[Live-demo] PyWPS application
Fenoy Gerald gerald.fenoy at geolabs.fr
Fri May 13 05:56:30 PDT 2016
Hi all,
I would like also to add that WPS servers have multiple kind of interfaces to interact with.
The most common and (probably) the most used is the QGIS application which is, thanks to a specific plugin, able to interact with WPS servers.
Obviously, it makes obsolete some part of QGIS or some of the services available as they are overlapping in capabilities.
I think it may be great to write a short documentation on how to use pyWPS through this plugin to take advantages of the great PyWPS implementation.
I am very supportive that OSGeoLive contains pyWPS. To be frank, I am a lot surprised that it is not already available, I should have taken a better look.
Best regards,
> Le 13 mai 2016 à 13:29, Tom Kralidis <tomkralidis at gmail.com> a écrit :
> Hi Cameron: thanks for the info.  Comments:
> - PyWPS does not require test data as part of its install.  If anything we will
> use the data already shipped with OSGeo Live
> - GUI: we can put together a simple request/response GUI (like pycsw) as
> an initial iteration
> Thanks
> ..Tom
> On Fri, May 13, 2016 at 7:25 AM, Cameron Shorter
> <cameron.shorter at gmail.com> wrote:
>> Tom,
>> Based on your description below, it seems like pyWPS would be a good
>> addition to OSGeo-Live.
>> A few questions/comments:
>> * I'm not sure that you completed question about using OSGeo-Live existing
>> datasets? What are your thoughts there?
>> * It appears there is no GUI interface to the WPS? The lack of a GUI makes
>> pyWPS appear less polished and I suspect will limit potential uses. You
>> could start with a HTML web page which provides template WPS queries and
>> displays the response. You might want to look at the GeoServer web interface
>> for inspiration.
>> I think PyWPS could still be included on OSGeo-Live without the GUI, but I
>> suggest aiming to put a GUI in place before completing OSGeo Incubation.
>> I'm +1 for inviting PyWPS to join OSGeo-Live.
>> Warm regards, Cameron
>> On 13/05/2016 8:18 pm, Tom Kralidis wrote:
>>> Hi all: below is the application for PyWPS for inclusion into OSGeo Live.
>>> If
>>> it helps, the below can also be found at [1].
>>> If you have any questions or comments, feel free to contact me.
>>> Thanks
>>> ..Tom
>>> [1] https://github.com/geopython/pywps/wiki/OSGeoLiveApplication
>>> Please describe your application.
>>> What is its name? PyWPS
>>> What is the home page URL? http://pywps.org
>>> Which OSI approved Open Source Licence is used? GPL for PyWPS 3.x.
>>> Note that PyWPS 4 (in development) is a rewrite and will be available
>>> under MIT
>>> What does the application do and how does it add value to the
>>> GeoSpatial stack of software? PyWPS provides an OGC WPS server
>>> implementation written in Python. PyWPS allows for processes to be
>>> exposed, discovered and executed in support of geospatial workflows
>>> Does the application make use of OGC standards? Which versions of the
>>> standards? Client or server? You may wish to add comments about how
>>> standards are used. PyWPS implements OGC WPS 1.0.0 (2.0.0 in
>>> development)
>>> What language is it written in? Python
>>> Which version of the application should be included in the next
>>> OSGeo-Live release? 3.2.5
>>> Stability is very important to us on OSGeo-Live. If a new user finds a
>>> bug in one application, it will tarnish the reputation of all other
>>> OSGeo-Live applications as well. (We pay most attention to the
>>> following answers):
>>> If risk adverse organisations have deployed your application into
>>> production, it would imply that these organisations have verified the
>>> stability of your software. Has the application been rolled out to
>>> production into risk (ideally risk adverse) organisations? Please
>>> mention some of these organisations? The Meteorological Service of
>>> Canada, the WMO WOUDC project, Department of Earth Observation at the
>>> Friedrich-Schiller University Jena (Germany), International Union of
>>> Soil Sciences, NASA (JPL), UNEP/GRID, Luxembourg Institute of Science
>>> and Technology (LIST)
>>> Open HUB provides metrics to help assess the health of a project. Eg:
>>> http://adhoc.osgeo.osuosl.org/livedvd/docs/en/metrics.html Could you
>>> please ensure that your project is registered with Open HUB, and Open
>>> HUB has been updated to reference the correct code repository(s) for
>>> your project. What is the Open HUB URL for your project?
