svn commit: r895 - trunk/mapbender/http/classes/class_wmc.php
christoph at osgeo.org
Tue Nov 21 03:11:07 EST 2006
Author: christoph
Date: 2006-11-21 08:11:07+0000
New Revision: 895
* added utf8_encode/decode functions
* removed verbose statements
* replaced alert by mb_exception
* added scalehints (TODO: change to "Extensions")
* now loading correct data format
Modified: trunk/mapbender/http/classes/class_wmc.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_wmc.php?view=diff&rev=895&p1=trunk/mapbender/http/classes/class_wmc.php&p2=trunk/mapbender/http/classes/class_wmc.php&r1=894&r2=895
--- trunk/mapbender/http/classes/class_wmc.php (original)
+++ trunk/mapbender/http/classes/class_wmc.php 2006-11-21 08:11:07+0000
@@ -1,5 +1,5 @@
<?php
-# $Id: class_wmc.php,v 1.31 2006/03/16 14:49:30 c_baudson Exp $
+# $Id: class_wmc.php 505 2006-11-20 10:53:10Z christoph $
# http://www.mapbender.org/index.php/class_wmc.php
# Copyright (C) 2002 CCGIS
@@ -18,7 +18,15 @@
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
require_once("../../conf/mapbender.conf");
require_once("../classes/class_wms.php");
+require_once("../classes/class_mb_exception.php");
+function mb_utf8_encode ($str) {
+ if(CHARSET=="UTF-8") return utf8_encode($str);
+ return $str;
+function mb_utf8_decode ($str) {
+ if(CHARSET=="UTF-8") return utf8_decode($str);
+ return $str;
class wmc {
var $wmc_id;
@@ -68,6 +76,8 @@
var $wmc_layer_format_current = array();
var $wmc_layer_dataurl = array();
var $wmc_layer_metadataurl = array();
+ var $wmc_layer_minscale = array();
+ var $wmc_layer_maxscale = array();
var $wmc_layer_format = array();
var $wmc_layer_style_current = array();
var $wmc_layer_style_name = array();
@@ -131,7 +141,8 @@
xml_parse_into_struct($parser,$data,$values,$tags);
$code = xml_get_error_code ($parser);
if ($code) {
- echo "alert('Error " . $code . " (" . xml_error_string($code) . ")');\n";
+ $line = xml_get_current_line_number($parser);
+ $mb_exception = new mb_exception(xml_error_string($code) . " in line " . $line);
return false;
xml_parser_free($parser);
@@ -151,243 +162,177 @@
$layer = false;
foreach ($values as $element) {
- $verbose .= ".";
if(strtoupper($element[tag]) == "VIEWCONTEXT" && $element[type] == "open"){
- $this->wmc_id = $element[attributes]["id"];
- $this->wmc_version = $element[attributes]["version"];
- $verbose .= "Viewcontext begin<br>\n";
- $verbose .= $this->wmc_id . "<br>\n";
- $verbose .= $this->wmc_version . "<br>\n";
- if(strtoupper($element[tag]) == "VIEWCONTEXT" && $element[type] == "close"){
- $verbose .= "Viewcontext end<br>\n";
+ $this->wmc_id = $element[attributes]["id"];
+ $this->wmc_version = $element[attributes]["version"];
if(strtoupper($element[tag]) == "GENERAL" && $element[type] == "open"){
$general = true;
- $verbose .= "General begin<br>\n";
if(strtoupper($element[tag]) == "LAYERLIST" && $element[type] == "open"){
$layerlist = true;
- $verbose .= "LayerList begin<br>\n";
if ($general) {
- if(strtoupper($element[tag]) == "WINDOW"){
- $this->wmc_windowWidth = $element[attributes]["width"];
- $this->wmc_windowHeight = $element[attributes]["height"];
- $verbose .= $this->wmc_windowHeight . "<br>\n";
- $verbose .= $this->wmc_windowWidth . "<br>\n";
