[Live-demo] Iris draft installer
Ian Edwards
iedwards.pub at gmail.com
Wed Jun 19 13:23:42 PDT 2013
Committed revision 10209
Incorporates Angelos' suggestion to remove the *-dev packages. Please let
me know if you spot any more tidying up that we can do.
On Wed, Jun 19, 2013 at 5:39 PM, Ian Edwards <iedwards.pub at gmail.com> wrote:
> Apologies Angelos - I've just committed the correct version that does the
> basic clean up
> http://trac.osgeo.org/osgeo/changeset/10204
> Got spot on the dev packages - that will save space. We'll provide another
> version of the install after we're ran the apt-get remove and tested that
> everything still works correctly.
> On Wed, Jun 19, 2013 at 5:35 PM, Angelos Tzotsos <gcpp.kalxas at gmail.com>wrote:
>> Hi Ian,
>> Thank you for your contribution.
>> I will enable the installer for the next nightly build.
>> One comment: I don't see a cleanup section in your script. Do you really
>> need the *-dev packages to stay in the dvd after the installation is over?
>> Best,
>> Angelos
>> On 06/19/2013 07:31 PM, Ian Edwards wrote:
>> We've submitted an installer for the Iris library:
>> http://trac.osgeo.org/osgeo/changeset/10203
>> Iris is split into a main library and also a plotting engine, these will
>> install to:
>> 3.3M
>> /usr/local/lib/python2.7/dist-packages/Iris-1.4.0-py2.7-linux-i686.egg
>> 2.1M /usr/local/lib/python2.7/dist-packages/cartopy
>> We've updated Matplotlib to version 1.2.0 (previously it was at 1.1.1rc1)
>> will this cause problems for anyone? There are also a few other
>> dependencies added.
>> Live-demo mailing listLive-demo at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/live-demohttp://live.osgeo.orghttp://wiki.osgeo.org/wiki/Live_GIS_Disc
>> Angelos Tzotsos
>> Remote Sensing Laboratory
>> National Technical University of Athenshttp://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20130619/ffd64a0c/attachment.html>
More information about the Live-demo
