[Live-demo] MOTION: Migrate OSGeo-Live issues to another Trac instance
Vicky Vergara
vicky at georepublic.de
Thu Oct 12 14:59:24 PDT 2017
+1
On Thu, Oct 12, 2017 at 4:37 PM, Cameron Shorter <cameron.shorter at gmail.com>
wrote:
> +0. I'm tentitively in favour of migrating to a better track system, but
> would fist like to be comfortable with:
> * What new tracker will we use and will it integrate with our current
> workflow?
> * Can we migrate old issues?
> * Can we exit from the new system if we need to (as per Ben's comments)?
> Cameron
> On 13/10/17 8:09 am, Even Rouault wrote:
> On vendredi 13 octobre 2017 10:02:29 CEST Ben Caradoc-Davies wrote:
> > We control our trac instances. Even before comparing features, is there
> > any mechanism for migrating issues from GitHub to another system should
> > we need to do so? I am still smarting from the Codehaus shutdown and its
> > impact on GeoTools and GeoServer.
> Ben,
> Never tried it but gitlab has apparently an import module (rather expected
> given they directly compete):
> https://docs.gitlab.com/ce/user/project/import/github.html
> There are also ways to backup github tickets through their REST API with
> gitthub-backup (which I tried)
> For example:
> 1) pip install github-backup
> 2) in github UI, create a personnal access token, so as to be able to use
> authenticated
> requests to github API, to bypass the rate limit of unauthenticated
> requests (you can use it even for repositories that you don't own)
> 3) github-backup -i -R python-github-backup josegonzalez --issues
> --issue-comments --issue-events --pulls --pull-comments --pull-commits -t
> ${your_github_token}
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> Live-demo mailing listLive-demo at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/live-demohttp://live.osgeo.orghttp://wiki.osgeo.org/wiki/Live_GIS_Disc
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky at georepublic.de
Web: https://georepublic.info
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20171012/84792803/attachment.html>
More information about the Live-demo
