svn commit: r896 - trunk/mapbender/http/classes/class_wms.php
christoph at osgeo.org
Tue Nov 21 03:16:46 EST 2006
Author: christoph
Date: 2006-11-21 08:16:46+0000
New Revision: 896
* added wms metadata
* added flag overwrite
Modified: trunk/mapbender/http/classes/class_wms.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/classes/class_wms.php?view=diff&rev=896&p1=trunk/mapbender/http/classes/class_wms.php&p2=trunk/mapbender/http/classes/class_wms.php&r1=895&r2=896
--- trunk/mapbender/http/classes/class_wms.php (original)
+++ trunk/mapbender/http/classes/class_wms.php 2006-11-21 08:16:46+0000
@@ -17,8 +17,8 @@
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-include_once("../../conf/mapbender.conf");
-require_once("class_connector.php");
+include_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/class_connector.php");
class wms {
var $lastURL;
@@ -33,7 +33,22 @@
var $wms_getfeatureinfo;
var $wms_getlegendurl;
var $wms_upload_url;
+ var $fees;
+ var $accessconstraints;
+ var $contactperson;
+ var $contactposition;
+ var $contactorganization;
+ var $address;
+ var $city;
+ var $stateorprovince;
+ var $postcode;
+ var $country;
+ var $contactvoicetelephone;
+ var $contactfacsimiletelephone;
+ var $contactelectronicmailaddress;
+ var $wms_keyword = array();
var $data_type = array();
var $data_format = array();
@@ -45,6 +60,7 @@
var $gui_wms_epsg;
var $default_epsg = 0;
+ var $overwrite = true;
function wms() {
@@ -99,6 +115,49 @@
if(strtoupper($element[tag]) == "ABSTRACT" && $element[level] == '3'){
$this->wms_abstract = $element[value];
+ if(strtolower($element[tag]) == "fees"){
+ $this->fees = $element[value];
+ if(strtolower($element[tag]) == "accessconstraints"){
+ $this->accessconstraints = $element[value];
+ if(strtolower($element[tag]) == "contactperson"){
+ $this->contactperson = $element[value];
+ if(strtolower($element[tag]) == "contactposition"){
+ $this->contactposition = $element[value];
+ if(strtolower($element[tag]) == "contactorganization"){
+ $this->contactorganization = $element[value];
+ if(strtolower($element[tag]) == "address"){
+ $this->address = $element[value];
+ if(strtolower($element[tag]) == "city"){
+ $this->city = $element[value];
+ if(strtolower($element[tag]) == "stateorprovince"){
+ $this->stateorprovince = $element[value];
+ if(strtolower($element[tag]) == "postcode"){
+ $this->postcode = $element[value];
+ if(strtolower($element[tag]) == "country"){
+ $this->country = $element[value];
+ if(strtolower($element[tag]) == "contactvoicetelephone"){
+ $this->contactvoicetelephone = $element[value];
+ if(strtolower($element[tag]) == "contactfacsimiletelephone"){
+ $this->contactfacsimiletelephone = $element[value];
+ if(strtolower($element[tag]) == "contactelectronicmailaddress"){
+ $this->contactelectronicmailaddress = $element[value];
+ if(strtolower($element[tag]) == "keyword" && $section != 'layer'){
+ $this->wms_keyword[count($this->wms_keyword)] = $element[value];
/*map section*/
if($this->wms_version == "1.0.0"){
if(strtoupper($element[tag]) == "MAP" && $element[type] == "open"){
@@ -330,6 +389,12 @@
