svn commit: r206 - trunk/mapbender/http/javascripts/mod_legend_tab.php
vera_schulze at osgeo.org
Mon May 8 11:02:31 EDT 2006
Author: vera_schulze
Date: 2006-05-08 15:02:31+0000
New Revision: 206
trunk/mapbender/http/javascripts/mod_legend_tab.php (contents, props changed)
Code cleaning, some comments left, 2 db_prep_query
Modified: trunk/mapbender/http/javascripts/mod_legend_tab.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_legend_tab.php?view=diff&rev=206&p1=trunk/mapbender/http/javascripts/mod_legend_tab.php&p2=trunk/mapbender/http/javascripts/mod_legend_tab.php&r1=205&r2=206
--- trunk/mapbender/http/javascripts/mod_legend_tab.php (original)
+++ trunk/mapbender/http/javascripts/mod_legend_tab.php 2006-05-08 15:02:31+0000
@@ -1,6 +1,6 @@
<?php
-#$Id: mod_legend_tab.php,v 1.13 2006/03/09 08:54:41 uli_rothstein Exp $
-#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_legend_tab.php,v 1.13 2006/03/09 08:54:41 uli_rothstein Exp $
+# $Id$
+# http://www.mapbender.org/index.php/mod_legend_tab.php
# Copyright (C) 2002 CCGIS
# This program is free software; you can redistribute it and/or modify
@@ -38,8 +38,10 @@
$con = db_connect($DBSERVER,$OWNER,$PW);
db_select_db(DB,$con);
-$sql = "SELECT e_target, e_width, e_height FROM gui_element WHERE e_id = 'legend' AND fkey_gui_id = '".$gui_id."'";
-$res = db_query($sql);
+$sql = "SELECT e_target, e_width, e_height FROM gui_element WHERE e_id = 'legend' AND fkey_gui_id = $1";
+$v = array($gui_id);
+$t = array('s');
+$res = db_prep_query($sql, $v, $t);
$cnt = 0;
while($row = db_fetch_array($res)){
$e_target = $row["e_target"];
@@ -47,8 +49,10 @@
if($cnt > 1){ echo "alert('legend: ID not unique!');";}
#target position, with and height...
-$sql = "SELECT e_left,e_top,e_width,e_height FROM gui_element WHERE e_id = '".$e_target."' AND fkey_gui_id = '".$gui_id."'";
+$sql = "SELECT e_left,e_top,e_width,e_height FROM gui_element WHERE e_id = '".$e_target."' AND fkey_gui_id = $1";
+$t = array('s');
echo "<script type='text/javascript'>";
echo "var mod_legend_target = '".$e_target."';";
@@ -66,56 +70,54 @@
parent.mb_registerSubFunctions("window.frames['legend'].mod_legend_pos()");
function mod_legend_init(){
- var obj = parent.document.getElementById("legend");
- /*obj.style.top = mod_legend_target_top + mod_legend_offsetTop;*/
- /*obj.style.left = mod_legend_target_left + mod_legend_target_width + mod_legend_offsetLeft;*/
+ var obj = parent.document.getElementById("legend");
+ /*obj.style.top = mod_legend_target_top + mod_legend_offsetTop;*/
+ /*obj.style.left = mod_legend_target_left + mod_legend_target_width + mod_legend_offsetLeft;*/
function mod_legend_repaint(obj){
-// if(obj.checked == true){
- mod_legend_pos();
+ // if(obj.checked == true){
+ mod_legend_pos();
function mod_legend_pos(){
- var ind = parent.getMapObjIndexByName(mod_legend_target);
- /*obj.style.left = parseInt(parent.mb_mapObj[ind].width) + mod_legend_target_left + mod_legend_offsetLeft;*/
- /*if(document.forms[0].sw.checked == false){
- parent.writeTag("legend", "leg", "");
- return true;
+ var ind = parent.getMapObjIndexByName(mod_legend_target);
+ /*obj.style.left = parseInt(parent.mb_mapObj[ind].width) + mod_legend_target_left + mod_legend_offsetLeft;*/
+ /*if(document.forms[0].sw.checked == false){
+ parent.writeTag("legend", "leg", "");
+ return true;
var layers;
- var str = "";
- for(var i=0; i<parent.mb_mapObj[ind].wms.length; i++){
- if(parent.mb_mapObj[ind].wms[i].wms_getlegendurl != ""){
- //header
- layers = parent.mb_checkScale(mod_legend_target,ind,i);
- if(layers[0] != ""){
- str += "<span class='header'>" +parent.mb_mapObj[ind].wms[i].wms_title+ "</span>";
+ var str = "";
+ for(var i=0; i<parent.mb_mapObj[ind].wms.length; i++){
+ if(parent.mb_mapObj[ind].wms[i].wms_getlegendurl != ""){
+ //header
+ layers = parent.mb_checkScale(mod_legend_target,ind,i);
+ if(layers[0] != ""){
+ str += "<span class='header'>" +parent.mb_mapObj[ind].wms[i].wms_title+ "</span>";
- var layer = layers[0].split(",");
- var titles = layers[2].split(",");
- for(var j=0; j<layer.length; j++){
- str += "<div><span class='titles'>" +titles[j]+ "</span></div>";
- str += "<div><img src = '";
- str += parent.mb_mapObj[ind].wms[i].wms_getlegendurl + "&format=image/png&REQUEST=getlegendgraphic&VERSION=1.1.1&SERVICE=WMS&layer=";
- str += layer[j];
- str += "'></div>";
- } str += "<br>";
- if(str != ""){
- parent.writeTag("legend", "leg", str);
- else{
- return true;
+ var layer = layers[0].split(",");
+ var titles = layers[2].split(",");
+ for(var j=0; j<layer.length; j++){
+ str += "<div><span class='titles'>" +titles[j]+ "</span></div>";
+ str += "<div><img src = '";
+ str += parent.mb_mapObj[ind].wms[i].wms_getlegendurl + "&format=image/png&REQUEST=getlegendgraphic&VERSION=1.1.1&SERVICE=WMS&layer=";
+ str += layer[j];
+ str += "'></div>";
+ str += "<br>";
+ if(str != ""){
+ parent.writeTag("legend", "leg", str);
+ else{
+ return true;
@@ -124,7 +126,8 @@
</head>
<body onload='mod_legend_init()'>
<form>
-<!--<span class='switch'>Legende ON/OFF<input type='checkbox' name='sw' checked='true' onclick='mod_legend_repaint(this)'>
+<span class='switch'>Legende ON/OFF<input type='checkbox' name='sw' checked='true' onclick='mod_legend_repaint(this)'>
</span>
</form>
More information about the Mapbender_commits
