[Live-demo] [OSGeo] #1234: pgRouting: PostGIS database ways table bad import os OSM data
OSGeo
trac_osgeo at osgeo.org
Thu Sep 19 00:58:08 PDT 2013
Reporter: hamish | Owner: dkastl
Type: defect | Status: assigned
Priority: critical | Milestone: OSGeoLive7.0
Component: LiveDVD | Keywords: pgRouting
Comment(by hamish):
just an update on the situation -- Daniel suggested that it might be a
32bit problem as it seems to test ok on 64bit ubuntu. OSM passed the 32bit
integer limit for feature ID a couple months ago so that may be the
culprit. The best thing would be to solve the bug in osm2pgrouting (if in
fact that's where the bug is :), but for the live disc on a deadline or
for a workshop with the 7.0 disc, perhaps some magic Postgres command to
delete lines connected to the one problematic node could help, or have
someone run the import on a 64bit ubuntu, dump the resulting DB to a file,
then reimport the DB on the live disc as part of the build process.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1234#comment:5>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
