svn commit: r48 - trunk/mapbender/http/classes/class_gml2.php
uli at osgeo.org
uli at osgeo.org
Thu Apr 13 16:58:56 EDT 2006
Author: uli
Date: 2006-04-13 20:58:56+0000
New Revision: 48
Added:
import Mapbender source without history
Added: trunk/mapbender/http/classes/class_gml2.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_gml2.php?view=auto&rev=48
--- (empty file)
+++ trunk/mapbender/http/classes/class_gml2.php 2006-04-13 20:58:56+0000
@@ -0,0 +1,134 @@
+<?php
+# $Id: class_gml2.php,v 1.5 2006/03/22 16:34:15 uli_rothstein Exp $
+# $Header: /cvsroot/mapbender/mapbender/http/classes/class_gml2.php,v 1.5 2006/03/22 16:34:15 uli_rothstein Exp $
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once("class_mb_exception.php");
+require_once("class_connector.php");
+require_once("../../conf/mapbender.conf");
+class gml2{
+ var $geometries = array('Point', 'Polygon', 'LineString', 'MultiPolygon', 'MultiLineString');
+ var $member = -1;
+ var $geomtype = array();
+ var $keys = array();
+ var $values = array();
+ var $geometry = array();
+ function gml2(){
+ function parsegml($req){
+ #$data = implode("",file($req));
+ $x = new connector($req);
+ $data = $this->char_encode($x->file);
+ $this->parse_xml($data);
+ function parsestring($req){
+ $data = $req;
+ function parse_xml($data){
+ $section = false;
+ $geom = false;
+ $el = -1;
+ $parser = xml_parser_create(CHARSET);
+ xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
+ xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
+ xml_parser_set_option($parser,XML_OPTION_TARGET_ENCODING,CHARSET);
+ xml_parse_into_struct($parser,$data,$values,$tags);
+ $code = xml_get_error_code ($parser);
+ if ($code) {
+ $line = xml_get_current_line_number($parser);
+ $mb_exception = new mb_exception(xml_error_string($code) . " in line " . $line);
+ xml_parser_free($parser);
+ foreach ($values as $element) {
+ if(strtoupper($element[tag]) == strtoupper("gml:featureMember") && $element[type] == "open"){
+ $this->member++;
+ $this->keys[$this->member] = array();
+ $this->value[$this->member] = array();
+ $this->geometry[$this->member] = array();
+ $section = true;
+ $cnt_geom = 0;
+ if($section == true){
+ if( in_array($this->sepNameSpace($element[tag]),$this->geometries) && $element[type] == "open"){
+ $geom = true;
+ $this->geomtype[$this->member] = $this->sepNameSpace($element[tag]);
+ else if(strtoupper($element[tag]) == strtoupper("gml:coordinates") && $geom == true){
+ $this->geometry[$this->member][$cnt_geom] = str_replace(",,","",str_replace(" ",",",trim($element[value])));
+ else if(in_array($this->sepNameSpace($element[tag]),$this->geometries) && $element[type] == "close"){
+ $cnt_geom++;
+ $geom = false;
+ else if(strtoupper($element[tag]) == strtoupper("gml:featureMember") && $element[type] == "close"){
+ $section = false;
+ $el = -1;
+ else{
+ $el++;
+ $this->values[$this->member][$el] = $element[value];
+ $this->keys[$this->member][$el] = $element[tag];
+ function sepNameSpace($s){
+ $c = strpos($s,":");
+ if($c>0){
+ return substr($s,$c+1);
+ else{
+ return $s;
+ function getMemberCount(){
+ return ($this->member+1);
+ function getValueBySeparatedKey($memberCount,$keyName){
+ for($i=0; $i<count($this->keys[$memberCount]); $i++){
+ if($this->sepNameSpace($this->keys[$memberCount][$i]) == $keyName){
+ return $this->values[$memberCount][$i];
+ function getValueByKey($memberCount,$keyName){
+ if($this->keys[$memberCount][$i] == $keyName){
+ function getGeometriesFromMember($memberCount){
+ return $this->geometry[$memberCount];
+ function getGeometryTypeFromMember($memberCount){
+ return $this->geomtype[$memberCount];
+ function char_encode($s){
+ if(CHARSET == 'UTF-8'){
+ $s = utf8_encode($s);
+ return $s;
\ No newline at end of file
More information about the Mapbender_commits
