[Live-demo] pgRouting PPA
Johan Van de Wauw
johan.vandewauw at gmail.com
Mon Jan 6 21:53:09 PST 2014
Daniel,
I noticed you have more recent versions (2.00-release) in your ppa
than in your git repository. Can you push your changes?
For the next live dvd I would like to build against postgresql 9.3, as
we did with postgis.
Johan
On Mon, Jan 6, 2014 at 2:28 AM, Daniel Kastl <daniel at georepublic.de> wrote:
> On Mon, Jan 6, 2014 at 10:16 AM, Alex Mandel <tech_dev at wildintellect.com>
> wrote:
>> On 01/05/2014 09:30 AM, Daniel Kastl wrote:
>> > Thanks for creating this OSGeo Live account on Launchpad!
>> > There is a "stable" PPA for pgRouting, which is also used in the install
>> > script of OSGeo Live.
>> > https://launchpad.net/~georepublic/+archive/pgrouting
>> > It's probably best to copy packages into the OSGeo Live PPA's. If you
>> > prefer to do this, then that's fine for me.
>> > But if you prefer that I care about having the right pgRouting packages
>> > in the PPA, then I can do this as well, if you add my account to
>> > “OSGeoLive” team.
>> > Best,
>> > Daniel
>> Daniel is pgRouting built against UbuntuGIS postgis, etc? We plan to
>> copy packages from there and freeze versions in our PPA as opposed to
>> directly putting packages in. So there is a very tight coupling and path
>> from UbuntuGIS to OSGeoLive (and when possible actually starts with
>> DebianGIS.
>> Thanks,
>> Alex
> Yes, the PostGIS package from UbuntuGIS repository is usually used.
> The dependency is just "postgis", and it works with any version, 1.5 and
> 2.x.
> So it's not particularly built with and dependent on UbuntuGIS, but
> personally I'm always using UbuntuGIS PPA together with pgRouting.
> pgRouting PPA is already used for pgRouting on LiveDVD for several releases,
> in fact OSGeo Live was one of the reasons to create a PPA.
> If anyone wants to help with the pgRouting Ubuntu/Debian builds (I don't
> think they are 100% following the Debian packaging policy), then this is
> quite simple by sending a pull request to the "pgrouting-build" repository
> on Github: https://github.com/pgRouting/pgrouting-build
> Thanks,
> Daniel
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
More information about the Live-demo
