svn commit: r855 - trunk/mapbender/http/javascripts
christoph at osgeo.org
Mon Nov 20 09:06:29 EST 2006
Author: christoph
Date: 2006-11-20 14:06:28+0000
New Revision: 855
trunk/mapbender/http/javascripts/mod_scaleHint.php
trunk/mapbender/http/javascripts/mod_scaleSel.php
trunk/mapbender/http/javascripts/mod_scaleText.php
trunk/mapbender/http/javascripts/mod_scalebar.php
trunk/mapbender/http/javascripts/mod_selArea.php
trunk/mapbender/http/javascripts/mod_selArea1.php
trunk/mapbender/http/javascripts/mod_selectMapsize.php
trunk/mapbender/http/javascripts/mod_setBBOX1.php
trunk/mapbender/http/javascripts/mod_setBackground.php
trunk/mapbender/http/javascripts/mod_setBackground_all.php
trunk/mapbender/http/javascripts/mod_state.php
trunk/mapbender/http/javascripts/mod_tab.php
trunk/mapbender/http/javascripts/mod_toggleModule.php
include via dirname(__FILE__)
Modified: trunk/mapbender/http/javascripts/mod_scaleHint.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_scaleHint.php?view=diff&rev=855&p1=trunk/mapbender/http/javascripts/mod_scaleHint.php&p2=trunk/mapbender/http/javascripts/mod_scaleHint.php&r1=854&r2=855
--- trunk/mapbender/http/javascripts/mod_scaleHint.php (original)
+++ trunk/mapbender/http/javascripts/mod_scaleHint.php 2006-11-20 14:06:28+0000
@@ -19,7 +19,7 @@
$gui_id = $_REQUEST["gui_id"];
-require_once("../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
$con = db_connect($DBSERVER,$OWNER,$PW);
db_select_db(DB,$con);
$sql = "SELECT e_target FROM gui_element WHERE e_id = 'setScaleHint' AND fkey_gui_id = $1";
Modified: trunk/mapbender/http/javascripts/mod_scaleSel.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_scaleSel.php?view=diff&rev=855&p1=trunk/mapbender/http/javascripts/mod_scaleSel.php&p2=trunk/mapbender/http/javascripts/mod_scaleSel.php&r1=854&r2=855
--- trunk/mapbender/http/javascripts/mod_scaleSel.php (original)
+++ trunk/mapbender/http/javascripts/mod_scaleSel.php 2006-11-20 14:06:28+0000
@@ -18,7 +18,7 @@
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'scaleSelect' AND fkey_gui_id = $1";
Modified: trunk/mapbender/http/javascripts/mod_scaleText.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_scaleText.php?view=diff&rev=855&p1=trunk/mapbender/http/javascripts/mod_scaleText.php&p2=trunk/mapbender/http/javascripts/mod_scaleText.php&r1=854&r2=855
--- trunk/mapbender/http/javascripts/mod_scaleText.php (original)
+++ trunk/mapbender/http/javascripts/mod_scaleText.php 2006-11-20 14:06:28+0000
@@ -18,7 +18,7 @@
$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'scaleText' AND fkey_gui_id = $1";
Modified: trunk/mapbender/http/javascripts/mod_scalebar.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_scalebar.php?view=diff&rev=855&p1=trunk/mapbender/http/javascripts/mod_scalebar.php&p2=trunk/mapbender/http/javascripts/mod_scalebar.php&r1=854&r2=855
--- trunk/mapbender/http/javascripts/mod_scalebar.php (original)
+++ trunk/mapbender/http/javascripts/mod_scalebar.php 2006-11-20 14:06:28+0000
@@ -18,7 +18,7 @@
$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'scalebar' AND fkey_gui_id = $1";
Modified: trunk/mapbender/http/javascripts/mod_selArea.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_selArea.php?view=diff&rev=855&p1=trunk/mapbender/http/javascripts/mod_selArea.php&p2=trunk/mapbender/http/javascripts/mod_selArea.php&r1=854&r2=855
--- trunk/mapbender/http/javascripts/mod_selArea.php (original)
+++ trunk/mapbender/http/javascripts/mod_selArea.php 2006-11-20 14:06:28+0000
@@ -18,7 +18,7 @@
$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'selArea1' AND fkey_gui_id = '".$gui_id."'";
Modified: trunk/mapbender/http/javascripts/mod_selArea1.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_selArea1.php?view=diff&rev=855&p1=trunk/mapbender/http/javascripts/mod_selArea1.php&p2=trunk/mapbender/http/javascripts/mod_selArea1.php&r1=854&r2=855
--- trunk/mapbender/http/javascripts/mod_selArea1.php (original)
+++ trunk/mapbender/http/javascripts/mod_selArea1.php 2006-11-20 14:06:28+0000
@@ -19,7 +19,7 @@
