svn commit: r205 - trunk/mapbender/http/javascripts/mod_key.php
vera_schulze at osgeo.org
Mon May 8 10:53:31 EDT 2006
Author: vera_schulze
Date: 2006-05-08 14:53:31+0000
New Revision: 205
trunk/mapbender/http/javascripts/mod_key.php (contents, props changed)
Code cleaning ready, 2 dp_prep_query
Modified: trunk/mapbender/http/javascripts/mod_key.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_key.php?view=diff&rev=205&p1=trunk/mapbender/http/javascripts/mod_key.php&p2=trunk/mapbender/http/javascripts/mod_key.php&r1=204&r2=205
--- trunk/mapbender/http/javascripts/mod_key.php (original)
+++ trunk/mapbender/http/javascripts/mod_key.php 2006-05-08 14:53:31+0000
@@ -1,39 +1,61 @@
<?php
-#$Id: mod_key.php,v 1.8 2005/09/13 18:16:42 bjoern_heuser Exp $
-#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_key.php,v 1.8 2005/09/13 18:16:42 bjoern_heuser Exp $
+# $Id$
+# http://www.mapbender.org/index.php/mod_key.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
require_once("../../conf/mapbender.conf");
$gui_id = $_REQUEST["gui_id"];
$con = db_connect($DBSERVER,$OWNER,$PW);
db_select_db(DB,$con);
-$sql = "SELECT e_target FROM gui_element WHERE e_id = 'keyHandler' AND fkey_gui_id = '".$gui_id."'";
-$res = db_query($sql);
+$sql = "SELECT e_target FROM gui_element WHERE e_id = 'keyHandler' AND fkey_gui_id = $1";
+$v = array($gui_id);
+$t = array('s');
+$res = db_prep_query($sql, $v, $t);
$cnt = 0;
while($row = db_fetch_array($res)){
- $e_target = $row["e_target"];
- $cnt++;
+ $e_target = $row["e_target"];
+ $cnt++;
if($cnt > 1){ echo "alert('keyHandler: ID not unique!');";}
echo "var mod_key_map = '".$e_target."';";
-$sql = "SELECT e_id,e_element FROM gui_element WHERE (e_element = 'body' or e_element = 'iframe') AND fkey_gui_id = '".$gui_id."' AND e_public = 1";
+$sql = "SELECT e_id,e_element FROM gui_element WHERE (e_element = 'body' or e_element = 'iframe') AND fkey_gui_id = $1 AND e_public = 1";
+$t = array('s');
$cnt = 0;
- $ids[$cnt] = $row["e_id"];
- $elements[$cnt] = $row["e_element"];
- $cnt++;
+ $ids[$cnt] = $row["e_id"];
+ $elements[$cnt] = $row["e_element"];
+ $cnt++;
echo "var mb_key_elements = new Array(";
for($i=0; $i < count($elements); $i++){
- if($i > 0){ echo ",";}
- echo "'".$elements[$i]."'";
+ if($i > 0){
+ echo ",";
+ echo "'".$elements[$i]."'";
echo ");";
echo "var mb_key_ids = new Array(";
for($i=0; $i < count($ids); $i++){
- echo "'".$ids[$i]."'";
+ if($i > 0){ echo ",";}
+ echo "'".$ids[$i]."'";
echo ");";
@@ -41,28 +63,42 @@
mb_registerInitFunctions('mod_key_init()');
function mod_key_init(){
- for(var i=0; i<mb_key_elements.length; i++){
- if(mb_key_elements[i] == "body"){
- document.getElementById(mb_key_ids[i]).onkeydown = mod_key_Keyhandler;
- else{
- window.frames[mb_key_ids[i]].document.getElementsByTagName("body")[0].onkeydown = new Function("mod_key_Keyhandler('" +mb_key_ids[i] + "');");
+ for(var i=0; i<mb_key_elements.length; i++){
+ if(mb_key_elements[i] == "body"){
+ document.getElementById(mb_key_ids[i]).onkeydown = mod_key_Keyhandler;
+ else{
+ window.frames[mb_key_ids[i]].document.getElementsByTagName("body")[0].onkeydown = new Function("mod_key_Keyhandler('" +mb_key_ids[i] + "');");
function mod_key_Keyhandler(frameName){
- if(frameName){
- var code = eval("window.frames['"+frameName+"'].event.keyCode");
- focus();
- else{
- var code = event.keyCode;
- if(code == 187 || code == 107){ zoom(mod_key_map,true, '2.0'); }
- if(code == 189 || code == 109){ zoom(mod_key_map,false, '2.0');}
- if(code == 32 || code == 13){setMapRequest(mod_key_map);}
- if(code == 37){mb_panMap(mod_key_map,"W");}
- if(code == 38){mb_panMap(mod_key_map,"N");}
- if(code == 39){mb_panMap(mod_key_map,"E");}
- if(code == 40){mb_panMap(mod_key_map,"S");}
+ if(frameName){
+ var code = eval("window.frames['"+frameName+"'].event.keyCode");
+ focus();
+ else{
+ var code = event.keyCode;
+ if(code == 187 || code == 107){
+ zoom(mod_key_map,true, '2.0');
+ if(code == 189 || code == 109){
+ zoom(mod_key_map,false, '2.0');
+ if(code == 32 || code == 13){
+ setMapRequest(mod_key_map);
+ if(code == 37){
+ mb_panMap(mod_key_map,"W");
+ if(code == 38){
+ mb_panMap(mod_key_map,"N");
+ if(code == 39){
+ mb_panMap(mod_key_map,"E");
+ if(code == 40){
+ mb_panMap(mod_key_map,"S");
More information about the Mapbender_commits
