[Live-demo] ISO not isohybrid, lacks UEFI support
Angelos Tzotsos
gcpp.kalxas at gmail.com
Tue Dec 6 08:12:13 PST 2016
Hi all,
A new build is available including the code from Ben's pull request:
http://aiolos.survey.ntua.gr/gisvm/dev/osgeo-live-nightly-build4-amd64-6875128.iso
Cheers,
Angelos
On 12/06/2016 06:01 PM, Johan Van de Wauw wrote:
> If a version is ready, I can test it on a few devices.
> On Tue, Dec 6, 2016 at 4:45 PM, Brian M Hamlin <maplabs at light42.com> wrote:
>> Hi All
>> this line of build steps looks promising .. my own small investigations into the UEFI boot process raised more questions than answers, so I am grateful to see a new set of resources applied to the problem.
>> Specifically, I had not seen nor heard of, GNU xorriso, and I had not gone through Ticket #1761 in detail.
>> great news, and I will make time to test a bit soon
>> best from Berkeley, California
>> --Brian
>> On Tue, 6 Dec 2016 20:55:17 +1100, Cameron Shorter wrote:
>> Sounds promising Ben.
>> Looks like size won't be an issue with what you are proposing.
>> I'd be interested to hear if Brian has any comments. Brian has burned a
>> lot of USBs for prior conferences and might have some feedback on things
>> to look out for.
>> Cheers, Cameron
>> On 6/12/2016 3:54 PM, Ben Caradoc-Davies wrote:
>>> Cameron,
>>> in my first test, isohybrid and UEFI support increases the size of the
>>> ISO image by only 411648 bytes.
>>> Kind regards,
>>> Ben.
>> On 6/12/2016 4:08 PM, Ben Caradoc-Davies wrote:
>>> Angelos,
>>> I think I have a working solution:
>>> https://github.com/OSGeo/OSGeoLive/pull/142
>>> Not yet tested on physical hardware. The ISO should now work after
>>> being written to a raw thumb drive with dd, just like the official
>>> Ubuntu and Lubuntu ISO images.
>>> All of these boot in QEMU:
>>> QEMU test as "cdrom":
>>> $ qemu-system-x86_64 -enable-kvm -m 2048 -cdrom
>>> osgeo-live-nightly-build6-amd64-ab426ef.iso
>>> QEMU test as MBR boot thumb drive (which boot as first hard disk):
>>> $ qemu-system-x86_64 -enable-kvm -m 2048 -hda
>>> osgeo-live-nightly-build6-amd64-ab426ef.iso ^C
>>> QEMU test as UEFI boot thumb drive (OVMF Tianocore UEFI BIOS):
>>> $ qemu-system-x86_64 -enable-kvm -m 2048 -bios /usr/share/ovmf/OVMF.fd
>>> -hda osgeo-live-nightly-build6-amd64-ab426ef.iso
>>> Boot equipment looks good to me:
>>> $ xorriso -indev osgeo-live-nightly-build6-amd64-ab426ef.iso
>>> -report_el_torito plain -report_system_area plain
>>> xorriso 1.4.6 : RockRidge filesystem manipulator, libburnia project.
