[Live-demo] ISO not isohybrid, lacks UEFI support
Ben Caradoc-Davies
ben at transient.nz
Tue Dec 6 18:25:48 PST 2016
Angelos,
my recent changes give me a working isohybrid+UEFI ISO with GeoServer
2.10.0 + NetCDF extension, combined in this new branch for your
nightly-building convenience:
https://github.com/bencaradocdavies/OSGeoLive/tree/devel
I have submitted the individual changes as separate pull requests.
Kind regards,
Ben.
On 07/12/16 05:12, Angelos Tzotsos wrote:
> Hi all,
> A new build is available including the code from Ben's pull request:
> http://aiolos.survey.ntua.gr/gisvm/dev/osgeo-live-nightly-build4-amd64-6875128.iso
> Cheers,
> Angelos
> On 12/06/2016 06:01 PM, Johan Van de Wauw wrote:
>> If a version is ready, I can test it on a few devices.
>> On Tue, Dec 6, 2016 at 4:45 PM, Brian M Hamlin <maplabs at light42.com>
>> wrote:
>>> Hi All
>>> this line of build steps looks promising .. my own small
>>> investigations into the UEFI boot process raised more questions than
>>> answers, so I am grateful to see a new set of resources applied to
>>> the problem.
>>> Specifically, I had not seen nor heard of, GNU xorriso, and I
>>> had not gone through Ticket #1761 in detail.
>>> great news, and I will make time to test a bit soon
>>> best from Berkeley, California
>>> --Brian
>>> On Tue, 6 Dec 2016 20:55:17 +1100, Cameron Shorter wrote:
>>> Sounds promising Ben.
>>> Looks like size won't be an issue with what you are proposing.
>>> I'd be interested to hear if Brian has any comments. Brian has burned a
>>> lot of USBs for prior conferences and might have some feedback on things
>>> to look out for.
>>> Cheers, Cameron
>>> On 6/12/2016 3:54 PM, Ben Caradoc-Davies wrote:
>>>> Cameron,
>>>> in my first test, isohybrid and UEFI support increases the size of the
>>>> ISO image by only 411648 bytes.
>>>> Kind regards,
>>>> Ben.
>>> On 6/12/2016 4:08 PM, Ben Caradoc-Davies wrote:
>>>> Angelos,
>>>> I think I have a working solution:
>>>> https://github.com/OSGeo/OSGeoLive/pull/142
>>>> Not yet tested on physical hardware. The ISO should now work after
>>>> being written to a raw thumb drive with dd, just like the official
>>>> Ubuntu and Lubuntu ISO images.
>>>> All of these boot in QEMU:
>>>> QEMU test as "cdrom":
>>>> $ qemu-system-x86_64 -enable-kvm -m 2048 -cdrom
>>>> osgeo-live-nightly-build6-amd64-ab426ef.iso
>>>> QEMU test as MBR boot thumb drive (which boot as first hard disk):
>>>> $ qemu-system-x86_64 -enable-kvm -m 2048 -hda
>>>> osgeo-live-nightly-build6-amd64-ab426ef.iso ^C
>>>> QEMU test as UEFI boot thumb drive (OVMF Tianocore UEFI BIOS):
>>>> $ qemu-system-x86_64 -enable-kvm -m 2048 -bios /usr/share/ovmf/OVMF.fd
>>>> -hda osgeo-live-nightly-build6-amd64-ab426ef.iso
>>>> Boot equipment looks good to me:
>>>> $ xorriso -indev osgeo-live-nightly-build6-amd64-ab426ef.iso
>>>> -report_el_torito plain -report_system_area plain
>>>> xorriso 1.4.6 : RockRidge filesystem manipulator, libburnia project.
