svn commit: r98 - trunk/mapbender/http/php/mod_addWmsFromFeatureInfo.php
christoph at osgeo.org
Wed Apr 19 09:41:24 EDT 2006
Author: christoph
Date: 2006-04-19 13:41:23+0000
New Revision: 98
Added:
Added: trunk/mapbender/http/php/mod_addWmsFromFeatureInfo.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/php/mod_addWmsFromFeatureInfo.php?view=auto&rev=98
--- (empty file)
+++ trunk/mapbender/http/php/mod_addWmsFromFeatureInfo.php 2006-04-19 13:41:23+0000
@@ -0,0 +1,80 @@
+<?php
+# $Id: mod_evalArea.php,v 1.13 2006/03/20 11:47:37 astrid_emde Exp $
+# $Header: /cvsroot/mapbender/mapbender/http/php/mod_evalArea.php,v 1.13 2006/03/20 11:47:37 astrid_emde Exp $
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+import_request_variables("PG");
+require_once("../php/mb_validateSession.php");
+require_once("../../conf/mapbender.conf");
+$con = db_connect($DBSERVER,$OWNER,$PW);
+db_select_db(DB,$con);
+$gui_id = $_SESSION["mb_user_gui"];
+$e_id_css = 'addWmsFromFeatureInfo';
+include('../include/dyn_js.php');
+$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = '" . $e_id_css . "' AND fkey_gui_id = '".$gui_id."'";
+ $res = db_query($sql);
+ $cnt = 0;
+ while($row = db_fetch_array($res)){
+ $e_src = $row["e_src"];
+ $e_target = explode(",",$row["e_target"]);
+ $cnt++;
+ if($cnt > 1){ echo "alert('digitize_button: ID not unique!');";}
+ echo "var mod_target = '".$e_target[0]."';";
+function addWmsFromFeatureInfo(pointer_name, version) {
+ mb_registerloadWmsSubFunctions("addWmsFromInfo_pos()");
+ var mywms = pointer_name;
+ if(mywms.indexOf("?") > -1){pointer_name += "&";}
+ if(mywms.indexOf("?") == -1){pointer_name += "?";}
+ if (version == '1.0.0')
+ var cap = pointer_name + "REQUEST=capabilities&WMTVER=1.0.0";
+ var load = cap;
+ else if (version == '1.1.0')
+ var cap = pointer_name + "REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.0";
+ var load = cap;
+ else if (version == '1.1.1')
+ var cap = pointer_name + "REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1";
+ var load = cap;
+ if(load)
+ //if the mapfile WMS ONLINE RESOURCE is set relative, without any host
+ if(load.charAt(0) == '/' && load.charAt(1) == 'c') {
+ mod_addWMS_load('http://localhost' + load);
+ else {
+ mod_addWMS_load(load);
+function addWmsFromInfo_pos(){
+ mb_wmsMoveByIndex(getMapObjIndexByName(mod_target), mb_mapObj[getMapObjIndexByName(mod_target)].wms.length-1, mod_addWmsFromFeatureInfo_position);
+ mb_removeFunctionFromArray("mb_loadWmsSubFunctions", "addWmsFromInfo_pos()");
More information about the Mapbender_commits
