[Live-demo] One version of geoserver on OSGeo-Live
Angelos Tzotsos gcpp.kalxas at gmail.com
Tue Jun 11 02:09:39 PDT 2013
We can update to 2.3.3 once it gets released.
Cheers,
Angelos
On 06/11/2013 02:24 AM, Cameron Shorter wrote:
> Ian Turton has recommended 2.3.3 (with 2.3.4 possible) for GeoServer.
> Ian,
> As there are other projects dependant upon GeoServer, I'll revise my
> previous advice to you, and suggest that we should try and lock in a
> stable version of GeoServer earlier than other projects so the other
> projects have time to test their applications. Ie, I'd suspect
> GeoServer 2.3.3 would probably be preferable.
> On 11/06/2013 12:37 AM, Angelos Tzotsos wrote:
>> Hi Patric,
>> I have already updated GeoServer to 2.3.2 in nightly builds.
>> http://aiolos.survey.ntua.gr/gisvm/dev/osgeo-live-debug-build10154-i386.iso
>> http://aiolos.survey.ntua.gr/gisvm/dev/osgeo-live-debug-build10154-i386-log.tar.gz
>> Can you please check if Cartaro is working as expected?
>> Thanks,
>> Angelos
>> On 06/10/2013 05:28 PM, Patric Hafner | geOps wrote:
>>> Hi,
>>> Am 10.06.2013 01:35, schrieb Angelos Tzotsos:
>>>> Only GeoNetwork has an internal GeoServer installation.
>>>> MapProxy, Sahana and Cartaro all use the stock GeoServer.
>>> For Cartaro, I can confirm this. Are there already any plans which
>>> version of GeoServer should be included ?
>>> For us, it is very important to know it as soon as possible, as there
>>> are some important changes between the 2.2.X and the 2.3.X series which
>>> may also affects other projects.
>>> With best regards,
>>> Patric
>>> We are hiring: http://www.geops.de/jobs
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
More information about the Live-demo mailing list