if(strtoupper($element[tag]) == "TITLE"){
$this->objLayer[$cnt_layer]->layer_title = $element[value];
+ if(strtoupper($element[tag]) == "ABSTRACT"){
+ $this->objLayer[$cnt_layer]->layer_abstract = $element[value];
+ if(strtoupper($element[tag]) == "KEYWORD"){
+ $this->objLayer[$cnt_layer]->layer_keyword[count($this->objLayer[$cnt_layer]->layer_keyword)] = $element[value];
if(strtoupper($element[tag]) == "DATAURL" && $element[type] == "open"){
$dataurl = true;
@@ -362,7 +427,7 @@
$this->objLayer[$cnt_layer]->layer_epsg[$cnt_epsg]["maxx"] = $element[attributes][maxx];
$this->objLayer[$cnt_layer]->layer_epsg[$cnt_epsg]["maxy"] = $element[attributes][maxy];
- if(strtoupper($element[tag]) == "BOUNDINGBOX"){
+ if(strtoupper($element[tag]) == "BOUNDINGBOX" && $element[attributes][SRS] != "EPSG:4326"){
$cnt_epsg++;
$this->objLayer[$cnt_layer]->layer_epsg[$cnt_epsg]["epsg"] = $element[attributes][SRS];
$this->objLayer[$cnt_layer]->layer_epsg[$cnt_epsg]["minx"] = $element[attributes][minx];
@@ -437,6 +502,10 @@
for($i=0;$i<count($this->objLayer);$i++){
+ if(!is_int($this->objLayer[$i]->layer_parent)){
+ $this->objLayer[$i]->layer_abstract = $this->wms_abstract;
+ $this->objLayer[$i]->layer_keyword = $this->wms_keyword;
if($this->objLayer[$i]->layer_name == ""){
$this->objLayer[$i]->layer_name = $this->objLayer[$i]->layer_title;
@@ -539,6 +608,8 @@
echo "<tr><td>".$this->objLayer[$i]->layer_style[$j][name]."</td><td>".$this->objLayer[$i]->layer_style[$j][title]."</td><td>".$this->objLayer[$i]->layer_style[$j][legendurl]."</td><td>".$this->objLayer[$i]->layer_style[$j][legendurlformat]."</td></tr>";
echo "</table>";
+ echo "<hr>";
+ echo "<hr>";
function addLayer($id,$parent){
@@ -631,12 +702,18 @@
# TABLE wms
$sql = "INSERT INTO wms (wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, ";
- $sql.= "wms_getfeatureinfo, wms_getlegendurl, wms_getcapabilities_doc,wms_upload_url) ";
- $sql .= "VALUES($1,$2,$3,$4,$5,$6,$7,$8,$9)";
+ $sql.= "wms_getfeatureinfo, wms_getlegendurl, wms_getcapabilities_doc, wms_upload_url, fees, ";
+ $sql .= "accessconstraints, contactperson, contactposition, contactorganization, address, city, ";
+ $sql .= "stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, ";
+ $sql .= "wms_owner,wms_timestamp) ";
+ $sql .= "VALUES($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13,$14,$15,$16,$17,$18,$19,$20,$21,$22,$23,$24)";
$v = array($this->wms_version,$this->wms_title,$this->wms_abstract,$this->wms_getcapabilities,
$this->wms_getmap,$this->wms_getfeatureinfo,$this->wms_getlegendurl,$this->wms_getcapabilities_doc,
- $this->wms_upload_url);
- $t = array('s','s','s','s','s','s','s','s','s');
+ $this->wms_upload_url,$this->fees,$this->accessconstraints,$this->contactperson,$this->contactposition,
+ $this->contactorganization,$this->address,$this->city,$this->stateorprovince,$this->postcode,$this->country,
+ $this->contactvoicetelephone,$this->contactfacsimiletelephone,$this->contactelectronicmailaddress,
+ $_SESSION['mb_user_id'],strtotime("now"));
+ $t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','i','i');
$res = db_prep_query($sql,$v,$t);
if(!$res){