- if(strtoupper($element[tag]) == "BOUNDINGBOX"){
- $this->wmc_bBox_SRS = $element[attributes]["SRS"];
- $verbose .= $this->wmc_bBox_SRS . "<br>\n";
- $this->wmc_bBox_minx = $element[attributes]["minx"];
- $verbose .= $this->wmc_bBox_minx . "<br>\n";
- $this->wmc_bBox_miny = $element[attributes]["miny"];
- $verbose .= $this->wmc_bBox_miny . "<br>\n";
- $this->wmc_bBox_maxx = $element[attributes]["maxx"];
- $verbose .= $this->wmc_bBox_maxx . "<br>\n";
- $this->wmc_bBox_maxy = $element[attributes]["maxy"];
- $verbose .= $this->wmc_bBox_maxy . "<br>\n";
- if(strtoupper($element[tag]) == "NAME"){
- $this->wmc_name = $element[value];
- $verbose .= $this->wmc_name . "<br>\n";
- if(strtoupper($element[tag]) == "TITLE"){
- $this->wmc_title = $element[value];
- $verbose .= $this->wmc_title . "<br>\n";
- if(strtoupper($element[tag]) == "ABSTRACT"){
- $this->wmc_abstract = $element[value];
- $verbose .= $this->wmc_abstract . "<br>\n";
- if(strtoupper($element[tag]) == "CONTACTINFORMATION" && $element['type'] == "open"){
- $contactinformation = true;
- $verbose .= "Contactinformation begin<br>\n";
- if ($contactinformation) {
- if(strtoupper($element[tag]) == "CONTACTPOSITION"){
- $this->wmc_contactposition = $element[value];
- $verbose .= $this->wmc_contactposition . "<br>\n";
- if(strtoupper($element[tag]) == "CONTACTVOICETELEPHONE"){
- $this->wmc_contactvoicetelephone = $element[value];
- $verbose .= $this->wmc_contactvoicetelephone . "<br>\n";
- if(strtoupper($element[tag]) == "CONTACTFACSIMILETELEPHONE"){
- $this->wmc_contactfacsimiletelephone = $element[value];
- $verbose .= $this->wmc_contactfacsimiletelephone . "<br>\n";
- if(strtoupper($element[tag]) == "CONTACTELECTRONICMAILADDRESS"){
- $this->wmc_contactemail = $element[value];
- $verbose .= $this->wmc_contactemail . "<br>\n";
- if(strtoupper($element[tag]) == "CONTACTPERSONPRIMARY" && $element['type'] == "open"){
- $contactpersonprimary = true;
- $verbose .= "Contactpersonprimary begin<br>\n";
- if ($contactpersonprimary) {
- if(strtoupper($element[tag]) == "CONTACTPERSON"){
- $this->wmc_contactperson = $element[value];
- $verbose .= $this->wmc_contactperson . "<br>\n";
- if(strtoupper($element[tag]) == "CONTACTORGANIZATION"){
- $this->wmc_contactorganization = $element[value];
- $verbose .= $this->wmc_contactorganization . "<br>\n";
- if(strtoupper($element[tag]) == "CONTACTPERSONPRIMARY" && $element['type'] == "close"){
- $contactpersonprimary = false;
- $verbose .= "Contactpersonprimary end<br>\n";
+ if(strtoupper($element[tag]) == "WINDOW"){
+ $this->wmc_windowWidth = $element[attributes]["width"];
+ $this->wmc_windowHeight = $element[attributes]["height"];
+ if(strtoupper($element[tag]) == "BOUNDINGBOX"){
+ $this->wmc_bBox_SRS = $element[attributes]["SRS"];
+ $this->wmc_bBox_minx = $element[attributes]["minx"];
+ $this->wmc_bBox_miny = $element[attributes]["miny"];
+ $this->wmc_bBox_maxx = $element[attributes]["maxx"];
+ $this->wmc_bBox_maxy = $element[attributes]["maxy"];
+ if(strtoupper($element[tag]) == "NAME"){
+ $this->wmc_name = mb_utf8_decode($element[value]);
+ if(strtoupper($element[tag]) == "TITLE"){
+ $this->wmc_title = mb_utf8_decode($element[value]);
+ if(strtoupper($element[tag]) == "ABSTRACT"){
