[Live-demo] [OSGeo] #1850: ZOO-Project-1.6.0
OSGeo trac_osgeo at osgeo.org
Mon Jan 23 00:47:29 PST 2017
 Reporter:  djay     |       Owner:  live-demo@…
     Type:  defect   |      Status:  new
 Priority:  major    |   Milestone:  OSGeoLive10.5
Component:  LiveDVD  |  Resolution:
 Keywords:           |
Comment (by djay):
 Replying to [comment:7 sebastic]:
 > Replying to [comment:1 sebastic]:
 > > The path to `libjvm.so` differs depending on which JRE is installed
 and which JDK zoo-project was built with, so adding a `ld.so.conf` snippet
 is not a good solution. I'm not sure what the proper solution for JNI
 bindings is.
 > Setting RPATH like GDAL may be good enough, see:
 >  https://trac.osgeo.org/gdal/browser/tags/2.1.2/gdal/configure.in#L4661
 Thanks, from [http://zoo-project.org/trac/changeset/809 r809], you can now
 use the --with-java-rpath=yes option to set the RPATH like in GDAL.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1850#comment:9>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
