svn commit: r47 - trunk/mapbender/http/classes/class_gmlMember.php
uli at osgeo.org
uli at osgeo.org
Thu Apr 13 16:58:31 EDT 2006
Author: uli
Date: 2006-04-13 20:58:30+0000
New Revision: 47
Added:
import Mapbender source without history
Added: trunk/mapbender/http/classes/class_gmlMember.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_gmlMember.php?view=auto&rev=47
--- (empty file)
+++ trunk/mapbender/http/classes/class_gmlMember.php 2006-04-13 20:58:30+0000
@@ -0,0 +1,175 @@
+<?php
+# $Id: class_gmlMember.php,v 1.7 2005/09/13 16:23:31 c_baudson Exp $
+# $Header: /cvsroot/mapbender/mapbender/http/classes/class_gmlMember.php,v 1.7 2005/09/13 16:23:31 c_baudson Exp $
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+class gmlMember {
+ var $cnt_item;
+ var $memberType;
+ var $attributes = array();
+ var $geometry = array();
+ function gmlMember ($type) {
+ $this->cnt_item = -1;
+ $this->setMemberType($type);
+ function setAttribute($attribTag, $attrib) {
+ $this->attributes[$attribTag] = $attrib;
+ function setMemberType($type) {
+ $this->memberType = $type;
+ function addPolygon () {
+ $this->cnt_item++;
+ $this->geometry[$this->cnt_item] = new _polygon();
+ function addLine () {
+ $this->geometry[$this->cnt_item] = new _line();
+ function addPoint () {
+ $this->geometry[$this->cnt_item] = new _point();
+# function addCoordinates ($coord, $pos) {
+# $this->geometry[$this->cnt_item]->addCoordinates($coord, $pos);
+ function addCoordinates ($coord) {
+ $this->geometry[$this->cnt_item]->addCoordinates($coord);
+ function addLabel($label) {
+ $this->geometry[$this->cnt_item]->setLabel($label);
+ function addToPng($image, $bbox, $width, $height, $line, $text, $label) {
+ $pos = array();
+ $pos_next = array();
+ for ($j=0; $j < count($this->geometry); $j++) {
+ $coord = $this->geometry[$j]->getCoordinates();
+ if ($this->geometry[$j]->getType() == "point") {
+ $topOffset = imagefontheight(2);
+ $pos = $this->makeRealWorld2mapPos($bbox, $width, $height, $coord["x"][0],$coord["y"][0]);
+ imagestring ($image, 2,$pos["x"], ($pos["y"] - $topOffset), $this->getAttribute($label), $text);
+ imageellipse($image, $pos["x"], $pos["y"], 5, 5, $line);
+ else {
+ for($k=0; $k < count($coord["x"])-1; $k++){
+ $pos = $this->makeRealWorld2mapPos($bbox, $width, $height, $coord["x"][$k],$coord["y"][$k]);
+ $pos_next = $this->makeRealWorld2mapPos($bbox, $width, $height, $coord["x"][$k+1],$coord["y"][$k+1]);
+ imageline($image,$pos["x"],$pos["y"],$pos_next["x"],$pos_next["y"],$line);
+ return $image;
+ function getAllGeom() {
+ return $this->geometry;
+ function getAllAttributes() {
+ return $this->attributes;
+ function getAllAttributeKeys() {
+ return array_keys($this->attributes);
+ function getAttribute($name) {
+ if (array_key_exists($name, $this->attributes)) {
+ return $this->attributes["$name"];
+ else {
+ return "";
+ function getGeomObj($index) {
+ return $this->geometry[$index];
+ function getMemberType() {
+ return $this->memberType;
+ function getMemberSize() {
+ return count($this->geometry);
+ function getGeomSize($i) {
+ return count($this->geometry[$i]);
+ function getJavaObjStr($bbox, $width, $height) {
+ $str = "";
+ $str .= "register_D('" . $this->geometry[$j]->getType() . "');";
+ if ($this->geometry[$j]->getType() == "point" && $this->geometry[$j]->getLabel()) {
+ $str .= "D[D.length-1].label = '" . $this->geometry[$j]->getLabel() . "';";
+ for($k=0; $k < count($coord["x"]); $k++){
+ $pos = $this->makeRealWorld2mapPos($bbox, $width, $height,$coord["x"][$k],$coord["y"][$k]);
+ $str .= "D[D.length-1].x[D[D.length-1].x.length] = Math.round(" . $coord["x"][$k] . " * 100)/100;";
+ $str .= "D[D.length-1].y[D[D.length-1].y.length] = Math.round(" . $coord["y"][$k] . " * 100)/100;";
+ $str .= "D[D.length-1].complete = true;";
+ return $str;
+ function makeRealWorld2mapPos($bbox, $width, $height, $x,$y){
+ $minx = $bbox[0];
+ $miny = $bbox[1];
+ $maxx = $bbox[2];
+ $maxy = $bbox[3];
+ $xtentx = $maxx - $minx;
+ $xtenty = $maxy - $miny;
+ if ($xtenty != 0 && $xtentx != 0) {
+ $posx = (($x - $minx) / $xtentx) * $width;
+ $posy = (($maxy - $y) / $xtenty) * $height;
+ $pos = array("x" => $posx, "y" => $posy);
+ return $pos;
+ if ($xtenty == 0 || $xtentx == 0) {
+ $mb_exception = new mb_exception("Division by zero in makeRealWorld2mapPos");
+ return 0;
\ No newline at end of file
More information about the Mapbender_commits
