svn commit: r854 - trunk/mapbender/http/javascripts
christoph at osgeo.org
Mon Nov 20 09:02:46 EST 2006
Author: christoph
Date: 2006-11-20 14:02:45+0000
New Revision: 854
trunk/mapbender/http/javascripts/mod_zoomCoords.php
trunk/mapbender/http/javascripts/mod_zoomFull.php
trunk/mapbender/http/javascripts/mod_zoomIn1.php
trunk/mapbender/http/javascripts/mod_zoomOut1.php
include via dirname(__FILE__)
Modified: trunk/mapbender/http/javascripts/mod_zoomCoords.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_zoomCoords.php?view=diff&rev=854&p1=trunk/mapbender/http/javascripts/mod_zoomCoords.php&p2=trunk/mapbender/http/javascripts/mod_zoomCoords.php&r1=853&r2=854
--- trunk/mapbender/http/javascripts/mod_zoomCoords.php (original)
+++ trunk/mapbender/http/javascripts/mod_zoomCoords.php 2006-11-20 14:02:45+0000
@@ -1,10 +1,10 @@
<?php
-#$Id: mod_zoomCoords.php,v 1.10 2006/03/09 08:57:13 uli_rothstein Exp $
+#$Id: mod_zoomCoords.php 76 2006-08-15 12:25:34Z heuser $
#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_zoomCoords.php,v 1.10 2006/03/09 08:57:13 uli_rothstein Exp $
-require_once("../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
session_start();
import_request_variables("PG");
-require_once("../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
Modified: trunk/mapbender/http/javascripts/mod_zoomFull.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_zoomFull.php?view=diff&rev=854&p1=trunk/mapbender/http/javascripts/mod_zoomFull.php&p2=trunk/mapbender/http/javascripts/mod_zoomFull.php&r1=853&r2=854
--- trunk/mapbender/http/javascripts/mod_zoomFull.php (original)
+++ trunk/mapbender/http/javascripts/mod_zoomFull.php 2006-11-20 14:02:45+0000
@@ -1,8 +1,8 @@
<?php
-#$Id: mod_zoomFull.php,v 1.8 2005/09/13 18:16:42 bjoern_heuser Exp $
+#$Id: mod_zoomFull.php 76 2006-08-15 12:25:34Z heuser $
#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_zoomFull.php,v 1.8 2005/09/13 18:16:42 bjoern_heuser Exp $
$gui_id = $_REQUEST["gui_id"];
$con = db_connect($DBSERVER,$OWNER,$PW);
db_select_db(DB,$con);
$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'zoomFull' AND fkey_gui_id = '".$gui_id."'";
Modified: trunk/mapbender/http/javascripts/mod_zoomIn1.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_zoomIn1.php?view=diff&rev=854&p1=trunk/mapbender/http/javascripts/mod_zoomIn1.php&p2=trunk/mapbender/http/javascripts/mod_zoomIn1.php&r1=853&r2=854
--- trunk/mapbender/http/javascripts/mod_zoomIn1.php (original)
+++ trunk/mapbender/http/javascripts/mod_zoomIn1.php 2006-11-20 14:02:45+0000
@@ -19,7 +19,7 @@
$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'zoomIn1' AND fkey_gui_id = $1";
Modified: trunk/mapbender/http/javascripts/mod_zoomOut1.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_zoomOut1.php?view=diff&rev=854&p1=trunk/mapbender/http/javascripts/mod_zoomOut1.php&p2=trunk/mapbender/http/javascripts/mod_zoomOut1.php&r1=853&r2=854
--- trunk/mapbender/http/javascripts/mod_zoomOut1.php (original)
+++ trunk/mapbender/http/javascripts/mod_zoomOut1.php 2006-11-20 14:02:45+0000
@@ -1,9 +1,9 @@
<?php
-#$Id: mod_zoomOut1.php,v 1.8 2005/09/13 18:16:42 bjoern_heuser Exp $
+#$Id: mod_zoomOut1.php 76 2006-08-15 12:25:34Z heuser $
#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_zoomOut1.php,v 1.8 2005/09/13 18:16:42 bjoern_heuser Exp $
$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'zoomOut1' AND fkey_gui_id = '".$gui_id."'";
More information about the Mapbender_commits
