[Live-demo] Transifex update
    Thomas Gratier
    osgeo.mailinglist at gmail.com
    Tue Jan 24 14:52:29 PST 2017
To easily go back and forth between Github and Transifex, you need  to use
the Transifex client utility e;g https://docs.transifex.com/client/set
Look at the steps the MapServer project does using it
http://mapserver.org/development/documentation.html#the-usual-workflow-for-already-existing-translation
Cheers
Thomas Gratier
2017-01-15 22:13 GMT+01:00 Cameron Shorter <cameron.shorter at gmail.com>:
> Nicholas,
> Sounds like you are making steady progress. Well done.
> Re getting duplicate images, we had a similar problem with the sphinx
> build process, and created a work around by creating symbolic links post
> build. Hopefully there is a smarter option with transifex.
> The large size of the HTML might be indicative of verbose HTML being
> created. I wonder whether transifex has a "compress" option, or
> alternatively we could run a compress option over created html afterwards.
> Warm regards, Cameron
> On 14/1/17 7:59 am, Baka Niko wrote:
> Hi everyone,
> Jakob send me the link to a recording about
>  internationalization (i18n), it is 24 min lenght and might interest
> people who want to get involved in the translation process. So thanks Jakob
> https://www.youtube.com/watch?v=Nz8zutA55fI
> During the second viewing, i downloaded the osgeolie docs from github to
> get a fresh start.
> In the Docs, i added or changed some lines:
>    import sys, os
>    # needed to avoid an ascii error during the build of the translations
>    reload(sys)
>    sys.setdefaultencoding('utf-8')
>  # General information about the project.
> project = u'OSGeo-Live'
> copyright = u'OSGeo-Live Contributors'
> # The short X.Y version.
> version = '10.5'
> # The full version, including alpha/beta/rc tags.
> release =  '10.5 alpha'
> # The language for content autogenerated by Sphinx. Refer to documentation
> # for a list of supported languages.
> language = 'en'
> # where do the translation go (should be changed ? or the html index
> changed ?)
> locale_dirs = ['locale/']
> # gettext compact mode (one folder by language)
> gettext_compact = True
> Then I used the following commands:
> tx init # folder initialisation (transifex client is needed)
> sphinx-intl update-txconfig-resources --pot-dir _build/locale
> --transifex-project-name osgeolive
> # configure the project ?
> tx pull -l fr # french translation pulling
> sphinx-intl build # translation building
> make SPHINXOPTS="-Dlanguage=fr" html # html pages building
> The last command lauched the building of ALL the languages which have a
> folder in the main folder.
> The _build folder now contains all the html files from the docs and is
> more than 1 GB.
> Even the images folder get fatter, passing from 854 files (103 MB) to
> 1602 (197 MB) when becoming _images and some images gets a copy (but not
> all).
> I tried to deleted language folders, but the only ones that where built
> are the 'en' and 'id' that i left. I expected at least that the french one
> will be downloaded since i requested it.
> So there is some progress but not enough yet. Any help or suggestion is
> welcomed.
> Sorry for the long mail,
> Best wishes,
> Nicolas
> 2017-01-08 20:18 GMT+01:00 Angelos Tzotsos <gcpp.kalxas at gmail.com>:
>> Hi Jakob,
>> Thank you for the update, good work!
>> It would be great to be able to push current translations automatically,
>> but I am afraid not all of them were up to date, so it might not be
>> straightforward.
>> Regarding the Mac and Window installer folders, those used to be
>> placeholders to actually link to folders with installers during our iso
>> build process. The installers have been removed since our 10.0 release, so
>> those folders are not needed anymore.
>> Best,
>> Angelos
>> On 01/08/2017 03:11 PM, Jakob Miksch wrote:
>>> Dear list,
>>> a short update regarding the move to Transifex.
>>> I managed push all English source files to Transifex. I solved the
>>> problem (that I mentioned in the last chat) by "hard-coding" the
>>> version number in the conf.py file. Before it was read automatically.
>>> This apparently caused some problems. https://github.com/OSGeo/OSGeoLiv
>>> e-doc/blob/master/conf.py#L26
>>> The next step is to push all existing translations to Transifex. Would
>>> be cool to do that automatically as well ...
>>> This is our Transifex repository: https://www.transifex.com/osgeo/osgeo
>>> live/dashboard/
>>> And here we can discuss about this topic: https://wiki.osgeo.org/wiki/T
>>> alk:Live_GIS_Translate
>>> Now, I am thinking about our folder structure. The folder structure
>>> from this project "QField" looks quite clean and nice: https://github.c
>>> om/opengisch/QField-docs
>>> I do not understand the purpose of these two folders in our repository:
>>> "MacInstallers" (https://github.com/OSGeo/OSGeoLive-doc/tree/master/Mac
>>> Installers) and "WindowsInstallers" (https://github.com/OSGeo/OSGeoLive
>>> -doc/tree/master/WindowsInstallers)
>>> They only link to the documentation within the language folders.
>>> Why do we need these two folders?
>>> Best wishes,
>>> Jakob
>>>   _______________________________________________
>>> Live-demo mailing list
>>> Live-demo at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/live-demo
>>> http://live.osgeo.org
>>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
>> Angelos Tzotsos, PhD
>> OSGeo Charter Member
>> http://users.ntua.gr/tzotsos
> Live-demo mailing listLive-demo at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/live-demohttp://live.osgeo.orghttp://wiki.osgeo.org/wiki/Live_GIS_Disc
> Cameron Shorter
> M +61 419 142 254 <+61%20419%20142%20254>
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20170124/5f29cacb/attachment.html>
More information about the Live-demo