>>> xorriso : NOTE : Loading ISO image tree from LBA 0
>>> xorriso : UPDATE : 502 nodes read in 1 seconds
>>> xorriso : NOTE : Detected El-Torito boot information which currently
>>> is set to be discarded
>>> Drive current: -indev 'osgeo-live-nightly-build6-amd64-ab426ef.iso'
>>> Media current: stdio file, overwriteable
>>> Media status : is written , is appendable
>>> Boot record : El Torito , MBR isohybrid cyl-align-off GPT
>>> Media summary: 1 session, 2069246 data blocks, 4041m data, 7489m free
>>> Volume id : 'OSGEOLIVE10'
>>> El Torito catalog : 164 1
>>> El Torito cat path : /isolinux/boot.cat
>>> El Torito images : N Pltf B Emul Ld_seg Hdpt Ldsiz LBA
>>> El Torito boot img : 1 BIOS y none 0x0000 0x00 4 165
>>> El Torito boot img : 2 UEFI y none 0x0000 0x00 4736 185
>>> El Torito img path : 1 /isolinux/isolinux.bin
>>> El Torito img opts : 1 boot-info-table isohybrid-suitable
>>> El Torito img path : 2 /boot/grub/efi.img
>>> System area options: 0x00000202
>>> System area summary: MBR isohybrid cyl-align-off GPT
>>> ISO image size/512 : 8276984
>>> Partition offset : 0
>>> MBR heads per cyl : 0
>>> MBR secs per head : 0
>>> MBR partition table: N Status Type Start Blocks
>>> MBR partition : 1 0x80 0x00 0 8278016
>>> MBR partition : 2 0x00 0xef 740 4736
>>> MBR partition path : 2 /boot/grub/efi.img
>>> GPT : N Info
>>> GPT disk GUID : c22a598de644cf4ababebbce02526bc1
>>> GPT entry array : 2 128 overlapping
>>> GPT lba range : 34 8277982 8278015
>>> GPT partition name : 1
>>> 490053004f004800790062007200690064002000490053004f00
>>> GPT partname local : 1 ISOHybrid ISO
>>> GPT partition GUID : 1 ddfce2b743e69e439dd9fd1b0859474c
>>> GPT type GUID : 1 a2a0d0ebe5b9334487c068b6b72699c7
>>> GPT partition flags: 1 0x0000000000000000
>>> GPT start and size : 1 0 8276984
>>> GPT partition name : 2 490053004f00480079006200720069006400
>>> GPT partname local : 2 ISOHybrid
>>> GPT partition GUID : 2 fd17fc2ba0182c4490c1d617372125de
>>> GPT type GUID : 2 a2a0d0ebe5b9334487c068b6b72699c7
>>> GPT partition flags: 2 0x0000000000000000
>>> GPT start and size : 2 740 4736
>>> GPT partition path : 2 /boot/grub/efi.img
>>> Kind regards,
>>> Ben.
>>> On 06/12/16 07:40, Ben Caradoc-Davies wrote:
>>>> Angelos,
>>>> I will see if I can get genisoimage+isohybrid to work. If not, I will
>>>> try xorriso, which seems to be under more active development.
>>>> Kind regards,
>>>> Ben.
>>>> On 04/12/16 23:22, Angelos Tzotsos wrote:
>>>>> Hi Ben,
>>>>> It is a known fact that Ubuntu has switched its build process closer to
>>>>> the Debian iso build process.
>>>>> I contacted several Ubuntu developers (specifically those who are
>>>>> responsible for the iso creation) during our previous dev cycle.
>>>>> Here is
>>>>> the information gathered back then:
>>>>> https://trac.osgeo.org/osgeo/ticket/1761
>>>>> We decided not to switch our build method since this would require too
>>>>> much effort.
>>>>> Now what you propose is something that sounds easier than switching to
>>>>> the new Ubuntu build process.
>>>>> Can you please make a pull request to include those extra isohybrid
>>>>> commands?
>>>>> Cheers,
>>>>> Angelos
>>>>> On 12/02/2016 01:16 AM, Ben Caradoc-Davies wrote:
>>>>>> The current ISO image osgeo-live-10.0-amd64.iso is not isohybrid, and
>>>>>> lacks UEFI support. As far as I know, all current official Ubuntu live
>>>>>> images have both. Shipping isohybrid images simplifies USB thumb drive
>>>>>> creation because the ISO can then be written directly to a raw device
>>>>>> with dd without needing any other processing, not to mention
>>>>>> consistency with Ubuntu.
>>>>>> Does anyone object to changing the ISO build process to make isohybrid
>>>>>> images with UEFI support? This should a matter of a few additional
>>>>>> xorriso arguments.
>>>>>> The current ISO is suitable for MBR isohybrid but lacks UEFI support:
>>>>>> $ isohybrid -u osgeo-live-10.0-amd64.iso
>>>>>> isohybrid: osgeo-live-10.0-amd64.iso: unable to find efi image
>>>>>> The existing boot equipment of the ISO contains only MBR support:
>>>>>> $ xorriso -indev osgeo-live-10.0-amd64.iso -report_el_torito plain
>>>>>> Drive current: -indev 'osgeo-live-10.0-amd64.iso'
>>>>>> Media summary: 1 session, 2062470 data blocks, 4028m data, 8267m free
>>>>>> Ldsiz LBA
>>>>>> xorriso : NOTE : No System Area was loaded
>>>>>> Kind regards,
>> Cameron Shorter
>> M +61 419 142 254
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/live-demo
>> http://live.osgeo.org
>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Angelos Tzotsos, PhD
OSGeo Charter Member
http://users.ntua.gr/tzotsos
More information about the Live-demo
