[Live-demo] MOTION: Migrate OSGeo-Live issues to another Trac instance
Cameron Shorter
cameron.shorter at gmail.com
Thu Oct 12 14:37:44 PDT 2017
+0. I'm tentitively in favour of migrating to a better track system, but
would fist like to be comfortable with:
* What new tracker will we use and will it integrate with our current
workflow?
* Can we migrate old issues?
* Can we exit from the new system if we need to (as per Ben's comments)?
Cameron
On 13/10/17 8:09 am, Even Rouault wrote:
> On vendredi 13 octobre 2017 10:02:29 CEST Ben Caradoc-Davies wrote:
> > We control our trac instances. Even before comparing features, is there
> > any mechanism for migrating issues from GitHub to another system should
> > we need to do so? I am still smarting from the Codehaus shutdown and its
> > impact on GeoTools and GeoServer.
> Ben,
> Never tried it but gitlab has apparently an import module (rather
> expected given they directly compete):
> https://docs.gitlab.com/ce/user/project/import/github.html
> There are also ways to backup github tickets through their REST API
> with gitthub-backup (which I tried)
> For example:
> 1) pip install github-backup
> 2) in github UI, create a personnal access token, so as to be able to
> use authenticated
> requests to github API, to bypass the rate limit of unauthenticated
> requests (you can use it even for repositories that you don't own)
> 3) github-backup -i -R python-github-backup josegonzalez --issues
> --issue-comments --issue-events --pulls --pull-comments --pull-commits
> -t ${your_github_token}
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20171013/04708c0d/attachment-0001.html>
More information about the Live-demo