+ $this->wmc_abstract = mb_utf8_decode($element[value]);
+ if(strtoupper($element[tag]) == "CONTACTINFORMATION" && $element['type'] == "open"){
+ $contactinformation = true;
+ if ($contactinformation) {
+ if(strtoupper($element[tag]) == "CONTACTPOSITION"){
+ $this->wmc_contactposition = mb_utf8_decode($element[value]);
+ if(strtoupper($element[tag]) == "CONTACTVOICETELEPHONE"){
+ $this->wmc_contactvoicetelephone = $element[value];
+ if(strtoupper($element[tag]) == "CONTACTFACSIMILETELEPHONE"){
+ $this->wmc_contactfacsimiletelephone = $element[value];
+ if(strtoupper($element[tag]) == "CONTACTELECTRONICMAILADDRESS"){
+ $this->wmc_contactemail = mb_utf8_decode($element[value]);
+ if(strtoupper($element[tag]) == "CONTACTPERSONPRIMARY" && $element['type'] == "open"){
+ $contactpersonprimary = true;
+ if ($contactpersonprimary) {
+ if(strtoupper($element[tag]) == "CONTACTPERSON"){
+ $this->wmc_contactperson = mb_utf8_decode($element[value]);
- if(strtoupper($element[tag]) == "CONTACTADDRESS" && $element['type'] == "open"){
- $contactaddress = true;
- $verbose .= "Contactaddress begin<br>\n";
- if ($contactaddress) {
- if(strtoupper($element[tag]) == "ADDRESSTYPE"){
- $this->wmc_contactaddresstype = $element[value];
- $verbose .= $this->wmc_contactaddresstype . "<br>\n";
- if(strtoupper($element[tag]) == "ADDRESS"){
- $this->wmc_contactaddress = $element[value];
- $verbose .= $this->wmc_contactaddress . "<br>\n";
- if(strtoupper($element[tag]) == "CITY"){
- $this->wmc_contactcity = $element[value];
- $verbose .= $this->wmc_contactcity . "<br>\n";
- if(strtoupper($element[tag]) == "STATEORPROVINCE"){
- $this->wmc_contactstateorprovince = $element[value];
- $verbose .= $this->wmc_contactstateorprovince . "<br>\n";
- if(strtoupper($element[tag]) == "POSTCODE"){
- $this->wmc_contactpostcode = $element[value];
- $verbose .= $this->wmc_contactpostcode . "<br>\n";
- if(strtoupper($element[tag]) == "COUNTRY"){
- $this->wmc_contactcountry = $element[value];
- $verbose .= $this->wmc_contactcountry . "<br>\n";
- if(strtoupper($element[tag]) == "CONTACTADDRESS" && $element['type'] == "close"){
- $contactaddress = false;
- $verbose .= "Contactaddress end<br>\n";
+ if(strtoupper($element[tag]) == "CONTACTORGANIZATION"){
+ $this->wmc_contactorganization = mb_utf8_decode($element[value]);
+ if(strtoupper($element[tag]) == "CONTACTPERSONPRIMARY" && $element['type'] == "close"){
+ $contactpersonprimary = false;
+ if(strtoupper($element[tag]) == "CONTACTADDRESS" && $element['type'] == "open"){
+ $contactaddress = true;
+ if ($contactaddress) {
+ if(strtoupper($element[tag]) == "ADDRESSTYPE"){
+ $this->wmc_contactaddresstype = mb_utf8_decode($element[value]);
+ if(strtoupper($element[tag]) == "ADDRESS"){
+ $this->wmc_contactaddress = mb_utf8_decode($element[value]);
+ if(strtoupper($element[tag]) == "CITY"){
+ $this->wmc_contactcity = mb_utf8_decode($element[value]);
+ if(strtoupper($element[tag]) == "STATEORPROVINCE"){
+ $this->wmc_contactstateorprovince = mb_utf8_decode($element[value]);
+ if(strtoupper($element[tag]) == "POSTCODE"){
+ $this->wmc_contactpostcode = $element[value];
+ if(strtoupper($element[tag]) == "COUNTRY"){
+ $this->wmc_contactcountry = mb_utf8_decode($element[value]);
