[Mapbender-commits] r1646 - trunk/mapbender/resources/db/update
svn_mapbender at osgeo.org
Thu Aug 9 09:05:34 EDT 2007
Author: astrid_emde
Date: 2007-08-09 09:05:34 -0400 (Thu, 09 Aug 2007)
New Revision: 1646
trunk/mapbender/resources/db/update/update_postgresql_db.sql
database changes for version 2.5
Modified: trunk/mapbender/resources/db/update/update_postgresql_db.sql
--- trunk/mapbender/resources/db/update/update_postgresql_db.sql 2007-08-09 09:11:26 UTC (rev 1645)
+++ trunk/mapbender/resources/db/update/update_postgresql_db.sql 2007-08-09 13:05:34 UTC (rev 1646)
@@ -1,3 +1,53 @@
--- no changes in version 2.4.2
\ No newline at end of file
+-- database changes in version 2.5
+-- notice lnguage plpgsql has to be installed
+-- How to install plpgsql?
+-- createlang plpgsql mapbender
+-- change in WFS configuration: access to geometries may now be restricted
+ALTER TABLE wfs_conf_element ADD COLUMN f_auth_varname VARCHAR(50);
+-- new column for translation
+ALTER TABLE gui_element ADD COLUMN e_title VARCHAR(255);
+--new table for translations
+CREATE TABLE translations
+ trs_id serial PRIMARY KEY not null,
+ locale varchar(8),
+ msgid varchar(512),
+ msgstr varchar(512)
+CREATE INDEX msgid_idx ON translations(msgid);
+--new function for easy translations
+CREATE OR REPLACE FUNCTION gettext(locale_arg "text", string "text")
+RETURNS "varchar" AS
+$BODY$
+DECLARE
+ msgstr varchar(512);
+ trl RECORD;
+BEGIN
+ -- RAISE NOTICE '>%<', locale_arg;
+ SELECT INTO trl * FROM translations
+ WHERE trim(from locale) = trim(from locale_arg) AND msgid = string;
+ -- we return the original string, if no translation is found.
+ -- this is consistent with gettext's behaviour
+ IF NOT FOUND THEN
+ RETURN string;
+ ELSE
+ RETURN trl.msgstr;
+ END IF;
+END;
+$BODY$
+ LANGUAGE 'plpgsql' VOLATILE;
More information about the Mapbender_commits
