svn commit: r275 - trunk/mapbender/http/javascripts/mod_scaleHint.php
vera_schulze at osgeo.org
Mon May 15 05:11:00 EDT 2006
Author: vera_schulze
Date: 2006-05-15 09:11:00+0000
New Revision: 275
trunk/mapbender/http/javascripts/mod_scaleHint.php (contents, props changed)
Code cleaning ready
Modified: trunk/mapbender/http/javascripts/mod_scaleHint.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_scaleHint.php?view=diff&rev=275&p1=trunk/mapbender/http/javascripts/mod_scaleHint.php&p2=trunk/mapbender/http/javascripts/mod_scaleHint.php&r1=274&r2=275
--- trunk/mapbender/http/javascripts/mod_scaleHint.php (original)
+++ trunk/mapbender/http/javascripts/mod_scaleHint.php 2006-05-15 09:11:00+0000
@@ -1,6 +1,6 @@
<?php
-#$Id: mod_scaleHint.php,v 1.9 2005/09/13 18:16:42 bjoern_heuser Exp $
-#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_scaleHint.php,v 1.9 2005/09/13 18:16:42 bjoern_heuser Exp $
+# $Id$
+# http://www.mapbender.org/index.php/mod_scaleHint.php
# Copyright (C) 2002 CCGIS
# This program is free software; you can redistribute it and/or modify
@@ -22,14 +22,18 @@
require_once("../../conf/mapbender.conf");
$con = db_connect($DBSERVER,$OWNER,$PW);
db_select_db(DB,$con);
-$sql = "SELECT e_target FROM gui_element WHERE e_id = 'setScaleHint' AND fkey_gui_id = '".$gui_id."'";
-$res = db_query($sql);
+$sql = "SELECT e_target FROM gui_element WHERE e_id = 'setScaleHint' AND fkey_gui_id = $1";
+$v = array($gui_id);
+$t = array('s');
+$res = db_prep_query($sql, $v, $t);
$cnt = 0;
while($row = db_fetch_array($res)){
$e_target = $row["e_target"];
$cnt++;
-if($cnt > 1){ echo "alert('mod_scaleHint: ID not unique!');";}
+if($cnt > 1){
+ echo "alert('mod_scaleHint: ID not unique!');";
$params = split(",",$e_target);
echo "var mod_scaleHint_target = '".$params[0]."';";
@@ -38,25 +42,27 @@
mb_registerPreFunctions("mod_scaleHint_init(frameName)");
function mod_scaleHint_init(frameName){
- if(frameName == mod_scaleHint_target){
- var scale = mb_getScale(frameName);
- if(scale < mod_scaleHint_min || scale > mod_scaleHint_max){
- if(scale < mod_scaleHint_min){var newScale = mod_scaleHint_min; }
- if(scale > mod_scaleHint_max){var newScale = mod_scaleHint_max; }
- var ind = getMapObjIndexByName(frameName);
- var arrayBBox = mb_mapObj[ind].extent.split(",");
- var x = parseFloat(arrayBBox[0]) + ((parseFloat(arrayBBox[2]) - parseFloat(arrayBBox[0]))/2);
- var y = parseFloat(arrayBBox[1]) + ((parseFloat(arrayBBox[3]) - parseFloat(arrayBBox[1]))/2);
- var minx = parseFloat(x) - (mb_mapObj[ind].width / (mb_resolution * 100 *2) * newScale);
- var miny = parseFloat(y) - (mb_mapObj[ind].height / (mb_resolution * 100 *2) * newScale);
- var maxx = parseFloat(x) + (mb_mapObj[ind].width / (mb_resolution * 100 *2) * newScale);
- var maxy = parseFloat(y) + (mb_mapObj[ind].height / (mb_resolution * 100 *2) * newScale);
- mb_mapObj[ind].extent = minx + "," + miny + "," + maxx + "," + maxy;
- return true;
+ if(frameName == mod_scaleHint_target){
+ var scale = mb_getScale(frameName);
+ if(scale < mod_scaleHint_min || scale > mod_scaleHint_max){
+ if(scale < mod_scaleHint_min){
+ var newScale = mod_scaleHint_min;
+ if(scale > mod_scaleHint_max){
+ var newScale = mod_scaleHint_max;
+ var ind = getMapObjIndexByName(frameName);
+ var arrayBBox = mb_mapObj[ind].extent.split(",");
+ var x = parseFloat(arrayBBox[0]) + ((parseFloat(arrayBBox[2]) - parseFloat(arrayBBox[0]))/2);
+ var y = parseFloat(arrayBBox[1]) + ((parseFloat(arrayBBox[3]) - parseFloat(arrayBBox[1]))/2);
+ var minx = parseFloat(x) - (mb_mapObj[ind].width / (mb_resolution * 100 *2) * newScale);
+ var miny = parseFloat(y) - (mb_mapObj[ind].height / (mb_resolution * 100 *2) * newScale);
+ var maxx = parseFloat(x) + (mb_mapObj[ind].width / (mb_resolution * 100 *2) * newScale);
+ var maxy = parseFloat(y) + (mb_mapObj[ind].height / (mb_resolution * 100 *2) * newScale);
+ mb_mapObj[ind].extent = minx + "," + miny + "," + maxx + "," + maxy;
+ return true;
More information about the Mapbender_commits
