[Live-demo] Permissions problems with GeoServer
Angelos Tzotsos
gcpp.kalxas at gmail.com
Tue Dec 6 02:02:56 PST 2016
Hi Ben,
I saw the same issue in nightly build5.
I am wondering why geoserver has this permission issue, previous
versions used to work fine with this setup.
Best,
Angelos
On 12/06/2016 05:10 AM, Ben Caradoc-Davies wrote:
> Angelos,
> even with my most recent fixes
> <https://github.com/bencaradocdavies/OSGeoLive/tree/upgrade-geoserver>,
> GeoServer on a nightly build will still not start.
> Looks to me like permissions problems (files and directories in the
> data directory whcih are owned by root). Likely culprit is
> install_geonode.sh, which starts GeoServer as root "to update layers
> in the geonode db", causing the creation of files and directories
> owned by root:root. The solution (in install_geonode.sh) might be
> something like:
> su -c "$GEOSERVER_PATH/bin/startup.sh" - user
> but it will take a little fiddling to get this working with
> redirection and running in the background. I will let you know when I
> have a fix.
> Kind regards,
Angelos Tzotsos, PhD
OSGeo Charter Member
http://users.ntua.gr/tzotsos
More information about the Live-demo
