[Live-demo] Update OSGeo-Live Project Overviews and Quickstarts - geoserver
Angelos Tzotsos
gcpp.kalxas at gmail.com
Mon Jul 29 07:50:53 PDT 2013
Thanks Benjamin,
Sorry I forgot 52North WPS :)
Best,
Angelos
On 07/29/2013 05:47 PM, Benjamin Proß wrote:
> GeoServer 2.3.4 works well with the 52°North WPS.
> Cheers,
> Benjamin
> Am 29.07.2013 14:49, schrieb Angelos Tzotsos:
>> Hi Frank,
>> After a small round of testing, it seems that GeoServer 2.3.4 did not
>> break any of the [Cartaro, GeoNode, ZOO] that use it in their
>> quickstarts.
>> The build tested is:
>> http://aiolos.survey.ntua.gr/gisvm/dev/osgeo-live-debug-build10503-i386.iso
>> http://aiolos.survey.ntua.gr/gisvm/dev/osgeo-live-debug-build10503-i386-log.tar.gz
>> Can the Cartaro team confirm?
>> I tested on behalf of GeoNode and ZOO projects since I am involved.
>> If I forget some other project that uses GeoServer as upstream,
>> please test and let me know.
>> Cheers,
>> Angelos
>> On 07/29/2013 10:49 AM, Frank Gasdorf wrote:
>>> Thanks Angelos, looking forward for the new ISO
>>> Cheers, Frank
>>> Am 29.07.2013 00:36 schrieb "Angelos Tzotsos" <gcpp.kalxas at gmail.com>:
>>>> Hi,
>>>> I see that an hour ago Geoserver was upgraded to 2.3.4 on svn.
>>>> I am going to make a nightly build with that setting and provide
>>>> the iso
>>>> link here soon.
>>>> Since we are in feature freeze, it is required from downstream
>>>> projects to
>>>> confirm that new GeoServer does not break their appllications. In
>>>> case it
>>>> does, the upgrade will be reverted for 7.0 and re-applied for 7.5.
>>>> Cheers,
>>>> Angelos
>>>> On 07/20/2013 02:04 AM, Angelos Tzotsos wrote:
>>>>> Hi Frank,
>>>>> I would be +1 on the upgrade only if Cartaro and GeoNode that have
>>>>> worked
>>>>> hard to catch up to 2.3.3 can confirm that their packages work
>>>>> fine with
>>>>> 2.3.4.
>>>>> BTW, Inspire plugin is already in the disk ;)
>>>>> Cheers,
>>>>> Angelos
>>>>> On Fri, Jul 19, 2013 at 10:54 PM, Frank Gasdorf <
>>>>> fgdrf at users.sourceforge.net
>>>>>> wrote:
>>>>>> Let me summarize the current state:
>>>>>> * geoserver is in version 2.3.3 on 7.0
>>>>>> * we would like to get 2.3.4 on it
>>>>>> * 2.3.4 will be build and released this weekend
>>>>>> what's new from my point of view:
>>>>>> * Translation completed for Dutch, German, Korean and close to is
>>>>>> Chinese
>>>>>> (98%) - will come with 2.3.4
>>>>>> * INSPIRE plugin made it into release (since 2.3.2)
>>>>>> * several Security Subsystem Improvements
>>>>>> * SQL Server performance improvements
>>>>>> * etc.
>>>>>> I hope we get 2.3.4 on OSGeo live 7.0 although we already have
>>>>>> feature
>>>>>> freeze. It would be great to get all the translated UI's for
>>>>>> GeoServer in
>>>>>> it because all the translation teams did a great job to (almost)
>>>>>> finish
>>>>>> it.
>>>>>> Any opinions?
>>>>>> Cheers, Frank
>>>>>> 2013/7/19 <cameron.shorter at gmail.com>
>>>>>> Ian, Frank,
>>>>>>> I'm not sure if you saw this email?
>>>>>>> We previously packaged version 2.2.2 of geoserver and our status
>>>>>>> sheet
>>>>>>> shows version 2.3.3 packaged for OSGeo-Live 7.0.
>>>>>>> On 19/07/2013 8:47 AM, Cameron Shorter wrote:
>>>>>>> Now that we have a feature freeze for OSGeo-Live 7.0, could all
>>>>>>>> OSGeo-Live projects please ensure
>>>>>>>> their Project Overviews and Quickstarts [0] are up to date. This
>>>>>>>> should be quite painless for most.
>>>>>>>> 1. Update the version number in your Project Overview (if
>>>>>>>> changed).
>>>>>>>> 2. Possibly mention a new feature or two.
>>>>>>>> 3. Re-run the Quickstart and ensure each step is still valid, and
>>>>>>>> screenshots match the implementation.
>>>>>>>> 4. Update status of the Project Overview and Quickstart to
>>>>>>>> "7.0draft"
>>>>>>>> in
>>>>>>>> our status sheet. [1]
>>>>>>>> Schedule:
>>>>>>> * 29 July 2013 English docs complete
>>>>>>>> * 05 August 2013 Translations complete
>>>>>>>> * 26 August 2013 OSGeo-Live sent to the printers
>>>>>>>> [0]
>>>>>>>> https://svn.osgeo.org/osgeo/****livedvd/gisvm/trunk/doc/<https://svn.osgeo.org/osgeo/**livedvd/gisvm/trunk/doc/>
>>>>>>> <https**://svn.osgeo.org/osgeo/**livedvd/gisvm/trunk/doc/<https://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/doc/>
>>>>>>> [1] https://docs.google.com/****spreadsheet/ccc?key=****
>>>>>>> 0Al9zh8DjmU_**<https://docs.google.com/**spreadsheet/ccc?key=**0Al9zh8DjmU_**>
>>>>>>>> RdGIzd0VLLTBpQVJuNVlHMlBWSDhKL****Xc#gid=13<https://docs.**
>>>>>>>> google.com/spreadsheet/ccc?**key=0Al9zh8DjmU_**
>>>>>>>> RdGIzd0VLLTBpQVJuNVlHMlBWSDhKL**Xc#gid=13<https://docs.google.com/spreadsheet/ccc?key=0Al9zh8DjmU_RdGIzd0VLLTBpQVJuNVlHMlBWSDhKLXc#gid=13>
>>>>>>> Cameron Shorter
>>>>>>> Geospatial Solutions Manager
>>>>>>> Tel: +61 (0)2 8570 5050
>>>>>>> Mob: +61 (0)419 142 254
>>>>>>> Think Globally, Fix Locally
>>>>>>> Geospatial Solutions enhanced with Open Standards and Open Source
>>>>>>> http://www.lisasoft.com
>>>> Angelos Tzotsos
>>>> Remote Sensing Laboratory
>>>> National Technical University of Athens
>>>> http://users.ntua.gr/tzotsos
Angelos Tzotsos
More information about the Live-demo