db_rollback();
@@ -680,11 +757,14 @@
db_rollback();
db_commit();
+ #Changes JW
+ $this->wms_id = $myWMS;
function insertLayer($i,$myWMS){
$sql = "INSERT INTO layer(fkey_wms_id, layer_pos, layer_parent, layer_name, layer_title, ";
- $sql .= " layer_queryable, layer_minscale, layer_maxscale,layer_dataurl,layer_metadataurl) ";
- $sql .= "VALUES($1,$2,$3,$4,$5,$6,$7,$8,$9,$10)";
+ $sql .= " layer_queryable, layer_minscale, layer_maxscale,layer_dataurl,layer_metadataurl,layer_abstract) ";
+ $sql .= "VALUES($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11)";
if($this->objLayer[$i]->layer_id != null){
$tmpPos = $this->objLayer[$i]->layer_id;
@@ -697,9 +777,9 @@
$v = array($myWMS,$tmpPos,$this->objLayer[$i]->layer_parent,$this->objLayer[$i]->layer_name,
$this->objLayer[$i]->layer_title,
$this->objLayer[$i]->layer_queryable,$this->objLayer[$i]->layer_minscale,
- $this->objLayer[$i]->layer_maxscale,$this->objLayer[$i]->layer_dataurl_href,$this->objLayer[$i]->layer_metadataurl
- $t = array('i','i','s','s','s','i','i','i','s','s');
+ $this->objLayer[$i]->layer_maxscale,$this->objLayer[$i]->layer_dataurl_href,
+ $this->objLayer[$i]->layer_metadataurl,$this->objLayer[$i]->layer_abstract);
+ $t = array('i','i','s','s','s','i','i','i','s','s','s');
if(!$res){
db_rollback();
@@ -710,7 +790,10 @@
$this->insertLayerEPSG($i);
# TABLE layer_style for each layer
- $this->insertLayerStyle($i);
+ $this->insertLayerStyle($i);
+ # insert Keywords
+ $this->insertLayerKeyword($i);
function updateLayer($i,$myWMS){
$sql = "SELECT layer_id FROM layer WHERE fkey_wms_id = $1 AND layer_name = $2";
@@ -734,8 +817,9 @@
$sql .= "layer_minscale = $5, ";
$sql .= "layer_maxscale = $6, ";
$sql .= "layer_dataurl = $7, ";
- $sql .= "layer_metadataurl = $8 ";
- $sql .= "WHERE layer_id = $9";
+ $sql .= "layer_metadataurl = $8, ";
+ $sql .= "layer_abstract = $9 ";
+ $sql .= "WHERE layer_id = $10";
@@ -750,10 +834,20 @@
- $this->objLayer[$i]->layer_metadataurl, $l_id
+ $this->objLayer[$i]->layer_metadataurl,$this->objLayer[$i]->layer_abstract, $l_id
- $t = array('i','s','s','i','i','i','s','s','i');
+ $t = array('i','s','s','i','i','i','s','s','s','i');
+ if($this->overwrite == true){
+ $sql = "UPDATE layer SET ";
+ $sql .= "layer_title = $1, ";
+ $sql .= "layer_abstract = $2 ";
+ $sql .= "WHERE layer_id = $3";
+ $v = array($this->objLayer[$i]->layer_title,$this->objLayer[$i]->layer_abstract, $l_id);
+ $t = array('s','s','i');
+ $res = db_prep_query($sql,$v,$t);
if(!$res){
db_rollback();
@@ -764,6 +858,9 @@
function insertGuiLayer($i,$myWMS,$gui_id){
# table gui_layer
@@ -855,31 +952,97 @@
+function insertLayerKeyword($i){
+ $sql = "DELETE FROM layer_keyword WHERE fkey_layer_id = $1";
+ $v = array($this->objLayer[$i]->db_id);
+ $t = array('s');
+ $k = $this->objLayer[$i]->layer_keyword;
+ for($j=0; $j<count($k); $j++){
+ $sql = "SELECT keyword_id FROM keyword WHERE keyword = $1";
+ $v = array($this->objLayer[$i]->layer_keyword[$j]);
+ $t = array('s');
+ if($row = db_fetch_array($res)){
+ $t_layer_id = $row["keyword_id"];
+ else if(!$row = db_fetch_array($res)){
+ $sql1 = "INSERT INTO keyword (keyword)";
