[Live-demo] Wiki update for Git
Angelos Tzotsos gcpp.kalxas at gmail.com
Tue May 26 09:36:44 PDT 2015
You can now send pull requests on git.
We will move the official repository to GitLab soon, but that is no
blocker to start contributing ;)
Best,
Angelos
On 05/26/2015 04:59 PM, Matthias Streulens Geomajas wrote:
> Hello,
> can we already commit to git now ?
> Or must we commit to svn ?
> Kind regards,
> Matthias
> Angelos Tzotsos schreef op 26/05/2015 om 10:59:
>> Thanks Luca,
>> Your pull request is now merged :)
>> Best,
>> Angelos
>> On 05/26/2015 11:13 AM, Luca Delucchi wrote:
>>> On 23 May 2015 at 17:44, Angelos Tzotsos <gcpp.kalxas at gmail.com> wrote:
>>>> Hi all,
>>> Hi Angelos
>>>> This is a first attempt to update our wiki regarding Git:
>>>> http://wiki.osgeo.org/wiki/Live_GIS_Disc#Git_migration
>>>> Please review.
>>> I forked and cloned it, I also create a new branch to work on the pdf
>>> output [0].
>>> When I tried to compile html or latexpdf I got error for missing
>>> files....
>>> make latexpdf
>>> for LANG in en ; do \
>>>          cat index_pdf.template | sed "s/LANG_PDF/$LANG/#" >
>>> index.rst ; \
>>> done
>>> echo `pwd`
>>> /home/lucadelu/github/OSGeoLive-doc
>>> ../bin/extract_licenses.sh > licenses.csv
>>> /bin/sh: 1: ../bin/extract_licenses.sh: not found
>>> Makefile:134: recipe for target 'licenses.csv' failed
>>> make: *** [licenses.csv] Error 127
>>> make html
>>> cp index.template index.rst
>>> sphinx-build -b html -d _build/doctrees   . _build/html
>>> Making output directory...
>>> Running Sphinx v1.2.3
>>> Exception occurred:
>>>    File "conf.py", line 25, in <module>
>>>      fileIN = open("../VERSION.txt", "r")
>>> IOError: [Errno 2] No such file or directory: '../VERSION.txt'
>>> The full traceback has been saved in /tmp/sphinx-err-sqFIS6.log, if
>>> you want to report the issue to the developers.
>>> Please also report this if it was a user error, so that a better error
>>> message can be provided next time.
>>> A bug report can be filed in the tracker at
>>> <https://bitbucket.org/birkenfeld/sphinx/issues/>. Thanks!
>>> Makefile:69: recipe for target 'sphinxbuild' failed
>>> make: *** [sphinxbuild] Error 1
>>> So I open a pull request [1] to add the needed files in to repository.
>>> With this pull request it is possible to compile both html and
>>> latexpdf but in the HTML there are still some errors
>>> bin/extract_licenses.sh: 32: cd: can't cd to
>>> /home/lucadelu/github/OSGeoLive-doc/bin/../doc/en/overview
>>> awk: fatal: cannot open file `*.rst' for reading (No such file or
>>> directory)
>>> directory)
>>> directory)
>>> /home/lucadelu/github/OSGeoLive-doc/bin/../doc/en/quickstart
>>> directory)
>>> directory)
>>> directory)
>>>> Angelos
>>> [0] https://github.com/lucadelu/OSGeoLive-doc/tree/pdf_output
>>> [1] https://github.com/OSGeo/OSGeoLive-doc/pull/5
> Dit e-mailbericht is gecontroleerd op virussen met Avast
> antivirussoftware.
> http://www.avast.com
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
More information about the Live-demo mailing list
