[Live-demo] Review of istSOS Project Overview
    Cameron Shorter
    cameron.shorter at gmail.com
    Fri Feb  5 20:06:54 PST 2016
Hi Milan,
I've reviewed the Project Overview in detail, and Quickstart briefly.
I've made a few minor changes to wording, corrected a broken link,
removed the bold formatting in a few places (as I felt it made the text
harder to read and didn't look elegant). Interested to hear your thoughts?
I've pushed the changes to:
https://github.com/OSGeo/OSGeoLive-doc/pull/59
Warm regards, Cameron
On 5/02/2016 3:20 am, Angelos Tzotsos wrote:
> Thanks Milan,
> We will review and merge your changes.
> Best,
> Angelos
> On Thu, Feb 4, 2016 at 5:59 PM, Milan Antonovic
> <milan.antonovic at supsi.ch <mailto:milan.antonovic at supsi.ch>> wrote:
>     Hi Cameron,
>     I've made some small tweaking (see the pull request on github)
>     I think that the text is ok now.
>     Thank you very much
>     Best regards
>      _Milan
>     Il giorno mer 3 feb 2016 alle ore 21:52 Cameron Shorter
>     <cameron.shorter at gmail.com <mailto:cameron.shorter at gmail.com>> ha
>     scritto:
>         Hi Milan,
>         I've reviewed the istSOS Project Overview, made some minor
>         changes to text, fixed a couple of issues with image sizes,
>         fixed some link issues, and commited into git. I've made minor
>         changes to the Quickstart, but haven't given it a detailed review.
>         Next steps:
>         * I suggest you have a look at the 52nSOS Project Overview and
>         Quickstart, and see how istSOS compares, potentially tweaking
>         your description.
>         * Also have a look at the description changes I've made to the
>         Project Overview, and see if they should be copied into the
>         Quickstart.
>         On 29/01/2016 3:07 am, Milan Antonovic wrote:
>>         Hi all,
>>         I've modified the file as suggested (in the attachment)
>>         Please let me if it's ok..
>>         Kind regards
>>          _Milan
>>         Il giorno gio 28 gen 2016 alle ore 15:13 Angelos Tzotsos
>>         <gcpp.kalxas at gmail.com <mailto:gcpp.kalxas at gmail.com>> ha
>>         scritto:
>>             Hi Maxi,
>>             I am referring to the quickstart and overview pages, in
>>             order to add to
>>             git and to the nightly builds.
>>             I was assuming that you would make a pull request. If
>>             not, I can add the
>>             documents directly.
>>             Best,
>>             Angelos
>>             On 01/28/2016 12:57 PM, Massimiliano Cannata wrote:
>>             > Hi Angelos,
>>             > thanks for completing the install.
>>             > When you talk of documentation what do you refer to?
>>             > The quickstart and the project description I have
>>             already provided to
>>             > Cameron?
>>             > Or to the istSOS documentation, which i guess should
>>             remain on the istsos
>>             > website?
>>             > Thanks for clarification
>>             > Maxi
>>             > 2016-01-28 0:11 GMT+01:00 Angelos Tzotsos
>>             <gcpp.kalxas at gmail.com <mailto:gcpp.kalxas at gmail.com>>:
>>             >> Hi Maxi and Milan,
>>             >> I have just completed an installer script for istSOS:
>>             >> https://github.com/OSGeo/OSGeoLive/pull/59/files
>>             >> This would be a good time to include the documentation
>>             too.
>>             >> Best,
>>             >> Angelos
>>             >> On 01/20/2016 09:25 AM, Cameron Shorter wrote:
>>             >> Hi Milan,
>>             >> I can see you have fixed the images. Thanks.
>>             >> I'm not sure if you noticed, but I made a number of
>>             updates to the text,
>>             >> primarily providing slight rewording of the English
>>             syntax, such that it
>>             >> aligns with the rest of the OSGeo-Live documentation.
>>             >> For instance, I had changed your:
>>             >> "* Offer your data according to the Sensor Observation
>>             Service standard
>>             >> from Open Geospatial Consortium."
>>             >> to:
>>             >> "* Publish sensor data in accordance with the Sensor
>>             Observation Service (
>>             >> SOS) standard."
>>             >> Could you please have a look at the review I provided,
>>             and do a "diff"
>>             >> comparison with your text. Hopefully most of my
>>             suggested changes should be
>>             >> able to be used without changes.
>>             >> On Tue, Jan 19, 2016 at 2:01 AM, Milan Antonovic
>>             >> wrote:
>>             >> Hi Cameron,
>>             >> Thanks for your review. I modified texts and images
>>             following your
>>             >> comments.
>>             >> You will find the modifications in the attachment.
>>             >> Best regards
>>             >>   _Milan
>>             >> Il giorno dom 10 gen 2016 alle ore 22:54 Cameron
>>             Shorter <cameron.shorter at gmail.com
>>             <mailto:cameron.shorter at gmail.com>> ha scritto:
>>             >> Hi Maxi,
>>             >> I've reviewed your istSOS Project Overview which is
>>             attached.
>>             >> Have you put this into git yet? If not, I suggest you do.
>>             >> Overall, it looks to be in pretty good shape.
>>             >> I've tweaked some of the syntax, and made some
>>             comments. Look for "..
>>             >> Cameron comment:"
>>             >> My key comment is that the images are too large, which
>>             makes the layout
>>             >> look bad.
>>             >> Could you please review my suggestions, and if ok,
>>             please include into
>>             >> your git commit.