+ $sql1 .= "VALUES ($1)";
+ $v1 = array($k[$j]);
+ $t1 = array('s');
+ $res1 = db_prep_query($sql1,$v1,$t1);
+ $t_layer_id = db_insert_id($con,'keyword', 'keyword_id');
+ if(!$res1){
+ db_rollback();
+ $sql1 = "INSERT INTO layer_keyword (fkey_keyword_id,fkey_layer_id)";
+ $sql1 .= "VALUES ($1,$2)";
+ $v1 = array($t_layer_id,$this->objLayer[$i]->db_id);
+ $t1 = array('i','i');
+ if(!$res1){
+ db_rollback();
function updateObjInDB($myWMS){
db_begin();
- # TABLE wms
$sql = "UPDATE wms SET ";
$sql .= "wms_version = $1 ,";
- $sql .= "wms_title = $2 ,";
- $sql .= "wms_abstract = $3 ,";
- $sql .= "wms_getcapabilities = $4 ,";
- $sql .= "wms_getmap = $5 ,";
- $sql .= "wms_getfeatureinfo = $6 ,";
- $sql .= "wms_getlegendurl = $7 ,";
- $sql .= "wms_getcapabilities_doc = $8 ,";
- $sql .= "wms_upload_url = $9 ";
+ $sql .= "wms_getcapabilities = $2 ,";
+ $sql .= "wms_getmap = $3 ,";
+ $sql .= "wms_getfeatureinfo = $4 ,";
+ $sql .= "wms_getlegendurl = $5 ,";
+ $sql .= "wms_getcapabilities_doc = $6 ,";
+ $sql .= "wms_upload_url = $7, ";
+ $sql .= "wms_owner = $8, ";
+ $sql .= "wms_timestamp = $9 ";
$sql .= " WHERE wms_id = $10";
- $v = array($this->wms_version,$this->wms_title,$this->wms_abstract,$this->wms_getcapabilities,
+ $v = array($this->wms_version,$this->wms_getcapabilities,
- $this->wms_getcapabilities_doc,$this->wms_upload_url,$myWMS);
- $t = array('s','s','s','s','s','s','s','s','s','i');
+ $this->wms_getcapabilities_doc,$this->wms_upload_url,$_SESSION["mb_user_id"],strtotime("now"),$myWMS);
+ $t = array('s','s','s','s','s','s','s','i','i','i');
if(!$res){
db_rollback();
+ $sql = "UPDATE wms SET ";
+ $sql .= "wms_title = $1 ,";
+ $sql .= "wms_abstract = $2 ,";
+ $sql .= "fees = $3, ";
+ $sql .= "accessconstraints = $4, ";
+ $sql .= "contactperson = $5, ";
+ $sql .= "contactposition = $6, ";
+ $sql .= "contactorganization = $7, ";
+ $sql .= "address = $8, ";
+ $sql .= "city = $9, ";
+ $sql .= "stateorprovince = $10, ";
+ $sql .= "postcode = $11, ";
+ $sql .= "country = $12, ";
+ $sql .= "contactvoicetelephone = $13, ";
+ $sql .= "contactfacsimiletelephone = $14, ";
+ $sql .= "contactelectronicmailaddress = $15 ";
+ $sql .= " WHERE wms_id = $16";
+ $v = array($this->wms_title,$this->wms_abstract,$this->fees,$this->accessconstraints,
+ $this->contactperson,$this->contactposition,$this->contactorganization,$this->address,
+ $this->city,$this->stateorprovince,$this->postcode,$this->country,$this->contactvoicetelephone,
+ $this->contactfacsimiletelephone,$this->contactelectronicmailaddress,$myWMS);
+ $t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','i');
+ if(!$res){
+ db_rollback();
# delete and refill srs and formats
$sql = "DELETE FROM wms_srs WHERE fkey_wms_id = $1 ";
$v = array($myWMS);
@@ -1319,12 +1482,14 @@
var $layer_parent;
var $layer_name;
var $layer_title;
+ var $layer_abstract;
var $layer_pos;
var $layer_queryable;
var $layer_minscale;
var $layer_maxscale;
var $layer_dataurl_href;
var $layer_metadataurl;
+ var $layer_keyword = array();
var $layer_epsg = array();
var $layer_style = array();
More information about the Mapbender_commits
