[Live-demo] how to easily create a live Disc with only some of the projects
Angelos Tzotsos
gcpp.kalxas at gmail.com
Tue Jan 24 11:21:43 PST 2017
Dear Karsten,
You can start by using the source code for OSGeoLive:
https://github.com/OSGeo/OSGeoLive
Specifically, you can disable projects in here:
https://github.com/OSGeo/OSGeoLive/blob/master/bin/inchroot.sh#L122-L213
and try to build an iso to fit your needs.
You can add your own installers, your own customizations etc.
Best,
Angelos
On Sun, Jan 22, 2017 at 11:49 PM, karsten <karsten at terragis.net> wrote:
> Dear All,
> I am in the process of creating a live Disk (aka USB stick) for a project
> called the "Tanzania Food and Land Productivity Information System" - see
> a online version of this here http://transsec2.terragis.net/Welcome.html .
> The system is nearly finished ( and uses MapServer, PostGIS, GDAL,
> OpenLayers 2 etc) under the hood. We would like to publish as an ISO image
> to have bootable USB sticks available for teaching and scientific purposes.
> No I have tried to cerate my own bootable system via setting up an Ubuntu
> and tried to cerate an ISO image form there but have run in a lot of issues
> (the first resulting ISO created via systemback failed to boot into the GUI
> but only command line, and a later botched attempt setting up a Xubuntu
> server on a local laptop, where all worked except the MapServer version
> could not easily be installed) .
> Thus, I wanted to reach out for advice what is the easiest way to get a
> bootable system iso created including my project (open to use Ubuntu for
> Xubuntu or the like as a base) .
> One alternative to my recent approach - I guess - would be to use the live
> disk as a base , install that to a local machine, then uninstall all that
> is not needed, and then use the Systemback application to create a iso ?
> Cheers
> Karsten
> Karsten Vennemann
> Principal
> Terra GIS LTD
> 2119 Boyer Ave E
> Seattle, WA 98112
> USA
> www.terragis.net
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Angelos Tzotsos, PhD
OSGeo Charter Member
http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20170124/11732221/attachment.html>
More information about the Live-demo
