svn commit: r99 - trunk/mapbender/http/javascripts/mod_back.php
arnulf at osgeo.org
arnulf at osgeo.org
Wed Apr 19 09:41:33 EDT 2006
Author: arnulf
Date: 2006-04-19 13:41:32+0000
New Revision: 99
code cleaned, added prepared statements
Modified: trunk/mapbender/http/javascripts/mod_back.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_back.php?view=diff&rev=99&p1=trunk/mapbender/http/javascripts/mod_back.php&p2=trunk/mapbender/http/javascripts/mod_back.php&r1=98&r2=99
--- trunk/mapbender/http/javascripts/mod_back.php (original)
+++ trunk/mapbender/http/javascripts/mod_back.php 2006-04-19 13:41:32+0000
@@ -1,6 +1,6 @@
<?php
-#$Id: mod_back.php,v 1.9 2005/09/13 18:16:42 bjoern_heuser Exp $
-#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_back.php,v 1.9 2005/09/13 18:16:42 bjoern_heuser Exp $
+# $Id$
+# http://www.mapbender.org/index.php/Back
# Copyright (C) 2002 CCGIS
# This program is free software; you can redistribute it and/or modify
@@ -17,18 +17,19 @@
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
$gui_id = $_REQUEST["gui_id"];
require_once("../../conf/mapbender.conf");
$con = db_connect($DBSERVER,$OWNER,$PW);
db_select_db(DB,$con);
-$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'back' AND fkey_gui_id = '".$gui_id."'";
-$res = db_query($sql);
+$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'back' AND fkey_gui_id = $1 ";
+$v = array($gui_id);
+$t = array('i');
+$res = db_prep_query($sql, $v, $t);
$cnt = 0;
while($row = db_fetch_array($res)){
- $e_src = $row["e_src"];
- $e_target = split(",",$row["e_target"]);
- $cnt++;
+ $e_src = $row["e_src"];
+ $e_target = split(",",$row["e_target"]);
+ $cnt++;
if($cnt > 1){ echo "alert('back: ID not unique!');";}
echo "var mod_back_map = '".$e_target[0]."';";
@@ -46,81 +47,80 @@
mb_registerSubFunctions("mod_back_check(frameName)");
function mod_back_check(frameName){
- if(frameName == mod_back_map){
- mod_back_cnt++;
- //alert(mod_back_cnt);
- if(mb_MapHistoryObj[mod_back_map].length > 1){
- document.getElementById("back").src = mod_back_img_off.src;
- else{
- document.getElementById("back").src = mod_back_img_off_disabled.src;
- mod_back_img_previous = document.getElementById("back").src;
+ if(frameName == mod_back_map){
+ mod_back_cnt++;
+ if(mb_MapHistoryObj[mod_back_map].length > 1){
+ document.getElementById("back").src = mod_back_img_off.src;
+ else{
+ document.getElementById("back").src = mod_back_img_off_disabled.src;
+ mod_back_img_previous = document.getElementById("back").src;
function mod_back_over(obj){
- if(document.getElementById("back").src == mod_back_img_off.src){
- document.getElementById("back").src = mod_back_img_over.src;
+ if(document.getElementById("back").src == mod_back_img_off.src){
+ document.getElementById("back").src = mod_back_img_over.src;
function mod_back_out(obj){
- document.getElementById("back").src = mod_back_img_previous;
+ document.getElementById("back").src = mod_back_img_previous;
function mod_back_set(){
- if(mod_back_img_previous == mod_back_img_off.src){
- //FutureObj
- if(mb_MapFutureObj){
- mb_setFutureObj(mod_back_map);
- var ind = getMapObjIndexByName(mod_back_map);
- var cnt = mb_MapHistoryObj[mod_back_map].length - 2;
- if(mb_mapObj[ind].epsg != mb_MapHistoryObj[mod_back_map][cnt].epsg){
- var oind = getMapObjIndexByName(mod_back_overview);
- for(var i=0; i<mb_MapHistoryObj[mod_back_overview].length; i++){
- if(mb_MapHistoryObj[mod_back_overview][i].epsg == mb_MapHistoryObj[mod_back_map][cnt].epsg){
- mb_mapObj[oind].epsg = mb_MapHistoryObj[mod_back_overview][i].epsg;
- mb_mapObj[oind].extent = mb_MapHistoryObj[mod_back_overview][i].extent;
- setMapRequest(mod_back_overview);
- break;
- document.getElementById(mod_back_map).style.width = mb_MapHistoryObj[mod_back_map][cnt].width;
- document.getElementById(mod_back_map).style.height = mb_MapHistoryObj[mod_back_map][cnt].height;
- mb_mapObj[ind].width = mb_MapHistoryObj[mod_back_map][cnt].width;
- mb_mapObj[ind].height = mb_MapHistoryObj[mod_back_map][cnt].height;
- mb_mapObj[ind].epsg = mb_MapHistoryObj[mod_back_map][cnt].epsg;