+ if(strtoupper($element[tag]) == "CONTACTADDRESS" && $element['type'] == "close"){
+ $contactaddress = false;
+ if(strtoupper($element[tag]) == "LOGOURL" && $element['type'] == "open"){
+ $logourl = true;
+ $this->wmc_logourl_width = $element[attributes]["width"];
+ $this->wmc_logourl_height = $element[attributes]["height"];
+ $this->wmc_logourl_format = $element[attributes]["format"];
+ if ($logourl) {
+ if(strtoupper($element[tag]) == "LOGOURL" && $element['type'] == "close"){
+ $logourl = false;
+ if(strtoupper($element[tag]) == "ONLINERESOURCE"){
+ $this->wmc_logourl_type = $element[attributes]["xlink:type"];
+ $this->wmc_logourl = $element[attributes]["xlink:href"];
- if(strtoupper($element[tag]) == "LOGOURL" && $element['type'] == "open"){
- $logourl = true;
- $verbose .= "Logourl begin<br>\n";
- $this->wmc_logourl_width = $element[attributes]["width"];
- $verbose .= $this->wmc_logourl_width . "<br>\n";
- $this->wmc_logourl_height = $element[attributes]["height"];
- $verbose .= $this->wmc_logourl_height ."<br>\n";
- $this->wmc_logourl_format = $element[attributes]["format"];
- $verbose .= $this->wmc_logourl_format . "<br>\n";
- if ($logourl) {
- if(strtoupper($element[tag]) == "LOGOURL" && $element['type'] == "close"){
- $logourl = false;
- $verbose .= "Logourl end<br>\n";
- if(strtoupper($element[tag]) == "ONLINERESOURCE"){
- $this->wmc_logourl_type = $element[attributes]["xlink:type"];
- $verbose .= $this->wmc_logourl_type . "<br>\n";
- $this->wmc_logourl = $element[attributes]["xlink:href"];
- $verbose .= $this->wmc_logourl . "<br>\n";
- if(strtoupper($element[tag]) == "DESCRIPTIONURL" && $element['type'] == "open"){
- $descriptionurl = true;
- $verbose .= "Descriptionurl begin<br>\n";
- $this->wmc_descriptionurl_format = $element[attributes]["format"];
- $verbose .= $this->wmc_descriptionurl_format . "<br>\n";
- if ($descriptionurl) {
- if(strtoupper($element[tag]) == "DESCRIPTIONURL" && $element['type'] == "close"){
- $descriptionurl = false;
- $verbose .= "Descriptionurl end<br>\n";
- $this->wmc_descriptionurl_type = $element[attributes]["xlink:type"];
- $verbose .= $this->wmc_descriptionurl_type . "<br>\n";
- $this->wmc_descriptionurl = $element[attributes]["xlink:href"];
- $verbose .= $this->wmc_descriptionurl . "<br>\n";
- if(strtoupper($element[tag]) == "KEYWORDLIST" && $element['type'] == "open"){
- $keywordlist = true;
- $verbose .= "Keywordlist begin<br>\n";
- if ($keywordlist) {
- if(strtoupper($element[tag]) == "KEYWORDLIST" && $element['type'] == "close"){
- $keywordlist = false;
- $cnt_keyword = -1;
- $verbose .= "Keywordlist end<br>\n";
- if(strtoupper($element[tag]) == "KEYWORD"){
- $cnt_keyword++;
- $this->wmc_keyword[$cnt_keyword] = $element[value];
- $verbose .= $this->wmc_keyword[$cnt_keyword] . "<br>\n";
- if(strtoupper($element[tag]) == "GENERAL" && $element['type'] == "close"){
- $general = false;
- $verbose .= "General end<br>\n";
+ if(strtoupper($element[tag]) == "DESCRIPTIONURL" && $element['type'] == "open"){
+ $descriptionurl = true;
+ $this->wmc_descriptionurl_format = $element[attributes]["format"];
+ if ($descriptionurl) {
+ if(strtoupper($element[tag]) == "DESCRIPTIONURL" && $element['type'] == "close"){
+ $descriptionurl = false;
