[Live-demo] One version of geoserver on OSGeo-Live
Jody Garnett
jody.garnett at gmail.com
Thu Jun 20 17:36:00 PDT 2013
I am trying to release 2.3.3 currently.
It is a bit stuck as twitter reports GeoTools build failures on windows 7 + Java 7 (sigh). If anyone has a similar environment and is in position to run "mvn install -Dall" I can always use a hand.
(While Java 7 is not a supported environment it would still be nice it it compiled)
There are not many changes (https://jira.codehaus.org/secure/ReleaseNote.jspa?version=19230&projectId=10270) between 2.3.2 and 2.3.3 - this is the stable release stream after all.
Jody Garnett
On Tuesday, 11 June 2013 at 7:09 PM, Angelos Tzotsos wrote:
> Hi,
> We can update to 2.3.3 once it gets released.
> Cheers,
> Angelos
> On 06/11/2013 02:24 AM, Cameron Shorter wrote:
> > Ian Turton has recommended 2.3.3 (with 2.3.4 possible) for GeoServer.
> > Ian,
> > As there are other projects dependant upon GeoServer, I'll revise my
> > previous advice to you, and suggest that we should try and lock in a
> > stable version of GeoServer earlier than other projects so the other
> > projects have time to test their applications. Ie, I'd suspect
> > GeoServer 2.3.3 would probably be preferable.
> > On 11/06/2013 12:37 AM, Angelos Tzotsos wrote:
> > > Hi Patric,
> > > I have already updated GeoServer to 2.3.2 in nightly builds.
> > > http://aiolos.survey.ntua.gr/gisvm/dev/osgeo-live-debug-build10154-i386.iso
> > > http://aiolos.survey.ntua.gr/gisvm/dev/osgeo-live-debug-build10154-i386-log.tar.gz
> > > Can you please check if Cartaro is working as expected?
> > > Thanks,
> > > Angelos
> > > On 06/10/2013 05:28 PM, Patric Hafner | geOps wrote:
> > > > Hi,
> > > > Am 10.06.2013 01:35, schrieb Angelos Tzotsos:
> > > > > Only GeoNetwork has an internal GeoServer installation.
> > > > > MapProxy, Sahana and Cartaro all use the stock GeoServer.
> > > > For Cartaro, I can confirm this. Are there already any plans which
> > > > version of GeoServer should be included ?
> > > > For us, it is very important to know it as soon as possible, as there
> > > > are some important changes between the 2.2.X and the 2.3.X series which
> > > > may also affects other projects.
> > > > With best regards,
> > > > Patric
> > > > We are hiring: http://www.geops.de/jobs
> Angelos Tzotsos
> Remote Sensing Laboratory
> National Technical University of Athens
> http://users.ntua.gr/tzotsos
> Live-demo mailing list
> Live-demo at lists.osgeo.org (mailto:Live-demo at lists.osgeo.org)
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20130621/92d7d559/attachment.html>
More information about the Live-demo
