svn commit: r100 - trunk/mapbender/http/javascripts/mod_back.php
arnulf at osgeo.org arnulf at osgeo.org
Wed Apr 19 10:24:54 EDT 2006
Author: arnulf
Date: 2006-04-19 14:24:54+0000
New Revision: 100
   trunk/mapbender/http/javascripts/mod_back.php   (contents, props changed)
corrected var type, added SVN header keyword
Modified: trunk/mapbender/http/javascripts/mod_back.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_back.php?view=diff&rev=100&p1=trunk/mapbender/http/javascripts/mod_back.php&p2=trunk/mapbender/http/javascripts/mod_back.php&r1=99&r2=100
--- trunk/mapbender/http/javascripts/mod_back.php	(original)
+++ trunk/mapbender/http/javascripts/mod_back.php	2006-04-19 14:24:54+0000
@@ -23,7 +23,7 @@
 db_select_db(DB,$con);
 $sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'back' AND fkey_gui_id = $1 ";
 $v = array($gui_id);
-$t = array('i');
+$t = array('s');
 $res = db_prep_query($sql, $v, $t);
 $cnt = 0;
 while($row = db_fetch_array($res)){
More information about the Mapbender_commits mailing list
