[Live-demo] PyWPS application
Cameron Shorter
cameron.shorter at gmail.com
Fri May 13 13:42:32 PDT 2016
Hi Fenoy,
It sounds like the pyWPS Quickstart should be based on a qgis use case?
Maybe you might be well qualified to help writing the quickstart?
Warm regards, Cameron
On 13/05/2016 10:56 pm, Fenoy Gerald wrote:
> Hi all,
> I would like also to add that WPS servers have multiple kind of interfaces to interact with.
> The most common and (probably) the most used is the QGIS application which is, thanks to a specific plugin, able to interact with WPS servers.
> Obviously, it makes obsolete some part of QGIS or some of the services available as they are overlapping in capabilities.
> I think it may be great to write a short documentation on how to use pyWPS through this plugin to take advantages of the great PyWPS implementation.
> I am very supportive that OSGeoLive contains pyWPS. To be frank, I am a lot surprised that it is not already available, I should have taken a better look.
> Best regards,
>> Le 13 mai 2016 à 13:29, Tom Kralidis <tomkralidis at gmail.com> a écrit :
>> Hi Cameron: thanks for the info. Comments:
>> - PyWPS does not require test data as part of its install. If anything we will
>> use the data already shipped with OSGeo Live
>> - GUI: we can put together a simple request/response GUI (like pycsw) as
>> an initial iteration
>> Thanks
>> ..Tom
>> On Fri, May 13, 2016 at 7:25 AM, Cameron Shorter
>> <cameron.shorter at gmail.com> wrote:
>>> Tom,
>>> Based on your description below, it seems like pyWPS would be a good
>>> addition to OSGeo-Live.
>>> A few questions/comments:
>>> * I'm not sure that you completed question about using OSGeo-Live existing
>>> datasets? What are your thoughts there?
>>> * It appears there is no GUI interface to the WPS? The lack of a GUI makes
>>> pyWPS appear less polished and I suspect will limit potential uses. You
>>> could start with a HTML web page which provides template WPS queries and
>>> displays the response. You might want to look at the GeoServer web interface
>>> for inspiration.
>>> I think PyWPS could still be included on OSGeo-Live without the GUI, but I
>>> suggest aiming to put a GUI in place before completing OSGeo Incubation.
>>> I'm +1 for inviting PyWPS to join OSGeo-Live.
>>> On 13/05/2016 8:18 pm, Tom Kralidis wrote:
>>>> Hi all: below is the application for PyWPS for inclusion into OSGeo Live.
>>>> If
>>>> it helps, the below can also be found at [1].
>>>> If you have any questions or comments, feel free to contact me.
>>>> Thanks
>>>> ..Tom
>>>> [1] https://github.com/geopython/pywps/wiki/OSGeoLiveApplication
>>>> Please describe your application.
>>>> What is its name? PyWPS
>>>> What is the home page URL? http://pywps.org
>>>> Which OSI approved Open Source Licence is used? GPL for PyWPS 3.x.
>>>> Note that PyWPS 4 (in development) is a rewrite and will be available
>>>> under MIT
>>>> What does the application do and how does it add value to the
>>>> GeoSpatial stack of software? PyWPS provides an OGC WPS server
>>>> implementation written in Python. PyWPS allows for processes to be
>>>> exposed, discovered and executed in support of geospatial workflows
>>>> Does the application make use of OGC standards? Which versions of the
>>>> standards? Client or server? You may wish to add comments about how
>>>> standards are used. PyWPS implements OGC WPS 1.0.0 (2.0.0 in
>>>> development)
>>>> What language is it written in? Python
>>>> Which version of the application should be included in the next
>>>> OSGeo-Live release? 3.2.5
>>>> Stability is very important to us on OSGeo-Live. If a new user finds a
>>>> bug in one application, it will tarnish the reputation of all other
>>>> OSGeo-Live applications as well. (We pay most attention to the
>>>> following answers):
>>>> If risk adverse organisations have deployed your application into
>>>> production, it would imply that these organisations have verified the
>>>> stability of your software. Has the application been rolled out to
>>>> production into risk (ideally risk adverse) organisations? Please
>>>> mention some of these organisations? The Meteorological Service of
>>>> Canada, the WMO WOUDC project, Department of Earth Observation at the
>>>> Friedrich-Schiller University Jena (Germany), International Union of
>>>> Soil Sciences, NASA (JPL), UNEP/GRID, Luxembourg Institute of Science
>>>> and Technology (LIST)
>>>> Open HUB provides metrics to help assess the health of a project. Eg:
>>>> http://adhoc.osgeo.osuosl.org/livedvd/docs/en/metrics.html Could you
>>>> please ensure that your project is registered with Open HUB, and Open
>>>> HUB has been updated to reference the correct code repository(s) for
>>>> your project. What is the Open HUB URL for your project?
