svn commit: r900 - trunk/mapbender/http/javascripts/mod_insertWmcIntoDb.php
christoph at osgeo.org
Tue Nov 21 03:57:13 EST 2006
Author: christoph
Date: 2006-11-21 08:57:13+0000
New Revision: 900
* added utf8_encoding
* only insert in db if ID and wmc are given
Modified: trunk/mapbender/http/javascripts/mod_insertWmcIntoDb.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_insertWmcIntoDb.php?view=diff&rev=900&p1=trunk/mapbender/http/javascripts/mod_insertWmcIntoDb.php&p2=trunk/mapbender/http/javascripts/mod_insertWmcIntoDb.php&r1=899&r2=900
--- trunk/mapbender/http/javascripts/mod_insertWmcIntoDb.php (original)
+++ trunk/mapbender/http/javascripts/mod_insertWmcIntoDb.php 2006-11-21 08:57:13+0000
@@ -1,5 +1,5 @@
<?php
-#$Id: mod_insertWmcIntoDb.php,v 1.19 2006/03/09 14:02:42 uli_rothstein Exp $
+#$Id: mod_insertWmcIntoDb.php 507 2006-11-20 10:55:57Z christoph $
#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_insertWmcIntoDb.php,v 1.19 2006/03/09 14:02:42 uli_rothstein Exp $
# Copyright (C) 2002 CCGIS
@@ -49,6 +49,16 @@
</body>
</html>
<?php
+function mb_utf8_encode ($str) {
+ if(CHARSET=="UTF-8") return utf8_encode($str);
+ return $str;
+function mb_utf8_decode ($str) {
+ if(CHARSET=="UTF-8") return utf8_decode($str);
+ return $str;
if ($_POST["data"]) {
$d = explode("____", $_POST["data"]);
// Display WMC
@@ -58,25 +68,28 @@
if ($session) {
echo "<script>document.write('<b>saving workspace...</b>');</script>";
-// $sql = "INSERT INTO mb_user_wmc VALUES ('" . $d[3] . "', '" . $d[0] . "', '" . str_replace("&", "&" , html_entity_decode($d[2])) . "', '" . $d[1] . "', '" . time() . "')";
-// $res = db_query($sql);
- $_SESSION['mb_wmc'] = str_replace("&", "&" , html_entity_decode($d[2]));
+ if (isset($_SESSION['mb_wmc'])) {
+ $_SESSION['mb_wmc'] = stripslashes(str_replace("&", "&" , mb_utf8_encode(html_entity_decode($d[2]))));
echo "<script>function obsolete(){window.close();} window.setTimeout('obsolete()', 1000);</script>";
else {
- $sql = "INSERT INTO mb_user_wmc VALUES ('" . $d[3] . "', '" . $d[0] . "', '" . str_replace("&", "&" , html_entity_decode($d[2])) . "', '" . $d[1] . "', '" . time() . "')";
- $res = db_query($sql);
- if ($d[1]) {
- $wmc_title = "'" . $d[1] . "' ";
- if (db_error()) {
- echo "<script>var title = \"" . $wmc_title . "\";alert(\"Error while saving WMC document \" + title + \"!\");</script>";
- else {
- if ($alert) {
- echo "<script>var title = \"" . $wmc_title . "\";alert(\"WMC document \" + title + \"has been saved!\")</script>";
+ if ($d[3] && $d[0]) {
+ $sql = "INSERT INTO mb_user_wmc VALUES ('" . $d[3] . "', '" . $d[0] . "', '" . str_replace("&", "&" , mb_utf8_encode(html_entity_decode($d[2]))) . "', '" . $d[1] . "', '" . time() . "')";
+ $res = db_query($sql);
+ if ($d[1]) {
+ $wmc_title = "'" . $d[1] . "' ";
+ if (db_error()) {
+ echo "<script>var title = \"" . $wmc_title . "\";alert(\"Error while saving WMC document \" + title + \"!\");</script>";
+ else {
+ if ($alert) {
+ echo "<script>var title = \"" . $wmc_title . "\";alert(\"WMC document \" + title + \"has been saved!\")</script>";
More information about the Mapbender_commits