+ $this->wmc_descriptionurl_type = $element[attributes]["xlink:type"];
+ $this->wmc_descriptionurl = $element[attributes]["xlink:href"];
+ if(strtoupper($element[tag]) == "KEYWORDLIST" && $element['type'] == "open"){
+ $keywordlist = true;
+ if ($keywordlist) {
+ if(strtoupper($element[tag]) == "KEYWORDLIST" && $element['type'] == "close"){
+ $keywordlist = false;
+ $cnt_keyword = -1;
+ if(strtoupper($element[tag]) == "KEYWORD"){
+ $cnt_keyword++;
+ $this->wmc_keyword[$cnt_keyword] = mb_utf8_decode($element[value]);
+ if(strtoupper($element[tag]) == "GENERAL" && $element['type'] == "close"){
+ $general = false;
if ($layerlist) {
if(strtoupper($element[tag]) == "LAYERLIST" && $element['type'] == "close"){
$layerlist = false;
- $verbose .= "LayerList end<br>\n";
if(strtoupper($element[tag]) == "LAYER" && $element[type] == "open"){
$cnt_layer++;
$this->wmc_layer_queryable[$cnt_layer] = $element[attributes]["queryable"];
$this->wmc_layer_hidden[$cnt_layer] = $element[attributes]["hidden"];
$layer = true;
- $verbose .= "Layer begin<br>\n";
- $verbose .= $this->wmc_layer_queryable[$cnt_layer] . "<br>\n";
- $verbose .= $this->wmc_layer_hidden[$cnt_layer] . "<br>\n";
$cnt_epsg = 0;
if ($layer) {
if(strtoupper($element[tag]) == "LAYER" && $element[type] == "close"){
- $layer = false;
- $verbose .= "Layer end<br>\n";
+ $layer = false;
if ($formatlist) {
if(strtoupper($element[tag]) == "FORMAT"){
$cnt_format++;
$this->wmc_layer_format_current[$cnt_layer][$cnt_format] = $element[attributes]["current"];
- $verbose .= $this->wmc_layer_format_current[$cnt_layer][$cnt_format] . "<br>\n";
$this->wmc_layer_format[$cnt_layer][$cnt_format] = $element[value];
- $verbose .= $this->wmc_layer_format[$cnt_layer][$cnt_format] . "<br>\n";
if(strtoupper($element[tag]) == "FORMATLIST" && $element[type] == "close"){
- $verbose .= "Formatlist end<br>\n";
$formatlist = false;
elseif ($metadataurl) {
$this->wmc_layer_metadataurl[$cnt_layer] = $element[attributes]["xlink:href"];
- $verbose .= $this->wmc_layer_metadataurl[$cnt_layer] . "<br>\n";
if(strtoupper($element[tag]) == "METADATAURL" && $element[type] == "close"){
- $verbose .= "Metadataurl end<br>\n";
$metadataurl = false;
elseif ($dataurl) {
$this->wmc_layer_dataurl[$cnt_layer] = $element[attributes]["xlink:href"];
- $verbose .= $this->wmc_layer_dataurl[$cnt_layer] . "<br>\n";
if(strtoupper($element[tag]) == "DATAURL" && $element[type] == "close"){
- $verbose .= "Dataurl end<br>\n";
$dataurl = false;
@@ -396,70 +341,52 @@
$cnt_style++;
$style = true;
$this->wmc_layer_style_current[$cnt_layer][$cnt_style] = $element[attributes]["current"];
- $verbose .= "Style begin<br>\n";
- $verbose .= $this->wmc_layer_style_current[$cnt_layer][$cnt_style] . "<br>\n";
if ($style) {
if(strtoupper($element[tag]) == "STYLE" && $element[type] == "close"){
$style = false;
- $verbose .= "Style end<br>\n";
if(strtoupper($element[tag]) == "SLD" && $element[type] == "open"){
$sld = true;
- $verbose .= "sld begin<br>\n";
if ($sld) {
if(strtoupper($element[tag]) == "SLD" && $element[type] == "close"){
- $verbose .= "sld end<br>\n";
$sld = false;
$this->wmc_layer_style_sld_type[$cnt_layer][$cnt_style] = $element[attributes]["xlink:type"];