>>> https://www.openhub.net/p/PyWPS
>>> What is the size of the user community? You can often answer this by
>>> mentioning downloads, or describing a healthy, busy email list? In
>>> 2016 the PyWPS mailing list received 250 messages, averaging almost 2
>>> messages per day. So far, 17 different individuals have subscribed the
>>> contribution agreement. The pywps-3 repository has been forked 43
>>> times and the pywps-4 repository has 17 forks.
>>> What is the size of your developer community (5-6 core developers)
>>> Do you have a bug free, stable release? yes
>>> Please discuss the level of testing that your project has gone
>>> through. PyWPS has regression testing. Bugs/issues are managed via
>>> GitHub and triaged accordingly
>>> How long has the project has had mature code. Started in 2006, PyWPS
>>> has had stable releases since 2008 with PyWPS 3.0.0
>>> OSGeo-Live is targeted at applications that people can use rather than
>>> libraries. Does the application have a user interface (possibly a
>>> command line interface) that a user can interact with? (We do make an
>>> exception for Incubated OSGeo Libraries, and will include Project
>>> Overviews for these libraries, even if they don't have a user
>>> interface.). PyWPS is configurable via the command line and
>>> configuration files. PyWPS does not have a graphical user interface
>>> We give preference to OSGeo Incubated Projects, or Projects which are
>>> presented at FOSS4G conferences. If your project is involved in OSGeo
>>> Incubation, or has been selected to be presented at FOSS4G, then
>>> please mention it. PyWPS is currently working through the OSGeo
>>> incubation process
>>> With around 50 applications installed on OSGeo-Live, us core packagers
>>> do not have the time to liaise with every single project email list
>>> for each OSGeo-Live release. So we require a volunteer (or two) to
>>> take responsibility for liaising between OSGeo-Live and the project's
>>> communities. This volunteer will be responsible for ensuring the
>>> install scripts and English documentation are updated by someone for
>>> each OSGeo-Live release. Also test that the installed application and
>>> Quickstart documentation works as expected on release candidate
>>> releases of OSGeo-Live. Who will act as the project's liaison person.
>>> Tom Kralidis
>>> OSGeo-Live is Ubuntu Linux based. Our installation preference is:
>>> Install from UbuntuGIS or DebianGIS Install .deb files from a PPA or
>>> Write a custom install script. Can you please discuss how your
>>> application will be installed. via UbuntuGIS and install script with
>>> configuration
>>> OSGeo-Live is memory and disk constrained. Can the application run in
>>> 512 Meg of RAM? Yes
>>> How much disk space will be required to install the application and a
>>> suitable example application? ~ 250KB
>>> We aim to reduce disk space by having all applications make use of a
>>> common dataset. We encourage applications to make use of the example
>>> datasets already installed:
>>> http://wiki.osgeo.org/wiki/Live_GIS_Add_Project#Example_Datasets If
>>> another dataset would be more appropriate, please discuss here. Is it
>>> appropriate, to remove existing demo datasets which may already be
>>> included in the standard release.
>>> Each OSGeo-Live application requires a Project Overview available
>>> under a CC By and a Quickstart available under a CC By-SA license.
>>> (You may release under a second license as well). Will you produce
>>> this? Yes
>>> In past releases, we have included Windows and Mac installers for some
>>> applications. It is likely we won't have space for these in future
>>> releases. However, if there is room, would you be wishing to include
>>> Windows and/or Mac installers? Yes, this is feasible given the very
>>> nature of Python
>>> Live-demo mailing list
>>> Live-demo at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/live-demo
>>> http://live.osgeo.org
>>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
>> Cameron Shorter,
>> Software and Data Solutions Manager
>> LISAsoft
>> Suite 112, Jones Bay Wharf,
>> 26 - 32 Pirrama Rd, Pyrmont NSW 2009
>> P +61 2 9009 5000,  W www.lisasoft.com,  F +61 2 9009 5099
Gérald Fenoy
http://wiki.osgeo.org/wiki/User:Djay
More information about the Live-demo mailing list
