[Live-demo] pgRouting PPA
Daniel Kastl daniel at georepublic.de
Mon Jan 6 22:26:32 PST 2014
Hi Johan,
You're right. I didn't realize I missed to push the changes.
Thanks for the notice!
I just pushed to the repository. I hope that was enough.
Still I have not enabled the Travis build tests for the repository, and I
think PostGIS is build from source for the test and not the official
release. But I don't think there will be an issue.
Daniel
On Tue, Jan 7, 2014 at 2:53 PM, Johan Van de Wauw <johan.vandewauw at gmail.com
> wrote:
> Daniel,
> I noticed you have more recent versions (2.00-release) in your ppa
> than in your git repository. Can you push your changes?
> For the next live dvd I would like to build against postgresql 9.3, as
> we did with postgis.
> Johan
> On Mon, Jan 6, 2014 at 2:28 AM, Daniel Kastl <daniel at georepublic.de>
> wrote:
> > On Mon, Jan 6, 2014 at 10:16 AM, Alex Mandel <tech_dev at wildintellect.com
> > wrote:
> >> On 01/05/2014 09:30 AM, Daniel Kastl wrote:
> >> > Thanks for creating this OSGeo Live account on Launchpad!
> >> > There is a "stable" PPA for pgRouting, which is also used in the
> install
> >> > script of  OSGeo Live.
> >> > https://launchpad.net/~georepublic/+archive/pgrouting
> >> > It's probably best to copy packages into the OSGeo Live PPA's. If you
> >> > prefer to do this, then that's fine for me.
> >> > But if you prefer that I care about having the right pgRouting
> packages
> >> > in the PPA, then I can do this as well, if you add my account to
> >> > “OSGeoLive” team.
> >> > Best,
> >> > Daniel
> >> Daniel is pgRouting built against UbuntuGIS postgis, etc? We plan to
> >> copy packages from there and freeze versions in our PPA as opposed to
> >> directly putting packages in. So there is a very tight coupling and path
> >> from UbuntuGIS to OSGeoLive (and when possible actually starts with
> >> DebianGIS.
> >> Thanks,
> >> Alex
> > Yes, the PostGIS package from UbuntuGIS repository is usually used.
> > The dependency is just "postgis", and it works with any version, 1.5 and
> > 2.x.
> > So it's not particularly built with and dependent on UbuntuGIS, but
> > personally I'm always using UbuntuGIS PPA together with pgRouting.
> > pgRouting PPA is already used for pgRouting on LiveDVD for several
> releases,
> > in fact OSGeo Live was one of the reasons to create a PPA.
> > If anyone wants to help with the pgRouting Ubuntu/Debian builds (I don't
> > think they are 100% following the Debian packaging policy), then this is
> > quite simple by sending a pull request to the "pgrouting-build"
> repository
> > on Github: https://github.com/pgRouting/pgrouting-build
> > Thanks,
> > Daniel
> > Georepublic UG & Georepublic Japan
> > eMail: daniel.kastl at georepublic.de
> > Web: http://georepublic.de
> > Live-demo mailing list
> > Live-demo at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/live-demo
> > http://live.osgeo.org
> > http://wiki.osgeo.org/wiki/Live_GIS_Disc
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20140107/2948b8b2/attachment.html>
More information about the Live-demo mailing list
