[Live-demo] how to easily create a live Disc with only some of the projects
karsten
karsten at terragis.net
Fri Jan 27 13:58:08 PST 2017
Hi Angelos,
great I will try to follow the documentation there.
Is there anywhere noted which tool is used to create the final iso image ?
Thanks a lot
Karsten
_____
From: Angelos Tzotsos [mailto:gcpp.kalxas at gmail.com]
Sent: Tuesday, January 24, 2017 11:22
To: karsten at terragis.net
Cc: live-demo at lists.osgeo.org
Subject: Re: [Live-demo] how to easily create a live Disc with only some of
the projects
Dear Karsten,
You can start by using the source code for OSGeoLive:
https://github.com/OSGeo/ <https://github.com/OSGeo/OSGeoLive> OSGeoLive
Specifically, you can disable projects in here:
<https://github.com/OSGeo/OSGeoLive/blob/master/bin/inchroot.sh#L122-L213>
and try to build an iso to fit your needs.
You can add your own installers, your own customizations etc.
Best,
Angelos
On Sun, Jan 22, 2017 at 11:49 PM, karsten <karsten at terragis.net> wrote:
Dear All,
I am in the process of creating a live Disk (aka USB stick) for a project
called the "Tanzania Food and Land Productivity Information System" - see a
online version of this here http://transsec2.terragis.net/
<http://transsec2.terragis.net/Welcome.html> Welcome.html . The system is
nearly finished ( and uses MapServer, PostGIS, GDAL, OpenLayers 2 etc) under
the hood. We would like to publish as an ISO image to have bootable USB
sticks available for teaching and scientific purposes.
No I have tried to cerate my own bootable system via setting up an Ubuntu
and tried to cerate an ISO image form there but have run in a lot of issues
(the first resulting ISO created via systemback failed to boot into the GUI
but only command line, and a later botched attempt setting up a Xubuntu
server on a local laptop, where all worked except the MapServer version
could not easily be installed) .
Thus, I wanted to reach out for advice what is the easiest way to get a
bootable system iso created including my project (open to use Ubuntu for
Xubuntu or the like as a base) .
One alternative to my recent approach - I guess - would be to use the live
disk as a base , install that to a local machine, then uninstall all that is
not needed, and then use the Systemback application to create a iso ?
Cheers
Karsten
Karsten Vennemann
Principal
Terra GIS LTD
2119 Boyer Ave E
Seattle, WA 98112
USA
<http://www.terragis.net/> www.terragis.net
Live-demo mailing list
Live-demo at lists.osgeo.org
https://lists.osgeo.org/
<https://lists.osgeo.org/mailman/listinfo/live-demo>
http://live.osgeo.org
http://wiki.osgeo.org/wiki/ <http://wiki.osgeo.org/wiki/Live_GIS_Disc>
Live_GIS_Disc
Angelos Tzotsos, PhD
OSGeo Charter Member
http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20170127/983af546/attachment.html>
More information about the Live-demo
