[Mapbender-commits] r1930 -
branches/mapbender_sld/resources/db/update
svn_mapbender at osgeo.org
Tue Dec 18 09:35:47 EST 2007
Author: mschulz
Date: 2007-12-18 09:35:47 -0500 (Tue, 18 Dec 2007)
New Revision: 1930
branches/mapbender_sld/resources/db/update/update_postgresql_db.sql
merge: added missing sld table definition
Modified: branches/mapbender_sld/resources/db/update/update_postgresql_db.sql
--- branches/mapbender_sld/resources/db/update/update_postgresql_db.sql 2007-12-18 14:28:19 UTC (rev 1929)
+++ branches/mapbender_sld/resources/db/update/update_postgresql_db.sql 2007-12-18 14:35:47 UTC (rev 1930)
@@ -203,5 +203,32 @@
INSERT INTO translations (locale, msgid, msgstr) VALUES ('de ', 'Logo', 'Logo');
INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Measure distance', 'Streckenabschnittsmessung');
+-- new sld_user_layer table
+CREATE TABLE sld_user_layer (
+ sld_user_layer_id serial NOT NULL,
+ fkey_mb_user_id integer NOT NULL,
+ fkey_layer_id integer NOT NULL,
+ fkey_gui_id character varying,
+ sld_xml text,
+ use_sld smallint
+ALTER TABLE sld_user_layer ADD CONSTRAINT pk_sld_user_layer PRIMARY KEY (sld_user_layer_id);
+-- Name: sld_user_layer_ibfk_1; Type: FK CONSTRAINT; Schema: public; Owner: admin
+ALTER TABLE ONLY sld_user_layer
+ ADD CONSTRAINT sld_user_layer_ibfk_1 FOREIGN KEY (fkey_mb_user_id) REFERENCES mb_user(mb_user_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- Name: sld_user_layer_ibfk_2; Type: FK CONSTRAINT; Schema: public; Owner: admin
+ ADD CONSTRAINT sld_user_layer_ibfk_2 FOREIGN KEY (fkey_layer_id) REFERENCES layer(layer_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- Name: sld_user_layer_ibfk_3; Type: FK CONSTRAINT; Schema: public; Owner: admin
+ ADD CONSTRAINT sld_user_layer_ibfk_3 FOREIGN KEY (fkey_gui_id) REFERENCES gui(gui_id) ON UPDATE CASCADE ON DELETE CASCADE;
More information about the Mapbender_commits
