[Live-demo] Review of istSOS Project Overview
Angelos Tzotsos gcpp.kalxas at gmail.com
Thu Jan 28 06:13:08 PST 2016
Hi Maxi,
I am referring to the quickstart and overview pages, in order to add to
git and to the nightly builds.
I was assuming that you would make a pull request. If not, I can add the
documents directly.
Best,
Angelos
On 01/28/2016 12:57 PM, Massimiliano Cannata wrote:
> Hi Angelos,
> thanks for completing the install.
> When you talk of documentation what do you refer to?
> The quickstart and the project description I have already provided to
> Cameron?
> Or to the istSOS documentation, which i guess should remain on the istsos
> website?
> Thanks for clarification
> Maxi
> 2016-01-28 0:11 GMT+01:00 Angelos Tzotsos <gcpp.kalxas at gmail.com>:
>> Hi Maxi and Milan,
>> I have just completed an installer script for istSOS:
>> https://github.com/OSGeo/OSGeoLive/pull/59/files
>> This would be a good time to include the documentation too.
>> Best,
>> Angelos
>> On 01/20/2016 09:25 AM, Cameron Shorter wrote:
>> Hi Milan,
>> I can see you have fixed the images. Thanks.
>> I'm not sure if you noticed, but I made a number of updates to the text,
>> primarily providing slight rewording of the English syntax, such that it
>> aligns with the rest of the OSGeo-Live documentation.
>> For instance, I had changed your:
>> "* Offer your data according to the Sensor Observation Service standard
>> from Open Geospatial Consortium."
>> to:
>> "* Publish sensor data in accordance with the Sensor Observation Service (
>> SOS) standard."
>> Could you please have a look at the review I provided, and do a "diff"
>> comparison with your text. Hopefully most of my suggested changes should be
>> able to be used without changes.
>> Warm regards, Cameron
>> On Tue, Jan 19, 2016 at 2:01 AM, Milan Antonovic <milan.antonovic at supsi.ch> <milan.antonovic at supsi.ch>
>> wrote:
>> Hi Cameron,
>> Thanks for your review. I modified texts and images following your
>> comments.
>> You will find the modifications in the attachment.
>> Best regards
>>   _Milan
>> Il giorno dom 10 gen 2016 alle ore 22:54 Cameron Shorter <cameron.shorter at gmail.com> ha scritto:
>> Hi Maxi,
>> I've reviewed your istSOS Project Overview which is attached.
>> Have you put this into git yet? If not, I suggest you do.
>> Overall, it looks to be in pretty good shape.
>> I've tweaked some of the syntax, and made some comments. Look for "..
>> Cameron comment:"
>> My key comment is that the images are too large, which makes the layout
>> look bad.
>> Could you please review my suggestions, and if ok, please include into
>> your git commit.
>> Warm regards,
>> Cameron Shorter
>> On 23/12/2015 11:47 pm, Massimiliano Cannata wrote:
>> Dear Cameron and OSGeo-Live team,
>> in attachemnt you can find the documents required for setting up istSOS
>> in the new Live-demo
>> Please cnsider these as still in draft format, so that required changes
>> can be done in the next future.
>> Best,
>> Maxi
>> 2015-12-19 3:36 GMT+01:00 Cameron Shorter <cameron.shorter at gmail.com> <cameron.shorter at gmail.com>:
>> Hi Massimiliano and Milan,
>> If I look at the istSOS OpenHub metrics, it suggests that 95% of the
>> code is javascript, however the project summary notes the project is
>> written in Python.
>> Would I be right in suspecting that your OpenHub entry is not accurately
>> pointing at your source code?
>> If so, could you please update OpenHub such that the metrics are more
>> accurate.
>> We encourage people to assess the quality of a project by looking at
>> Open Hub metrics [2]
>> [1] https://www.openhub.net/p/istsos
>> [2] http://live.osgeo.org/en/metrics.html
>> On 18/12/2015 8:33 am, Cameron Shorter wrote:
>> Seems my last email was too big for the email list, here is the trimmed
>> version:
>> On 18/12/2015 8:18 am, Cameron Shorter wrote:
>> Hi Massimiliano,
>> We discussed including istSOS on OSGeo-Live in our weekly meeting today,
>> and all present were in favour of it being included. So welcome to the
>> OSGeo-Live community.
>> Could you please focus first on working out your install process so that
>> we can get istSOS into OSGeo-Live builds and start testing it.
>> Then start working on the Project Overview and Quickstart.
>> Could you also please start an email thread suggesting what dataset(s)
>> should be used for istSOS.
>> I suspect that your dataset needs would be similar to 52 North SOS?
>> There may be other datasets on OSGeo-Live which might be of use too?
>> Ideally we'd like to ensure we use the same datasets across applications
>> On 17/12/2015 7:52 pm, Massimiliano Cannata wrote:
>> Dear Cameron, sear OSGeo-live team,
>> here below you can find the istSOS application ofr being included in
>> the next OSGeo live release.
>> Cameron Shorter,
>> Software and Data Solutions Manager
>> LISAsoft
>> Suite 112, Jones Bay Wharf,
>> 26 - 32 Pirrama Rd, Pyrmont NSW 2009
>> P +61 2 9009 5000,  W www.lisasoft.com,  F +61 2 9009 5099
>> Cameron Shorter,
>> LISAsoft
>> *Massimiliano Cannata*
>> Professore SUPSI in ingegneria Geomatica
>> Responsabile settore Geomatica
>> Istituto scienze della Terra
>> Dipartimento ambiente costruzione e design
>> Scuola universitaria professionale della Svizzera italiana
>> Campus Trevano, CH - 6952 Canobbio
>> Tel. +41 (0)58 666 62 14
>> Fax +41 (0)58 666 62 09
>> <massimiliano.cannata at supsi.ch> <massimiliano.cannata at supsi.ch>massimiliano.cannata at supsi.ch
>> *www.supsi.ch/ist <http://www.supsi.ch/ist> <http://www.supsi.ch/ist>*
>> Cameron Shorter,
>> LISAsoft
>> Live-demo mailing listLive-demo at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/live-demohttp://live.osgeo.orghttp://wiki.osgeo.org/wiki/Live_GIS_Disc
>> Angelos Tzotsos, PhD
>> OSGeo Charter Memberhttp://users.ntua.gr/tzotsos
More information about the Live-demo mailing list
