[Live-demo] [OSGeo] #1616: Comments on OSGeo-live 9.5 alpha2 testing
    OSGeo
    trac_osgeo at osgeo.org
    Thu Feb  4 13:28:59 PST 2016
 Reporter:  bakaniko  |      Owner:  live-demo@…
     Type:  task      |     Status:  new
 Priority:  normal    |  Milestone:  OSGeoLive9.5
Component:  LiveDVD   |   Keywords:  test, alpha2
 There is some comment I made after testing OSGeo-live 9.5 alpha2.
 Everything I tried was working and major stuff was in french, so i happy
 with it.
 Here is just some feedback that might useful.
 It is mostly quickstarts , but i went a little forward on qgis and
 postgis.
 thanks to kalxas suggesting posting it here.(comments in brackets are his)
 Tests
     On LiveCD:
     System:
     Language choosing on start up -> Great stuff !
     Full screen after logging: Perfect !
     Updates: 66 packages, 328.3 Mo right after boot with osgeo-
 live-9.5alpha2-amd64.iso?
     17 packages, 165 Mo with build 62-amd64-96cd3d3 ?
     (we update most packages on each build, without kernel updates, so the
 older the build, the more updates it will ask for)
     On virtualbox, shutdown stop at "Stopping early crypto disks", maybe
 an Ubuntu issue.
     (upstream issue)
     PostGIS:
     It Lacks a PostGIS Database with recommended extensions postgis,
 postgis_topology, fuzzystrmatch..
     (postgis databases exist in the build, I am not sure about topology
 though)
     -- pgrouting DB has postgis enabled, but not postgis_topology.
     It think for educational purposes easier to have a model with the an
 explicit name and recommended extensions to use as a template. --
     pgAdminIII:
     Working, little bug that i already have on an other installation of
 Postgre/PostGIS:
     Get that message launching shp2pgsql via button:
     src/common/menucmn.cpp(715): assert "!IsAttached()" failed in
 SetInvokingWindow(): menus attached to menu bar can't have invoking window
     There is one enter in Databases and one in Programmation ?
     shp2pgsql:
     Works, import and export of shape files
     SqLite Gui:
     Working
     QGIS:
     2.12.1 version and in French: great ! Not problems so far
     QGIS Browser:
     Ok
     GRASS:
     Working
     gvSIG:
     Why is it in Graphism and not in Geospatial ?
     OpenJump:
     Working
     SAGA:
     working
     JSOM:
     working
     iPython:
     working
     Hexchat:
     Why not make Freenode default irc server and #osgeo-live channel too ?
     R:
     Seems working, why is it in Graphism?
     gv:
     Working
     Kosmo:
     Seems working, no english version ?
     TileMille:
     Working
     Sahana:
     Working
     Cartaro:
     Working
     Ushahidi:
     Launched but not installed ?
     GeoServer:
     Working
     After Install in Virtualbox:
     installation: No problems
     QGIS started in English (it was in French in live session), but it is
 easy to change.
     Not thing to had
     Software choice:
     It is just my opinion, don't take personally.
     Lubuntu:
     I'd rather have Xfce or mate than LXDE.  I know it is lightweighted, i
 spend 2 years on #! (so with openbox) and i liked it. But LXDE, no i can't
 bare it.
     Abiword/ Gnunmeric:
     For professional use, i think OpenOffice will be a better choice.
     Games:
     Why ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1616>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
