[Live-demo] Review of istSOS Project Overview
Cameron Shorter cameron.shorter at lisasoft.com
Thu Jan 28 13:06:28 PST 2016
Hi Maxi,
We were discussing the istSOS Project Overview docs in our weekly
OSGeo-Live meeting today.
Have you had a chance to go back and re-check my original review (where I
made a number of tweaks to the proposed text).
I've re-attached my review text. (I suggest using my text as a basis, and
if you have any changes, then apply them over mine).
On 20/01/2016 6:25 pm, Cameron Shorter wrote:
Hi Milan,
I can see you have fixed the images. Thanks.
I'm not sure if you noticed, but I made a number of updates to the text,
primarily providing slight rewording of the English syntax, such that it
aligns with the rest of the OSGeo-Live documentation.
For instance, I had changed your:
"* Offer your data according to the Sensor Observation Service standard
from Open Geospatial Consortium."
to:
"* Publish sensor data in accordance with the Sensor Observation Service (
SOS) standard."
Could you please have a look at the review I provided, and do a "diff"
comparison with your text. Hopefully most of my suggested changes should be
able to be used without changes.
Warm regards, Cameron
On Fri, Jan 29, 2016 at 1:13 AM, Angelos Tzotsos <gcpp.kalxas at gmail.com>
wrote:
> Hi Maxi,
> I am referring to the quickstart and overview pages, in order to add to
> git and to the nightly builds.
> I was assuming that you would make a pull request. If not, I can add the
> documents directly.
> Best,
> Angelos
> On 01/28/2016 12:57 PM, Massimiliano Cannata wrote:
>> Hi Angelos,
>> thanks for completing the install.
>> When you talk of documentation what do you refer to?
>> The quickstart and the project description I have already provided to
>> Cameron?
>> Or to the istSOS documentation, which i guess should remain on the istsos
>> website?
>> Thanks for clarification
>> Maxi
>> 2016-01-28 0:11 GMT+01:00 Angelos Tzotsos <gcpp.kalxas at gmail.com>:
>> Hi Maxi and Milan,
>>> I have just completed an installer script for istSOS:
>>> https://github.com/OSGeo/OSGeoLive/pull/59/files
>>> This would be a good time to include the documentation too.
>>> Best,
>>> Angelos
>>> On 01/20/2016 09:25 AM, Cameron Shorter wrote:
>>> Hi Milan,
>>> to:
>>> SOS) standard."
>>> be
>>> On Tue, Jan 19, 2016 at 2:01 AM, Milan Antonovic <
>>> milan.antonovic at supsi.ch> <milan.antonovic at supsi.ch>
>>> wrote:
>>> Hi Cameron,
>>> Thanks for your review. I modified texts and images following your
>>> comments.
>>> You will find the modifications in the attachment.
>>> Best regards
>>>   _Milan
>>> Il giorno dom 10 gen 2016 alle ore 22:54 Cameron Shorter <
>>> cameron.shorter at gmail.com> ha scritto:
>>> Hi Maxi,
>>> I've reviewed your istSOS Project Overview which is attached.
>>> Have you put this into git yet? If not, I suggest you do.
>>> Overall, it looks to be in pretty good shape.
>>> I've tweaked some of the syntax, and made some comments. Look for "..
>>> Cameron comment:"
>>> My key comment is that the images are too large, which makes the layout
>>> look bad.
>>> Could you please review my suggestions, and if ok, please include into
>>> your git commit.
>>> Warm regards,
>>> Cameron Shorter
>>> On 23/12/2015 11:47 pm, Massimiliano Cannata wrote:
>>> Dear Cameron and OSGeo-Live team,
>>> in attachemnt you can find the documents required for setting up istSOS
>>> in the new Live-demo
>>> Please cnsider these as still in draft format, so that required changes
>>> can be done in the next future.
>>> Best,
>>> Maxi
>>> 2015-12-19 3:36 GMT+01:00 Cameron Shorter <cameron.shorter at gmail.com> <
>>> cameron.shorter at gmail.com>:
>>> Hi Massimiliano and Milan,
>>> If I look at the istSOS OpenHub metrics, it suggests that 95% of the
>>> code is javascript, however the project summary notes the project is
>>> written in Python.
>>> Would I be right in suspecting that your OpenHub entry is not accurately
>>> pointing at your source code?
>>> If so, could you please update OpenHub such that the metrics are more
>>> accurate.
>>> We encourage people to assess the quality of a project by looking at
>>> Open Hub metrics [2]
>>> [1] https://www.openhub.net/p/istsos
>>> [2] http://live.osgeo.org/en/metrics.html
>>> On 18/12/2015 8:33 am, Cameron Shorter wrote:
>>> Seems my last email was too big for the email list, here is the trimmed
>>> version:
>>> On 18/12/2015 8:18 am, Cameron Shorter wrote:
>>> Hi Massimiliano,
>>> We discussed including istSOS on OSGeo-Live in our weekly meeting today,
>>> and all present were in favour of it being included. So welcome to the
>>> OSGeo-Live community.
>>> Could you please focus first on working out your install process so that
>>> we can get istSOS into OSGeo-Live builds and start testing it.
>>> Then start working on the Project Overview and Quickstart.
>>> Could you also please start an email thread suggesting what dataset(s)
>>> should be used for istSOS.
>>> I suspect that your dataset needs would be similar to 52 North SOS?
>>> There may be other datasets on OSGeo-Live which might be of use too?
>>> Ideally we'd like to ensure we use the same datasets across applications
>>> On 17/12/2015 7:52 pm, Massimiliano Cannata wrote:
>>> Dear Cameron, sear OSGeo-live team,
>>> here below you can find the istSOS application ofr being included in
>>> the next OSGeo live release.
>>> Cameron Shorter,
>>> Software and Data Solutions Manager
>>> LISAsoft
>>> Suite 112, Jones Bay Wharf,
>>> 26 - 32 Pirrama Rd, Pyrmont NSW 2009
>>> P +61 2 9009 5000,  W www.lisasoft.com,  F +61 2 9009 5099
>>> Cameron Shorter,
>>> LISAsoft
>>> *Massimiliano Cannata*
>>> Professore SUPSI in ingegneria Geomatica
>>> Responsabile settore Geomatica
>>> Istituto scienze della Terra
>>> Dipartimento ambiente costruzione e design
>>> Scuola universitaria professionale della Svizzera italiana
>>> Campus Trevano, CH - 6952 Canobbio
>>> Tel. +41 (0)58 666 62 14
>>> Fax +41 (0)58 666 62 09
>>> <massimiliano.cannata at supsi.ch> <massimiliano.cannata at supsi.ch>
>>> *www.supsi.ch/ist <http://www.supsi.ch/ist> <http://www.supsi.ch/ist>*
>>> Cameron Shorter,
>>> LISAsoft
>>> Live-demo mailing listLive-demo at lists.osgeo.orghttp://
>>> lists.osgeo.org/mailman/listinfo/live-demohttp://live.osgeo.orghttp://wiki.osgeo.org/wiki/Live_GIS_Disc
>>> Angelos Tzotsos, PhD
>>> OSGeo Charter Memberhttp://users.ntua.gr/tzotsos
> http://lists.osgeo.org/mailman/listinfo/live-demo
Cameron Shorter,
LISAsoft
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20160129/9cb63336/attachment-0001.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20160129/9cb63336/attachment-0001.obj>
More information about the Live-demo mailing list