>>>> xorriso : NOTE : Loading ISO image tree from LBA 0
>>>> xorriso : UPDATE : 502 nodes read in 1 seconds
>>>> xorriso : NOTE : Detected El-Torito boot information which currently
>>>> is set to be discarded
>>>> Drive current: -indev 'osgeo-live-nightly-build6-amd64-ab426ef.iso'
>>>> Media current: stdio file, overwriteable
>>>> Media status : is written , is appendable
>>>> Boot record : El Torito , MBR isohybrid cyl-align-off GPT
>>>> Media summary: 1 session, 2069246 data blocks, 4041m data, 7489m free
>>>> Volume id : 'OSGEOLIVE10'
>>>> El Torito catalog : 164 1
>>>> El Torito cat path : /isolinux/boot.cat
>>>> El Torito images : N Pltf B Emul Ld_seg Hdpt Ldsiz
>>>> LBA
>>>> El Torito boot img : 1 BIOS y none 0x0000 0x00 4 165
>>>> El Torito boot img : 2 UEFI y none 0x0000 0x00 4736 185
>>>> El Torito img path : 1 /isolinux/isolinux.bin
>>>> El Torito img opts : 1 boot-info-table isohybrid-suitable
>>>> El Torito img path : 2 /boot/grub/efi.img
>>>> System area options: 0x00000202
>>>> System area summary: MBR isohybrid cyl-align-off GPT
>>>> ISO image size/512 : 8276984
>>>> Partition offset : 0
>>>> MBR heads per cyl : 0
>>>> MBR secs per head : 0
>>>> MBR partition table: N Status Type Start Blocks
>>>> MBR partition : 1 0x80 0x00 0 8278016
>>>> MBR partition : 2 0x00 0xef 740 4736
>>>> MBR partition path : 2 /boot/grub/efi.img
>>>> GPT : N Info
>>>> GPT disk GUID : c22a598de644cf4ababebbce02526bc1
>>>> GPT entry array : 2 128 overlapping
>>>> GPT lba range : 34 8277982 8278015
>>>> GPT partition name : 1
>>>> 490053004f004800790062007200690064002000490053004f00
>>>> GPT partname local : 1 ISOHybrid ISO
>>>> GPT partition GUID : 1 ddfce2b743e69e439dd9fd1b0859474c
>>>> GPT type GUID : 1 a2a0d0ebe5b9334487c068b6b72699c7
>>>> GPT partition flags: 1 0x0000000000000000
>>>> GPT start and size : 1 0 8276984
>>>> GPT partition name : 2 490053004f00480079006200720069006400
>>>> GPT partname local : 2 ISOHybrid
>>>> GPT partition GUID : 2 fd17fc2ba0182c4490c1d617372125de
>>>> GPT type GUID : 2 a2a0d0ebe5b9334487c068b6b72699c7
>>>> GPT partition flags: 2 0x0000000000000000
>>>> GPT start and size : 2 740 4736
>>>> GPT partition path : 2 /boot/grub/efi.img
>>>> Kind regards,
>>>> Ben.
>>>> On 06/12/16 07:40, Ben Caradoc-Davies wrote:
>>>>> Angelos,
>>>>> I will see if I can get genisoimage+isohybrid to work. If not, I will
>>>>> try xorriso, which seems to be under more active development.
>>>>> Kind regards,
>>>>> Ben.
>>>>> On 04/12/16 23:22, Angelos Tzotsos wrote:
>>>>>> Hi Ben,
>>>>>> It is a known fact that Ubuntu has switched its build process
>>>>>> closer to
>>>>>> the Debian iso build process.
>>>>>> I contacted several Ubuntu developers (specifically those who are
>>>>>> responsible for the iso creation) during our previous dev cycle.
>>>>>> Here is
>>>>>> the information gathered back then:
>>>>>> https://trac.osgeo.org/osgeo/ticket/1761
>>>>>> We decided not to switch our build method since this would require
>>>>>> too
>>>>>> much effort.
>>>>>> Now what you propose is something that sounds easier than
>>>>>> switching to
>>>>>> the new Ubuntu build process.
>>>>>> Can you please make a pull request to include those extra isohybrid
>>>>>> commands?
>>>>>> Cheers,
>>>>>> Angelos
>>>>>> On 12/02/2016 01:16 AM, Ben Caradoc-Davies wrote:
>>>>>>> The current ISO image osgeo-live-10.0-amd64.iso is not isohybrid,
>>>>>>> and
>>>>>>> lacks UEFI support. As far as I know, all current official Ubuntu
>>>>>>> live
>>>>>>> images have both. Shipping isohybrid images simplifies USB thumb
>>>>>>> drive
>>>>>>> creation because the ISO can then be written directly to a raw
>>>>>>> device
>>>>>>> with dd without needing any other processing, not to mention
>>>>>>> consistency with Ubuntu.
>>>>>>> Does anyone object to changing the ISO build process to make
>>>>>>> isohybrid
>>>>>>> images with UEFI support? This should a matter of a few additional
>>>>>>> xorriso arguments.
>>>>>>> The current ISO is suitable for MBR isohybrid but lacks UEFI
>>>>>>> support:
>>>>>>> $ isohybrid -u osgeo-live-10.0-amd64.iso
>>>>>>> isohybrid: osgeo-live-10.0-amd64.iso: unable to find efi image
>>>>>>> The existing boot equipment of the ISO contains only MBR support:
>>>>>>> $ xorriso -indev osgeo-live-10.0-amd64.iso -report_el_torito plain
>>>>>>> Drive current: -indev 'osgeo-live-10.0-amd64.iso'
>>>>>>> Media summary: 1 session, 2062470 data blocks, 4028m data, 8267m
>>>>>>> free
>>>>>>> Ldsiz LBA
>>>>>>> xorriso : NOTE : No System Area was loaded
>>>>>>> Kind regards,
>>> Cameron Shorter
>>> M +61 419 142 254
>>> Live-demo mailing list
>>> Live-demo at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/live-demo
>>> http://live.osgeo.org
>>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Ben Caradoc-Davies <ben at transient.nz>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
More information about the Live-demo
