[Live-demo] Review of istSOS Project Overview
    Cameron Shorter
    cameron.shorter at lisasoft.com
    Thu Jan 28 13:11:03 PST 2016
Oops,
Please ignore last email. I see that Mlan has just sent updated text to my
other email account. I'll review that over the next 48 hours or so.
Warm regards, Cameron
On Fri, Jan 29, 2016 at 8:06 AM, Cameron Shorter <
cameron.shorter at lisasoft.com> wrote:
> Hi Maxi,
> We were discussing the istSOS Project Overview docs in our weekly
> OSGeo-Live meeting today.
> Have you had a chance to go back and re-check my original review (where I
> made a number of tweaks to the proposed text).
> I've re-attached my review text. (I suggest using my text as a basis, and
> if you have any changes, then apply them over mine).
> On 20/01/2016 6:25 pm, Cameron Shorter wrote:
> Hi Milan,
> I can see you have fixed the images. Thanks.
> I'm not sure if you noticed, but I made a number of updates to the text,
> primarily providing slight rewording of the English syntax, such that it
> aligns with the rest of the OSGeo-Live documentation.
> For instance, I had changed your:
> "* Offer your data according to the Sensor Observation Service standard
> from Open Geospatial Consortium."
> to:
> "* Publish sensor data in accordance with the Sensor Observation Service (
> SOS) standard."
> Could you please have a look at the review I provided, and do a "diff"
> comparison with your text. Hopefully most of my suggested changes should be
> able to be used without changes.
> On Fri, Jan 29, 2016 at 1:13 AM, Angelos Tzotsos <gcpp.kalxas at gmail.com>
> wrote:
>> Hi Maxi,
>> I am referring to the quickstart and overview pages, in order to add to
>> git and to the nightly builds.
>> I was assuming that you would make a pull request. If not, I can add the
>> documents directly.
>> Best,
>> Angelos
>> On 01/28/2016 12:57 PM, Massimiliano Cannata wrote:
>>> Hi Angelos,
>>> thanks for completing the install.
>>> When you talk of documentation what do you refer to?
>>> The quickstart and the project description I have already provided to
>>> Cameron?
>>> Or to the istSOS documentation, which i guess should remain on the istsos
>>> website?
>>> Thanks for clarification
>>> Maxi
>>> 2016-01-28 0:11 GMT+01:00 Angelos Tzotsos <gcpp.kalxas at gmail.com>:
>>> Hi Maxi and Milan,
>>>> I have just completed an installer script for istSOS:
>>>> https://github.com/OSGeo/OSGeoLive/pull/59/files
>>>> This would be a good time to include the documentation too.
>>>> Best,
>>>> Angelos
>>>> On 01/20/2016 09:25 AM, Cameron Shorter wrote:
>>>> Hi Milan,
>>>> to:
>>>> Service (
>>>> SOS) standard."
>>>> should be
>>>> On Tue, Jan 19, 2016 at 2:01 AM, Milan Antonovic <
>>>> milan.antonovic at supsi.ch> <milan.antonovic at supsi.ch>
>>>> wrote:
>>>> Hi Cameron,
>>>> Thanks for your review. I modified texts and images following your
>>>> comments.
>>>> You will find the modifications in the attachment.
>>>> Best regards
>>>>   _Milan
>>>> Il giorno dom 10 gen 2016 alle ore 22:54 Cameron Shorter <
>>>> cameron.shorter at gmail.com> ha scritto:
>>>> Hi Maxi,
>>>> I've reviewed your istSOS Project Overview which is attached.
>>>> Have you put this into git yet? If not, I suggest you do.
>>>> Overall, it looks to be in pretty good shape.
>>>> I've tweaked some of the syntax, and made some comments. Look for "..
>>>> Cameron comment:"
>>>> My key comment is that the images are too large, which makes the layout
>>>> look bad.
>>>> Could you please review my suggestions, and if ok, please include into
>>>> your git commit.