$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'selArea1' AND fkey_gui_id = $1";
Modified: trunk/mapbender/http/javascripts/mod_selectMapsize.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_selectMapsize.php?view=diff&rev=855&p1=trunk/mapbender/http/javascripts/mod_selectMapsize.php&p2=trunk/mapbender/http/javascripts/mod_selectMapsize.php&r1=854&r2=855
--- trunk/mapbender/http/javascripts/mod_selectMapsize.php (original)
+++ trunk/mapbender/http/javascripts/mod_selectMapsize.php 2006-11-20 14:06:28+0000
@@ -18,7 +18,7 @@
$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'selectMapsize' AND fkey_gui_id = $1";
Modified: trunk/mapbender/http/javascripts/mod_setBBOX1.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_setBBOX1.php?view=diff&rev=855&p1=trunk/mapbender/http/javascripts/mod_setBBOX1.php&p2=trunk/mapbender/http/javascripts/mod_setBBOX1.php&r1=854&r2=855
--- trunk/mapbender/http/javascripts/mod_setBBOX1.php (original)
+++ trunk/mapbender/http/javascripts/mod_setBBOX1.php 2006-11-20 14:06:28+0000
@@ -18,7 +18,7 @@
-include("../../conf/mapbender.conf");
+include(dirname(__FILE__)."/../../conf/mapbender.conf");
$sql = "SELECT e_target FROM gui_element WHERE e_id = 'setBBOX' AND fkey_gui_id = $1";
Modified: trunk/mapbender/http/javascripts/mod_setBackground.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_setBackground.php?view=diff&rev=855&p1=trunk/mapbender/http/javascripts/mod_setBackground.php&p2=trunk/mapbender/http/javascripts/mod_setBackground.php&r1=854&r2=855
--- trunk/mapbender/http/javascripts/mod_setBackground.php (original)
+++ trunk/mapbender/http/javascripts/mod_setBackground.php 2006-11-20 14:06:28+0000
@@ -18,7 +18,7 @@
$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'setBackground' AND fkey_gui_id = $1";
Modified: trunk/mapbender/http/javascripts/mod_setBackground_all.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_setBackground_all.php?view=diff&rev=855&p1=trunk/mapbender/http/javascripts/mod_setBackground_all.php&p2=trunk/mapbender/http/javascripts/mod_setBackground_all.php&r1=854&r2=855
--- trunk/mapbender/http/javascripts/mod_setBackground_all.php (original)
+++ trunk/mapbender/http/javascripts/mod_setBackground_all.php 2006-11-20 14:06:28+0000
@@ -20,7 +20,7 @@
$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'setBackground_all' AND fkey_gui_id = $1 ";
Modified: trunk/mapbender/http/javascripts/mod_state.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_state.php?view=diff&rev=855&p1=trunk/mapbender/http/javascripts/mod_state.php&p2=trunk/mapbender/http/javascripts/mod_state.php&r1=854&r2=855
--- trunk/mapbender/http/javascripts/mod_state.php (original)
+++ trunk/mapbender/http/javascripts/mod_state.php 2006-11-20 14:06:28+0000
@@ -17,9 +17,9 @@
# along with this program; if not, write to the Free Software
-//require("mb_validateSession.php");
+//require(dirname(__FILE__)."/mb_validateSession.php");
$gui_id = $_SESSION["mb_user_gui"];
Modified: trunk/mapbender/http/javascripts/mod_tab.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_tab.php?view=diff&rev=855&p1=trunk/mapbender/http/javascripts/mod_tab.php&p2=trunk/mapbender/http/javascripts/mod_tab.php&r1=854&r2=855
--- trunk/mapbender/http/javascripts/mod_tab.php (original)
+++ trunk/mapbender/http/javascripts/mod_tab.php 2006-11-20 14:06:28+0000
@@ -21,7 +21,7 @@
$e_id_css = 'tabs';
-include('../include/dyn_js.php');
+include(dirname(__FILE__).'/../include/dyn_js.php');
var tab_height = false;
Modified: trunk/mapbender/http/javascripts/mod_toggleModule.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_toggleModule.php?view=diff&rev=855&p1=trunk/mapbender/http/javascripts/mod_toggleModule.php&p2=trunk/mapbender/http/javascripts/mod_toggleModule.php&r1=854&r2=855
--- trunk/mapbender/http/javascripts/mod_toggleModule.php (original)
+++ trunk/mapbender/http/javascripts/mod_toggleModule.php 2006-11-20 14:06:28+0000
@@ -19,7 +19,7 @@
$sql = "SELECT e_target FROM gui_element WHERE e_id = 'toggleModule' AND fkey_gui_id = $1";
More information about the Mapbender_commits
