[Live-demo] Iris draft installer
Angelos Tzotsos
gcpp.kalxas at gmail.com
Wed Jun 19 14:09:47 PDT 2013
Thank you very much for the fix.
Best,
Angelos
On 06/19/2013 11:23 PM, Ian Edwards wrote:
> Committed revision 10209
> Incorporates Angelos' suggestion to remove the *-dev packages. Please let
> me know if you spot any more tidying up that we can do.
> On Wed, Jun 19, 2013 at 5:39 PM, Ian Edwards <iedwards.pub at gmail.com> wrote:
>> Apologies Angelos - I've just committed the correct version that does the
>> basic clean up
>> http://trac.osgeo.org/osgeo/changeset/10204
>> Got spot on the dev packages - that will save space. We'll provide another
>> version of the install after we're ran the apt-get remove and tested that
>> everything still works correctly.
>> On Wed, Jun 19, 2013 at 5:35 PM, Angelos Tzotsos <gcpp.kalxas at gmail.com>wrote:
>>> Hi Ian,
>>> Thank you for your contribution.
>>> I will enable the installer for the next nightly build.
>>> One comment: I don't see a cleanup section in your script. Do you really
>>> need the *-dev packages to stay in the dvd after the installation is over?
>>> Best,
>>> Angelos
>>> On 06/19/2013 07:31 PM, Ian Edwards wrote:
>>> We've submitted an installer for the Iris library:
>>> http://trac.osgeo.org/osgeo/changeset/10203
>>> Iris is split into a main library and also a plotting engine, these will
>>> install to:
>>> 3.3M
>>> /usr/local/lib/python2.7/dist-packages/Iris-1.4.0-py2.7-linux-i686.egg
>>> 2.1M /usr/local/lib/python2.7/dist-packages/cartopy
>>> We've updated Matplotlib to version 1.2.0 (previously it was at 1.1.1rc1)
>>> will this cause problems for anyone? There are also a few other
>>> dependencies added.
>>> Live-demo mailing listLive-demo at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/live-demohttp://live.osgeo.orghttp://wiki.osgeo.org/wiki/Live_GIS_Disc
>>> Angelos Tzotsos
>>> Remote Sensing Laboratory
>>> National Technical University of Athenshttp://users.ntua.gr/tzotsos
Angelos Tzotsos
More information about the Live-demo