- $verbose .= $this->wmc_layer_style_sld_type[$cnt_layer][$cnt_style] . "<br>\n";
$this->wmc_layer_style_sld_url[$cnt_layer][$cnt_style] = $element[attributes]["xlink:href"];
- $verbose .= $this->wmc_layer_style_sld_url[$cnt_layer][$cnt_style] . "<br>\n";
- $this->wmc_layer_style_sld_title[$cnt_layer][$cnt_style] = $element[value];
- $verbose .= $this->wmc_layer_style_sld_title[$cnt_layer][$cnt_style] . "<br>\n";
+ $this->wmc_layer_style_sld_title[$cnt_layer][$cnt_style] = mb_utf8_decode($element[value]);
else {
- $this->wmc_layer_style_name[$cnt_layer][$cnt_style] = $element[value];
- $verbose .= $this->wmc_layer_style_name[$cnt_layer][$cnt_style] . "<br>\n";
+ $this->wmc_layer_style_name[$cnt_layer][$cnt_style] = mb_utf8_decode($element[value]);
$this->wmc_layer_style_title[$cnt_layer][$cnt_style] = $element[value];
- $verbose .= $this->wmc_layer_style_title[$cnt_layer][$cnt_style] . "<br>\n";
if(strtoupper($element[tag]) == "LEGENDURL" && $element[type] == "open"){
- $verbose .= "legendurl begin<br>\n";
$legendurl = true;
$this->wmc_layer_style_legendurl_width[$cnt_layer][$cnt_style] = $element[attributes]["width"];
- $verbose .= $this->wmc_layer_style_legendurl_width[$cnt_layer][$cnt_style] . "<br>\n";
$this->wmc_layer_style_legendurl_height[$cnt_layer][$cnt_style] = $element[attributes]["height"];
- $verbose .= $this->wmc_layer_style_legendurl_height[$cnt_layer][$cnt_style] . "<br>\n";
$this->wmc_layer_style_legendurl_format[$cnt_layer][$cnt_style] = $element[attributes]["format"];
- $verbose .= $this->wmc_layer_style_legendurl_format[$cnt_layer][$cnt_style] . "<br>\n";
if ($legendurl) {
if(strtoupper($element[tag]) == "LEGENDURL" && $element[type] == "close"){
- $verbose .= "legendurl end<br>\n";
$legendurl = false;
$this->wmc_layer_style_legendurl_type[$cnt_layer][$cnt_style] = $element[attributes]["xlink:type"];
- $verbose .= $this->wmc_layer_style_legendurl_type[$cnt_layer][$cnt_style] . "<br>\n";
$this->wmc_layer_style_legendurl[$cnt_layer][$cnt_style] = $element[attributes]["xlink:href"];
- $verbose .= $this->wmc_layer_style_legendurl[$cnt_layer][$cnt_style] . "<br>\n";
if(strtoupper($element[tag]) == "STYLELIST" && $element[type] == "close"){
$stylelist = false;
- $verbose .= "Stylelist end<br>\n";
else {
@@ -467,68 +394,56 @@
$server = true;
$this->wmc_wms_service[$cnt_layer] = $element[attributes]["service"];
$this->wmc_wms_version[$cnt_layer] = $element[attributes]["version"];
- $this->wmc_wms_title[$cnt_layer] = $element[attributes]["title"];
- $verbose .= "Server begin<br>\n";
- $verbose .= $this->wmc_wms_service[$cnt_layer] . "<br>\n";
- $verbose .= $this->wmc_wms_version[$cnt_layer] . "<br>\n";
- $verbose .= $this->wmc_layer_title[$cnt_layer] . "<br>\n";
+ $this->wmc_wms_title[$cnt_layer] = mb_utf8_decode($element[attributes]["title"]);
if ($server) {
if(strtoupper($element[tag]) == "SERVER" && $element[type] == "close"){
- $verbose .= "Server end<br>\n";
$server = false;
- $this->wmc_wms_serviceURL[$cnt_layer] = $element[attributes]["xlink:href"];
- $verbose .= $this->wmc_wms_serviceURL[$cnt_layer] . "<br>\n";
+ $this->wmc_wms_serviceURL[$cnt_layer] = $element[attributes]["xlink:href"];
- $this->wmc_layer_name[$cnt_layer] = $element[value];
- $verbose .= $this->wmc_layer_name[$cnt_layer] . "<br>\n";
