[Live-demo] [OSGeo] #1176: grass upgrade to 6.4.3 not installable on disk
OSGeo trac_osgeo at osgeo.org
Mon Jul 29 14:37:09 PDT 2013
 Reporter:  kalxas   |       Owner:  live-demo@…
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  OSGeoLive7.0
Component:  LiveDVD  |    Keywords:
 grass logs from build 10513:
 Reading package lists...
 Building dependency tree...
 Reading state information...
 Some packages could not be installed. This may mean that you have
 requested an impossible situation or if you are using the unstable
 distribution that some required packages have not yet been created
 or been moved out of Incoming.
 The following information may help to resolve the situation:
 The following packages have unmet dependencies:
  grass : Depends: grass-core but it is not going to be installed
          Depends: grass-gui but it is not going to be installed
  grass-dev : Depends: grass-core (= 6.4.3~1precise1) but it is not going
 to be installed
 E: Unable to correct problems, you have held broken packages.
 ERROR: Package install failed! Aborting
 QGIS fails to install too.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1176>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