- mb_mapObj[ind].extent = mb_MapHistoryObj[mod_back_map][cnt].extent;
- mb_mapObj[ind].layers = mb_MapHistoryObj[mod_back_map][cnt].layers;
- mb_mapObj[ind].styles = mb_MapHistoryObj[mod_back_map][cnt].styles;
- mb_mapObj[ind].querylayers = mb_MapHistoryObj[mod_back_map][cnt].querylayers;
- mb_MapHistoryObj[mod_back_map].length = (mb_MapHistoryObj[mod_back_map].length - 2);
- setMapRequest(mod_back_map);
+ if(mod_back_img_previous == mod_back_img_off.src){
+ if(mb_MapFutureObj){
+ mb_setFutureObj(mod_back_map);
+ var ind = getMapObjIndexByName(mod_back_map);
+ var cnt = mb_MapHistoryObj[mod_back_map].length - 2;
+ if(mb_mapObj[ind].epsg != mb_MapHistoryObj[mod_back_map][cnt].epsg){
+ var oind = getMapObjIndexByName(mod_back_overview);
+ for(var i=0; i < mb_MapHistoryObj[mod_back_overview].length; i++){
+ if(mb_MapHistoryObj[mod_back_overview][i].epsg == mb_MapHistoryObj[mod_back_map][cnt].epsg){
+ mb_mapObj[oind].epsg = mb_MapHistoryObj[mod_back_overview][i].epsg;
+ mb_mapObj[oind].extent = mb_MapHistoryObj[mod_back_overview][i].extent;
+ setMapRequest(mod_back_overview);
+ break;
+ document.getElementById(mod_back_map).style.width = mb_MapHistoryObj[mod_back_map][cnt].width;
+ document.getElementById(mod_back_map).style.height = mb_MapHistoryObj[mod_back_map][cnt].height;
+ mb_mapObj[ind].width = mb_MapHistoryObj[mod_back_map][cnt].width;
+ mb_mapObj[ind].height = mb_MapHistoryObj[mod_back_map][cnt].height;
+ mb_mapObj[ind].epsg = mb_MapHistoryObj[mod_back_map][cnt].epsg;
+ mb_mapObj[ind].extent = mb_MapHistoryObj[mod_back_map][cnt].extent;
+ mb_mapObj[ind].layers = mb_MapHistoryObj[mod_back_map][cnt].layers;
+ mb_mapObj[ind].styles = mb_MapHistoryObj[mod_back_map][cnt].styles;
+ mb_mapObj[ind].querylayers = mb_MapHistoryObj[mod_back_map][cnt].querylayers;
+ mb_MapHistoryObj[mod_back_map].length = (mb_MapHistoryObj[mod_back_map].length - 2);
+ setMapRequest(mod_back_map);
function mb_setHistoryObj(frameName){
- if(mb_MapHistoryObj[frameName] == null){
- mb_MapHistoryObj[frameName] = new Array();
- var ind = getMapObjIndexByName(frameName);
- var cnt = mb_MapHistoryObj[frameName].length;
- mb_MapHistoryObj[frameName][cnt] = new Object();
- mb_MapHistoryObj[frameName][cnt].width = mb_mapObj[ind].width;
- mb_MapHistoryObj[frameName][cnt].height = mb_mapObj[ind].height;
- mb_MapHistoryObj[frameName][cnt].epsg = mb_mapObj[ind].epsg;
- mb_MapHistoryObj[frameName][cnt].extent = mb_mapObj[ind].extent;
- mb_MapHistoryObj[frameName][cnt].layers = new Array();
- for(var i=0; i<mb_mapObj[ind].layers.length;i++){
- mb_MapHistoryObj[frameName][cnt].layers[i] = mb_mapObj[ind].layers[i];
- mb_MapHistoryObj[frameName][cnt].styles = new Array();
- for(var i=0; i<mb_mapObj[ind].styles.length;i++){
- mb_MapHistoryObj[frameName][cnt].styles[i] = mb_mapObj[ind].styles[i];
- mb_MapHistoryObj[frameName][cnt].querylayers = new Array();
- for(var i=0; i<mb_mapObj[ind].querylayers.length;i++){
- mb_MapHistoryObj[frameName][cnt].querylayers[i] = mb_mapObj[ind].querylayers[i];
+ if(mb_MapHistoryObj[frameName] == null){
+ mb_MapHistoryObj[frameName] = new Array();
+ var ind = getMapObjIndexByName(frameName);
+ var cnt = mb_MapHistoryObj[frameName].length;
+ mb_MapHistoryObj[frameName][cnt] = new Object();
+ mb_MapHistoryObj[frameName][cnt].width = mb_mapObj[ind].width;
+ mb_MapHistoryObj[frameName][cnt].height = mb_mapObj[ind].height;
+ mb_MapHistoryObj[frameName][cnt].epsg = mb_mapObj[ind].epsg;
+ mb_MapHistoryObj[frameName][cnt].extent = mb_mapObj[ind].extent;
+ mb_MapHistoryObj[frameName][cnt].layers = new Array();
+ for(var i=0; i<mb_mapObj[ind].layers.length;i++){
+ mb_MapHistoryObj[frameName][cnt].layers[i] = mb_mapObj[ind].layers[i];
+ mb_MapHistoryObj[frameName][cnt].styles = new Array();
+ for(var i=0; i<mb_mapObj[ind].styles.length;i++){
+ mb_MapHistoryObj[frameName][cnt].styles[i] = mb_mapObj[ind].styles[i];
+ mb_MapHistoryObj[frameName][cnt].querylayers = new Array();
+ for(var i=0; i<mb_mapObj[ind].querylayers.length;i++){
+ mb_MapHistoryObj[frameName][cnt].querylayers[i] = mb_mapObj[ind].querylayers[i];
More information about the Mapbender_commits
