svn commit: r901 - trunk/mapbender/http/javascripts/mod_digitize_tab.php
christoph at osgeo.org
Tue Nov 21 04:00:35 EST 2006
Author: christoph
Date: 2006-11-21 09:00:34+0000
New Revision: 901
include via dirname(__FILE__)
Modified: trunk/mapbender/http/javascripts/mod_digitize_tab.php
Url: https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_digitize_tab.php?view=diff&rev=901&p1=trunk/mapbender/http/javascripts/mod_digitize_tab.php&p2=trunk/mapbender/http/javascripts/mod_digitize_tab.php&r1=900&r2=901
--- trunk/mapbender/http/javascripts/mod_digitize_tab.php (original)
+++ trunk/mapbender/http/javascripts/mod_digitize_tab.php 2006-11-21 09:00:34+0000
@@ -19,8 +19,8 @@
session_start();
import_request_variables("PG");
-require_once("../php/mb_validateSession.php");
-require_once("../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
$con = db_connect($DBSERVER,$OWNER,$PW);
db_select_db(DB,$con);
$gui_id = $_SESSION["mb_user_gui"];
@@ -59,7 +59,7 @@
echo "<script language='JavaScript'>";
echo "var mod_digitize_target = '".$e_target[0]."';";
echo "var mod_digitize_frame = '".$e_target[1]."';";
- require_once("mod_geometryArray.js");
+ require_once(dirname(__FILE__)."/mod_geometryArray.js");
var wfsWindow;
@@ -969,7 +969,7 @@
<body onload="registerFunctions();displayButtons();">
<table cellpadding='0' cellspacing='0' align = center><tr><td><div id='digButtons'></div></td></tr></table>
<div id = 'listOfGeometries'></div>
- <form name='sendForm' action='../extensions/geom2wfst.php' method='POST' TARGET='_blank'>
+ <form name='sendForm' action='../extensions/geom2wfst.php' method='POST' TARGET='wfsupdate'>
<input type='hidden' name='url'><input type='hidden' name='filter'><input type='hidden' name='onlineresource'>
</form>
<iframe id='wfsupdate' name='wfsupdate' width=0 height=0></iframe>
More information about the Mapbender_commits