+ $this->wmc_layer_name[$cnt_layer] = mb_utf8_decode($element[value]);
- $this->wmc_layer_title[$cnt_layer] = $element[value];
+ $this->wmc_layer_title[$cnt_layer] = mb_utf8_decode($element[value]);
- $this->wmc_layer_abstract[$cnt_layer] = $element[value];
- $verbose .= $this->wmc_layer_abstract[$cnt_layer] . "<br>\n";
+ $this->wmc_layer_abstract[$cnt_layer] = mb_utf8_decode($element[value]);
if(strtoupper($element[tag]) == "SRS"){
- $epsgArray = explode(" ", $element[value]);
- for ($c = 0 ; $c < count($epsgArray) ; $c ++) {
- $this->wmc_layer_srs[$cnt_layer][$cnt_epsg] = $epsgArray[$c];
- $verbose .= $this->wmc_layer_srs[$cnt_layer][$cnt_epsg] . "<br>\n";
- $cnt_epsg++;
+ $epsgArray = explode(" ", $element[value]);
+ for ($c = 0 ; $c < count($epsgArray) ; $c ++) {
+ $this->wmc_layer_srs[$cnt_layer][$cnt_epsg] = $epsgArray[$c];
+ $cnt_epsg++;
+ if(strtoupper($element[tag]) == "SCALEHINT"){
+ $this->wmc_layer_minscale[$cnt_layer] = $element[attributes]["min"];
+ $this->wmc_layer_maxscale[$cnt_layer] = $element[attributes]["max"];
if(strtoupper($element[tag]) == "METADATAURL" && $element[type] == "open"){
- $verbose .= "Metadataurl begin<br>\n";
$metadataurl = true;
if(strtoupper($element[tag]) == "DATAURL" && $element[type] == "open"){
- $verbose .= "Dataurl begin<br>\n";
$dataurl = true;
if(strtoupper($element[tag]) == "FORMATLIST" && $element[type] == "open"){
- $verbose .= "Formatlist begin<br>\n";
$formatlist = true;
$cnt_format = -1;
if(strtoupper($element[tag]) == "STYLELIST" && $element[type] == "open"){
- $verbose .= "Stylelist begin<br>\n";
$stylelist = true;
$cnt_style = -1;
return true;
- //return $verbose;
function createJsObjFromWMC($target, $mapObj, $action){
@@ -581,7 +496,12 @@
echo "alert('Error: no valid capabilities-document !!');\n";
die; exit;
+ for($j=0;$j<count($this->wmc_layer_format[$i]);$j++){
+ if ($this->wmc_layer_format_current[$i][$j] == 1) {
+ $wms_data_format = $this->wmc_layer_format[$i][$j];
// add wms
$wmc_string .= "\t" . $target . "add_wms('','".
$this->wmc_wms_version[$i] ."','".
@@ -590,7 +510,7 @@
$this->wmc_wms_serviceURL[$i] ."','" .
$this->wmc_layer_style_legendurl[$i][0] ."','','".
- $this->wmc_layer_format[$i][0] ."','text/html','application/vnd.ogc.se_xml','".
+ $wms_data_format ."','text/html','application/vnd.ogc.se_xml','".
$this->wmc_bBox_SRS ."','1');\n";
$added_wms[count($added_wms)] = $current_wms;
@@ -665,17 +585,19 @@
// add layer
$wmc_string .= "\t" . $target . "wms_add_layer('0','".
$this->wmc_layer_name[$ii] . "','".
- $this->wmc_layer_title[$ii] ."','".
- $this->wmc_layer_dataurl[$ii]
+ $this->wmc_layer_title[$ii] ."','".
+ $this->wmc_layer_dataurl[$ii] . "','".
intval($cnt_layers) ."','".
- $this->wmc_layer_queryable[$ii] ."','0','0','".
- $this->wmc_layer_metadataurl[$ii]
+ $this->wmc_layer_queryable[$ii] ."','".
+ $this->wmc_layer_minscale[$ii] ."','".
+ $this->wmc_layer_maxscale[$ii] ."','".
+ $this->wmc_layer_metadataurl[$ii] ."','".
$id ."','1','1','".
intval(!$this->wmc_layer_hidden[$ii]) ."','".
- $this->wmc_layer_queryable[$ii] ."','0','0');\n";
+ $this->wmc_layer_maxscale[$ii] ."');\n";
if ($action == "merge") {
$wmc_string .= "\t}\n";
More information about the Mapbender_commits
