svn commit: r276 - trunk/mapbender/http/javascripts/mod_scaleSel.php
vera_schulze at osgeo.org
Mon May 15 05:14:34 EDT 2006
Author: vera_schulze
Date: 2006-05-15 09:14:33+0000
New Revision: 276
trunk/mapbender/http/javascripts/mod_scaleSel.php (contents, props changed)
Code cleaning ready
Modified: trunk/mapbender/http/javascripts/mod_scaleSel.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_scaleSel.php?view=diff&rev=276&p1=trunk/mapbender/http/javascripts/mod_scaleSel.php&p2=trunk/mapbender/http/javascripts/mod_scaleSel.php&r1=275&r2=276
--- trunk/mapbender/http/javascripts/mod_scaleSel.php (original)
+++ trunk/mapbender/http/javascripts/mod_scaleSel.php 2006-05-15 09:14:33+0000
@@ -1,30 +1,49 @@
<?php
-#$Id: mod_scaleSel.php,v 1.8 2005/09/13 18:16:42 bjoern_heuser Exp $
-#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_scaleSel.php,v 1.8 2005/09/13 18:16:42 bjoern_heuser Exp $
+# $Id$
+# http://www.mapbender.org/index.php/mod_scaleSel.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
$gui_id = $_REQUEST["gui_id"];
require_once("../../conf/mapbender.conf");
$con = db_connect($DBSERVER,$OWNER,$PW);
db_select_db(DB,$con);
-$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'scaleSelect' AND fkey_gui_id = '".$gui_id."'";
-$res = db_query($sql);
+$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'scaleSelect' AND fkey_gui_id = $1";
+$v = array($gui_id);
+$t = array('s');
+$res = db_prep_query($sql, $v, $t);
$cnt = 0;
while($row = db_fetch_array($res)){
$e_target = $row["e_target"];
$cnt++;
echo "var mod_scaleSelect_target = '".$e_target."';";
-if($cnt > 1){ echo "alert('scaleSelect: ID not unique!');";}
+if($cnt > 1){
+ echo "alert('scaleSelect: ID not unique!');";
mb_registerSubFunctions("mod_scaleSelect_val(frameName)");
function mod_scaleSelect(obj){
- var ind = obj.selectedIndex;
- mb_repaintScale(mod_scaleSelect_target,null,null,obj.options[ind].value);
+ var ind = obj.selectedIndex;
+ mb_repaintScale(mod_scaleSelect_target,null,null,obj.options[ind].value);
function mod_scaleSelect_val(frameName){
- if(frameName == mod_scaleSelect_target){
- var scale = mb_getScale(frameName);
- document.getElementById("scaleSelect").options[0].text = "1 : " + scale;
- document.getElementById("scaleSelect").options[0].selected = true;
+ if(frameName == mod_scaleSelect_target){
+ var scale = mb_getScale(frameName);
+ document.getElementById("scaleSelect").options[0].text = "1 : " + scale;
+ document.getElementById("scaleSelect").options[0].selected = true;
More information about the Mapbender_commits