>>>> Warm regards,
>>>> Cameron Shorter
>>>> On 23/12/2015 11:47 pm, Massimiliano Cannata wrote:
>>>> Dear Cameron and OSGeo-Live team,
>>>> in attachemnt you can find the documents required for setting up istSOS
>>>> in the new Live-demo
>>>> Please cnsider these as still in draft format, so that required changes
>>>> can be done in the next future.
>>>> Best,
>>>> Maxi
>>>> 2015-12-19 3:36 GMT+01:00 Cameron Shorter <cameron.shorter at gmail.com> <
>>>> cameron.shorter at gmail.com>:
>>>> Hi Massimiliano and Milan,
>>>> If I look at the istSOS OpenHub metrics, it suggests that 95% of the
>>>> code is javascript, however the project summary notes the project is
>>>> written in Python.
>>>> Would I be right in suspecting that your OpenHub entry is not accurately
>>>> pointing at your source code?
>>>> If so, could you please update OpenHub such that the metrics are more
>>>> accurate.
>>>> We encourage people to assess the quality of a project by looking at
>>>> Open Hub metrics [2]
>>>> [1] https://www.openhub.net/p/istsos
>>>> [2] http://live.osgeo.org/en/metrics.html
>>>> On 18/12/2015 8:33 am, Cameron Shorter wrote:
>>>> Seems my last email was too big for the email list, here is the trimmed
>>>> version:
>>>> On 18/12/2015 8:18 am, Cameron Shorter wrote:
>>>> Hi Massimiliano,
>>>> We discussed including istSOS on OSGeo-Live in our weekly meeting today,
>>>> and all present were in favour of it being included. So welcome to the
>>>> OSGeo-Live community.
>>>> Could you please focus first on working out your install process so that
>>>> we can get istSOS into OSGeo-Live builds and start testing it.
>>>> Then start working on the Project Overview and Quickstart.
>>>> Could you also please start an email thread suggesting what dataset(s)
>>>> should be used for istSOS.
>>>> I suspect that your dataset needs would be similar to 52 North SOS?
>>>> There may be other datasets on OSGeo-Live which might be of use too?
>>>> Ideally we'd like to ensure we use the same datasets across applications
>>>> On 17/12/2015 7:52 pm, Massimiliano Cannata wrote:
>>>> Dear Cameron, sear OSGeo-live team,
>>>> here below you can find the istSOS application ofr being included in
>>>> the next OSGeo live release.
>>>> Cameron Shorter,
>>>> Software and Data Solutions Manager
>>>> LISAsoft
>>>> Suite 112, Jones Bay Wharf,
>>>> 26 - 32 Pirrama Rd, Pyrmont NSW 2009
>>>> P +61 2 9009 5000,  W www.lisasoft.com,  F +61 2 9009 5099
>>>> Cameron Shorter,
>>>> LISAsoft
>>>> *Massimiliano Cannata*
>>>> Professore SUPSI in ingegneria Geomatica
>>>> Responsabile settore Geomatica
>>>> Istituto scienze della Terra
>>>> Dipartimento ambiente costruzione e design
>>>> Scuola universitaria professionale della Svizzera italiana
>>>> Campus Trevano, CH - 6952 Canobbio
>>>> Tel. +41 (0)58 666 62 14
>>>> Fax +41 (0)58 666 62 09
>>>> <massimiliano.cannata at supsi.ch> <massimiliano.cannata at supsi.ch>
>>>> *www.supsi.ch/ist <http://www.supsi.ch/ist> <http://www.supsi.ch/ist>*
>>>> Cameron Shorter,
>>>> LISAsoft
>>>> _______________________________________________
>>>> Live-demo mailing listLive-demo at lists.osgeo.orghttp://
>>>> lists.osgeo.org/mailman/listinfo/live-demohttp://live.osgeo.orghttp://wiki.osgeo.org/wiki/Live_GIS_Disc
>>>> Angelos Tzotsos, PhD
>>>> OSGeo Charter Memberhttp://users.ntua.gr/tzotsos
>> http://lists.osgeo.org/mailman/listinfo/live-demo
> Cameron Shorter,
> LISAsoft
Cameron Shorter,
LISAsoft
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20160129/d9728e90/attachment.html>
More information about the Live-demo
