[Context.RWG] Using OWS Context to describe GML/WFS layers whichdecimate
Kralidis,Tom [Burlington] Tom.Kralidis at ec.gc.ca
Tue Oct 31 21:50:20 EST 2006
> -----Original Message-----
> From: Cameron Shorter [mailto:cameron.shorter at gmail.com]
> Sent: 31 October, 2006 7:17 PM
> To: Kralidis,Tom [Burlington]
> Cc: Martin Daly; context.rwg at opengeospatial.org;
> webmap-discuss at mail.osgeo.org; Raj Singh
> Subject: Re: [Context.RWG] Using OWS Context to describe
> Kralidis,Tom [Burlington] wrote:
> > Cameron,
> > So you want one OWSContext FeatureType to hold many GML documents?
> > If yes, can you not define each GML doc as an OWSContext
> FeatureType,
> > each with respective scale rules?
> Tom,
> Using Style scale rules to make a layer visible or not would
> be one solution - but with a number of limitations:
> 1. If I were to build a LayerList (or Legend) from the
> Context, would I end up with a layer for each scale?
Yes, however you could build your client Legend handler to show layers
only if they're within the scale range of where the application scale is
at.
> 2. If my legend was smart, and layers were only visible at
> certain resolutions, how do I associate a HighResolutionLayer
> with a LowResolutionLayer so that the Layer attributes (like
> visibility) can be associated between layers.
If OWSContext identified the notion of a @group attribute as part of the
AbstractResourceType, this might be an option.  There has been some mild
discussion on this front.
> >>Sent: 30 October, 2006 7:29 PM
> >>To: Martin Daly
> >>Cc: context.rwg at opengeospatial.org; Kralidis,Tom [Burlington];
> >>Subject: Re: [Context.RWG] Using OWS Context to describe GML/WFS
> >>Martin,
> >>Point taken regarding G/Y/M maps. Replace zoomLevel with
> >>sld:Min/MaxScaleDenominator in my previous comment.
> >>I still need to reference different GML sources for each layer
> >>depending on scale, which doesn't seem to be covered by OWS Context
> >>yet.
> >>Martin Daly wrote:
> >>>>zoomLevel is a term used by Google/Yahoo/MSN Maps.
> >>>>It is a measure of resolution. As you zoom out, the zoomLevel
> >>>>increases.
> >>>That is not a definition that will wash in a standard that
> aims for
> >>>interoperability.
> >>>In fact, OWS Context already uses
> sld:Min/MaxScaleDenominator in the
> >>>AbstractResourceType, so the capability already exists.
> >>>As with the previous long e-mail trail re. GYM data, this
> >>spec. should
> >>>leverage de jure OGC standards, not de facto ones that
> >>large parts of
> >>>the target audience cannot use.
> >>>M
> >>Cameron Shorter
> >>http://cameron.shorter.net
> Cameron Shorter
More information about the Mail_webmap-discuss mailing list
