[Live-demo] [OSGeo] #1850: ZOO-Project-1.6.0
OSGeo trac_osgeo at osgeo.org
Sun Jan 22 23:53:29 PST 2017
 Reporter:  djay     |       Owner:  live-demo@…
     Type:  defect   |      Status:  new
 Priority:  major    |   Milestone:  OSGeoLive10.5
Component:  LiveDVD  |  Resolution:
 Keywords:           |
Comment (by djay):
 Report about the setup made on osgeo-live-nightly-
 build42-amd64-bae0e1c.iso .
 It looks like almost everything is here. But some things are not in the
 right place, the first that makes the OTB demo failing, is that there are
 2 main.cfg files, one located in {{{/etc/zoo-project}}} which contains
 only the minimal setup and one in {{{/usr/lib/cgi-bin}}} that contains all
 the correct settings required to get the demos working properly. So simply
 moving the correct {{{main.cfg}}} to {{{/usr/lib/cgi-bin}}} solves this
 issue.
 Once the issue with main.cfg is solved, the MapServer WMS generated by the
 OTB demo still not displaying. Indeed, it search for a {{{symbols.sym}}}
 file in the dataPath directory, so in the {{{/var/lib/zoo-project}}}
 directory. This file should be created and the owner of this directory
 should be set to {{{www-data}}} as it should be writable by the apache
 user.
 Once this two steps has been completed, everything works properly.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1850#comment:8>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