>>             >> Warm regards,
>>             >> Cameron Shorter
>>             >> On 23/12/2015 11:47 pm, Massimiliano Cannata wrote:
>>             >> Dear Cameron and OSGeo-Live team,
>>             >> in attachemnt you can find the documents required for
>>             setting up istSOS
>>             >> in the new Live-demo
>>             >> Please cnsider these as still in draft format, so that
>>             required changes
>>             >> can be done in the next future.
>>             >> Best,
>>             >> Maxi
>>             >> 2015-12-19 3:36 GMT+01:00 Cameron Shorter
>>             <mailto:cameron.shorter at gmail.com>>:
>>             >> Hi Massimiliano and Milan,
>>             >> If I look at the istSOS OpenHub metrics, it suggests
>>             that 95% of the
>>             >> code is javascript, however the project summary notes
>>             the project is
>>             >> written in Python.
>>             >> Would I be right in suspecting that your OpenHub entry
>>             is not accurately
>>             >> pointing at your source code?
>>             >> If so, could you please update OpenHub such that the
>>             metrics are more
>>             >> accurate.
>>             >> We encourage people to assess the quality of a project
>>             by looking at
>>             >> Open Hub metrics [2]
>>             >> [1] https://www.openhub.net/p/istsos
>>             >> [2] http://live.osgeo.org/en/metrics.html
>>             >> On 18/12/2015 8:33 am, Cameron Shorter wrote:
>>             >> Seems my last email was too big for the email list,
>>             here is the trimmed
>>             >> version:
>>             >> On 18/12/2015 8:18 am, Cameron Shorter wrote:
>>             >> Hi Massimiliano,
>>             >> We discussed including istSOS on OSGeo-Live in our
>>             weekly meeting today,
>>             >> and all present were in favour of it being included.
>>             So welcome to the
>>             >> OSGeo-Live community.
>>             >> Could you please focus first on working out your
>>             install process so that
>>             >> we can get istSOS into OSGeo-Live builds and start
>>             testing it.
>>             >> Then start working on the Project Overview and Quickstart.
>>             >> Could you also please start an email thread suggesting
>>             what dataset(s)
>>             >> should be used for istSOS.
>>             >> I suspect that your dataset needs would be similar to
>>             52 North SOS?
>>             >> There may be other datasets on OSGeo-Live which might
>>             be of use too?
>>             >> Ideally we'd like to ensure we use the same datasets
>>             across applications
>>             >> On 17/12/2015 7:52 pm, Massimiliano Cannata wrote:
>>             >> Dear Cameron, sear OSGeo-live team,
>>             >> here below you can find the istSOS application ofr
>>             being included in
>>             >> the next OSGeo live release.
>>             >> Cameron Shorter,
>>             >> Software and Data Solutions Manager
>>             >> LISAsoft
>>             >> Suite 112, Jones Bay Wharf,
>>             >> 26 - 32 Pirrama Rd, Pyrmont NSW 2009
>>             >> P +61 2 9009 5000 <tel:%2B61%202%209009%205000>,  W
>>             www.lisasoft.com <http://www.lisasoft.com>, F +61 2 9009
>>             5099 <tel:%2B61%202%209009%205099>
>>             >> Cameron Shorter,
>>             >> LISAsoft
>>             >> *Massimiliano Cannata*
>>             >> Professore SUPSI in ingegneria Geomatica
>>             >> Responsabile settore Geomatica
>>             >> Istituto scienze della Terra
>>             >> Dipartimento ambiente costruzione e design
>>             >> Scuola universitaria professionale della Svizzera italiana
>>             >> Campus Trevano, CH - 6952 Canobbio
>>             >> Tel. +41 (0)58 666 62 14
>>             <tel:%2B41%20%280%2958%20666%2062%2014>
>>             >> Fax +41 (0)58 666 62 09
>>             <tel:%2B41%20%280%2958%20666%2062%2009>
>>             >> <massimiliano.cannata at supsi.ch
>>             <mailto:massimiliano.cannata at supsi.ch>>
>>             <mailto:massimiliano.cannata at supsi.ch>>massimiliano.cannata at supsi.ch
>>             >> *www.supsi.ch/ist <http://www.supsi.ch/ist>
>>             <http://www.supsi.ch/ist> <http://www.supsi.ch/ist>*
>>             >> Cameron Shorter,
>>             >> LISAsoft
>>             >> _______________________________________________
>>             >> Live-demo mailing listLive-demo at lists.osgeo.orghttp://
>>             <mailto:listLive-demo at lists.osgeo.orghttp://>lists.osgeo.org/mailman/listinfo/live-demohttp://live.osgeo.orghttp://wiki.osgeo.org/wiki/Live_GIS_Disc
>>             <http://lists.osgeo.org/mailman/listinfo/live-demohttp://live.osgeo.orghttp://wiki.osgeo.org/wiki/Live_GIS_Disc>
>>             >> Angelos Tzotsos, PhD
>>             >> OSGeo Charter Memberhttp://users.ntua.gr/tzotsos
>>             <http://users.ntua.gr/tzotsos>
>         Cameron Shorter,
>         LISAsoft
>         P+61 2 9009 5000 <tel:%2B61%202%209009%205000>,  Wwww.lisasoft.com <http://www.lisasoft.com>,  F+61 2 9009 5099 <tel:%2B61%202%209009%205099>
Cameron Shorter,
LISAsoft
P +61 2 9009 5000,  W www.lisasoft.com,  F +61 2 9009 5099
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20160206/c4fbb979/attachment-0001.html>
More information about the Live-demo
