[Live-demo] Wiki update for Git
Matthias Streulens Geomajas matthias.streulens at geomajas.org
Tue May 26 06:59:58 PDT 2015
Hello,
can we already commit to git now ?
Or must we commit to svn ?
Kind regards,
Matthias
Angelos Tzotsos schreef op 26/05/2015 om 10:59:
> Thanks Luca,
> Your pull request is now merged :)
> Best,
> Angelos
> On 05/26/2015 11:13 AM, Luca Delucchi wrote:
>> On 23 May 2015 at 17:44, Angelos Tzotsos <gcpp.kalxas at gmail.com> wrote:
>>> Hi all,
>> Hi Angelos
>>> This is a first attempt to update our wiki regarding Git:
>>> http://wiki.osgeo.org/wiki/Live_GIS_Disc#Git_migration
>>> Please review.
>> I forked and cloned it, I also create a new branch to work on the pdf
>> output [0].
>> When I tried to compile html or latexpdf I got error for missing
>> files....
>> make latexpdf
>> for LANG in en ; do \
>>          cat index_pdf.template | sed "s/LANG_PDF/$LANG/#"  >
>> index.rst ; \
>> done
>> echo `pwd`
>> /home/lucadelu/github/OSGeoLive-doc
>> ../bin/extract_licenses.sh > licenses.csv
>> /bin/sh: 1: ../bin/extract_licenses.sh: not found
>> Makefile:134: recipe for target 'licenses.csv' failed
>> make: *** [licenses.csv] Error 127
>> make html
>> cp index.template index.rst
>> sphinx-build -b html -d _build/doctrees   . _build/html
>> Making output directory...
>> Running Sphinx v1.2.3
>> Exception occurred:
>>    File "conf.py", line 25, in <module>
>>      fileIN = open("../VERSION.txt", "r")
>> IOError: [Errno 2] No such file or directory: '../VERSION.txt'
>> The full traceback has been saved in /tmp/sphinx-err-sqFIS6.log, if
>> you want to report the issue to the developers.
>> Please also report this if it was a user error, so that a better error
>> message can be provided next time.
>> A bug report can be filed in the tracker at
>> <https://bitbucket.org/birkenfeld/sphinx/issues/>. Thanks!
>> Makefile:69: recipe for target 'sphinxbuild' failed
>> make: *** [sphinxbuild] Error 1
>> So I open a pull request [1] to add the needed files in to repository.
>> With this pull request it is possible to compile both html and
>> latexpdf but in the HTML there are still some errors
>> bin/extract_licenses.sh: 32: cd: can't cd to
>> /home/lucadelu/github/OSGeoLive-doc/bin/../doc/en/overview
>> awk: fatal: cannot open file `*.rst' for reading (No such file or
>> directory)
>> directory)
>> directory)
>> /home/lucadelu/github/OSGeoLive-doc/bin/../doc/en/quickstart
>> directory)
>> directory)
>> directory)
>>> Angelos
>> [0] https://github.com/lucadelu/OSGeoLive-doc/tree/pdf_output
>> [1] https://github.com/OSGeo/OSGeoLive-doc/pull/5
Dit e-mailbericht is gecontroleerd op virussen met Avast antivirussoftware.
http://www.avast.com
More information about the Live-demo mailing list
