[Mapbender-commits] r1647 - trunk/mapbender/resources/db/update
svn_mapbender at osgeo.org
Thu Aug 9 09:14:14 EDT 2007
Author: astrid_emde
Date: 2007-08-09 09:14:14 -0400 (Thu, 09 Aug 2007)
New Revision: 1647
trunk/mapbender/resources/db/update/update_postgresql_db.sql
database changes for version 2.5
Modified: trunk/mapbender/resources/db/update/update_postgresql_db.sql
--- trunk/mapbender/resources/db/update/update_postgresql_db.sql 2007-08-09 13:05:34 UTC (rev 1646)
+++ trunk/mapbender/resources/db/update/update_postgresql_db.sql 2007-08-09 13:14:14 UTC (rev 1647)
@@ -1,22 +1,26 @@
-- database changes in version 2.5
--- notice lnguage plpgsql has to be installed
+-- notice language plpgsql has to be installed
-- How to install plpgsql?
-- createlang plpgsql mapbender
--- change in WFS configuration: access to geometries may now be restricted
+-- table wfs_conf_element: change in WFS configuration: access to geometries may now be restricted
ALTER TABLE wfs_conf_element ADD COLUMN f_auth_varname VARCHAR(50);
--- new column for translation
+-- table gui_element: new column for translation
ALTER TABLE gui_element ADD COLUMN e_title VARCHAR(255);
---new table for translations
+-- new table translation: new table for translations
CREATE TABLE translations
@@ -28,8 +32,9 @@
CREATE INDEX msgid_idx ON translations(msgid);
---new function for easy translations
+-- new function gettext for easy translations
CREATE OR REPLACE FUNCTION gettext(locale_arg "text", string "text")
RETURNS "varchar" AS
$BODY$
More information about the Mapbender_commits