>>>> https://www.openhub.net/p/PyWPS
>>>> What is the size of the user community? You can often answer this by
>>>> mentioning downloads, or describing a healthy, busy email list? In
>>>> 2016 the PyWPS mailing list received 250 messages, averaging almost 2
>>>> messages per day. So far, 17 different individuals have subscribed the
>>>> contribution agreement. The pywps-3 repository has been forked 43
>>>> times and the pywps-4 repository has 17 forks.
>>>> What is the size of your developer community (5-6 core developers)
>>>> Do you have a bug free, stable release? yes
>>>> Please discuss the level of testing that your project has gone
>>>> through. PyWPS has regression testing. Bugs/issues are managed via
>>>> GitHub and triaged accordingly
>>>> How long has the project has had mature code. Started in 2006, PyWPS
>>>> has had stable releases since 2008 with PyWPS 3.0.0
>>>> OSGeo-Live is targeted at applications that people can use rather than
>>>> libraries. Does the application have a user interface (possibly a
>>>> command line interface) that a user can interact with? (We do make an
>>>> exception for Incubated OSGeo Libraries, and will include Project
>>>> Overviews for these libraries, even if they don't have a user
>>>> interface.). PyWPS is configurable via the command line and
>>>> configuration files. PyWPS does not have a graphical user interface
>>>> We give preference to OSGeo Incubated Projects, or Projects which are
>>>> presented at FOSS4G conferences. If your project is involved in OSGeo
>>>> Incubation, or has been selected to be presented at FOSS4G, then
>>>> please mention it. PyWPS is currently working through the OSGeo
>>>> incubation process
>>>> With around 50 applications installed on OSGeo-Live, us core packagers
>>>> do not have the time to liaise with every single project email list
>>>> for each OSGeo-Live release. So we require a volunteer (or two) to
>>>> take responsibility for liaising between OSGeo-Live and the project's
>>>> communities. This volunteer will be responsible for ensuring the
>>>> install scripts and English documentation are updated by someone for
>>>> each OSGeo-Live release. Also test that the installed application and
>>>> Quickstart documentation works as expected on release candidate
>>>> releases of OSGeo-Live. Who will act as the project's liaison person.
>>>> Tom Kralidis
>>>> OSGeo-Live is Ubuntu Linux based. Our installation preference is:
>>>> Install from UbuntuGIS or DebianGIS Install .deb files from a PPA or
>>>> Write a custom install script. Can you please discuss how your
>>>> application will be installed. via UbuntuGIS and install script with
>>>> configuration
>>>> OSGeo-Live is memory and disk constrained. Can the application run in
>>>> 512 Meg of RAM? Yes
>>>> How much disk space will be required to install the application and a
>>>> suitable example application? ~ 250KB
>>>> We aim to reduce disk space by having all applications make use of a
>>>> common dataset. We encourage applications to make use of the example
>>>> datasets already installed:
>>>> http://wiki.osgeo.org/wiki/Live_GIS_Add_Project#Example_Datasets If
>>>> another dataset would be more appropriate, please discuss here. Is it
>>>> appropriate, to remove existing demo datasets which may already be
>>>> included in the standard release.
>>>> Each OSGeo-Live application requires a Project Overview available
>>>> under a CC By and a Quickstart available under a CC By-SA license.
>>>> (You may release under a second license as well). Will you produce
>>>> this? Yes
>>>> In past releases, we have included Windows and Mac installers for some
>>>> applications. It is likely we won't have space for these in future
>>>> releases. However, if there is room, would you be wishing to include
>>>> Windows and/or Mac installers? Yes, this is feasible given the very
>>>> nature of Python
>>>> _______________________________________________
>>>> Live-demo mailing list
>>>> Live-demo at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/live-demo
>>>> http://live.osgeo.org
>>>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
>>> Cameron Shorter,
>>> Software and Data Solutions Manager
>>> LISAsoft
>>> Suite 112, Jones Bay Wharf,
>>> 26 - 32 Pirrama Rd, Pyrmont NSW 2009
>>> P +61 2 9009 5000, W www.lisasoft.com, F +61 2 9009 5099
> Gérald Fenoy
> http://wiki.osgeo.org/wiki/User:Djay
Cameron Shorter,
LISAsoft
More information about the Live-demo
