MapGuide-Users PHP/IIS vs .NET/IIS
Jason Birch
Jason.Birch at nanaimo.ca
Mon Feb 13 14:38:41 EST 2006
I had success running the initial web extensions installation for .Net,
and then going into Add/Remove Programs and modifying the installation
to add the PHP extensions as well. Doing it the other way didn't work;
I think there was a problem with the .Net assemblies not registering
properly or something like that...
Andy notes some problems with doing this in this document:
http://www.spatialgis.com/MSE_Install_Tips.pdf
(Web Extensions - Only Install One Flavor!)
Make sure that you have .Net 2.0 installed before running the setup or
you may need to uninstall and reinstall web extensions to get it to work
again.
Jason
-----Original Message-----
From: Randy Glen Johnson [mailto:rjohnson at maintenanceconnection.com]
Sent: Monday, February 13, 2006 11:29
To: mse-users at mail.osgeo.org
Subject: RE: MapGuide-Users PHP/IIS vs .NET/IIS
Do I just run the webextension setup twice - once for each?
Best Regards,
Randy Glen Johnson
Programmer Analyst
Maintenance Connection, Inc.
1-888-567-3434 ext 800
http://www.maintenanceconnection.com
Sent: Monday, February 13, 2006 11:24 AM
Subject: Re: MapGuide-Users PHP/IIS vs .NET/IIS
On Mon, 13 Feb 2006 10:22:49 -0800, Randy Glen Johnson
<rjohnson at maintenanceconnection.com> wrote:
> I want to know if I can run BOTH PHP and .NET with IIS - at the same
> time? Or is that a bad idea? What advantages or disadvantages are
> there for each (php and .net)?
Sure you can. We've got several machines running these together, and
we've even set up a laptop that used those plus ColdFusion, Apache and
Tomcat -- all on the same machine (I don't recommend that one though).
I'm not aware of any particular advantages; disadvantages would
primarily be the added load on the server of the additional processes.
James Card
California CAD Solutions, Inc.
209 578-5580 Voice
209 521-6493 FAX
To unsubscribe, e-mail: mse-users-unsubscribe at mail.osgeo.org
For additional commands, e-mail: mse-users-help at mail.osgeo.org
More information about the Mail_mse-users
