[Mapbender-commits] r1931 - branches/mapbender_sld/http/sld
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Dec 18 10:17:01 EST 2007
Author: mschulz
Date: 2007-12-18 10:17:01 -0500 (Tue, 18 Dec 2007)
New Revision: 1931
   branches/mapbender_sld/http/sld/sld_edit_filter.php
   branches/mapbender_sld/http/sld/sld_filter_parse.php
   branches/mapbender_sld/http/sld/sld_function_handler.php
use ogc: namespace for filter element
Modified: branches/mapbender_sld/http/sld/sld_edit_filter.php
--- branches/mapbender_sld/http/sld/sld_edit_filter.php	2007-12-18 14:35:47 UTC (rev 1930)
+++ branches/mapbender_sld/http/sld/sld_edit_filter.php	2007-12-18 15:17:01 UTC (rev 1931)
@@ -90,31 +90,31 @@
 				case "NOT":
 					$_SESSION["sld_filter_objects"][$_REQUEST["id"]]->operations[] = new UnaryLogicOp("Not");
 					break;
-				case "OGC:PROPERTYISEQUALTO":
+				case "PROPERTYISEQUALTO":
 					$_SESSION["sld_filter_objects"][$_REQUEST["id"]]->operations[] = new BinaryComparisonOp("ogc:PropertyIsEqualTo");
 					break;
-				case "OGC:PROPERTYISNOTEQUALTO":
+				case "PROPERTYISNOTEQUALTO":
 					$_SESSION["sld_filter_objects"][$_REQUEST["id"]]->operations[] = new BinaryComparisonOp("ogc:PropertyIsNotEqualTo");
 					break;
-				case "OGC:PROPERTYISGREATERTHAN":
+				case "PROPERTYISGREATERTHAN":
 					$_SESSION["sld_filter_objects"][$_REQUEST["id"]]->operations[] = new BinaryComparisonOp("ogc:PropertyIsGreaterThan");
 					break;
-				case "OGC:PROPERTYISGREATERTHANOREQUALTO":
+				case "PROPERTYISGREATERTHANOREQUALTO":
 					$_SESSION["sld_filter_objects"][$_REQUEST["id"]]->operations[] = new BinaryComparisonOp("ogc:PropertyIsGreaterThanOrEqualTo");
 					break;
-				case "OGC:PROPERTYISLESSTHAN":
+				case "PROPERTYISLESSTHAN":
 					$_SESSION["sld_filter_objects"][$_REQUEST["id"]]->operations[] = new BinaryComparisonOp("ogc:PropertyIsLessThan");
 					break;
-				case "OGC:PROPERTYISLESSTHANOREQUALTO":
+				case "PROPERTYISLESSTHANOREQUALTO":
 					$_SESSION["sld_filter_objects"][$_REQUEST["id"]]->operations[] = new BinaryComparisonOp("ogc:PropertyIsLessThanOrEqualTo");
 					break;
-				case "OGC:PROPERTYISLIKE":
+				case "PROPERTYISLIKE":
 					$_SESSION["sld_filter_objects"][$_REQUEST["id"]]->operations[] = new PropertyIsLike();
 					break;
-				case "OGC:PROPERTYISNULL":
+				case "PROPERTYISNULL":
 					$_SESSION["sld_filter_objects"][$_REQUEST["id"]]->operations[] = new PropertyIsNull();
 					break;
-				case "OGC:PROPERTYISBETWEEN":
+				case "PROPERTYISBETWEEN":
 					$_SESSION["sld_filter_objects"][$_REQUEST["id"]]->operations[] = new PropertyIsBetween();
 					break;
Modified: branches/mapbender_sld/http/sld/sld_filter_parse.php
--- branches/mapbender_sld/http/sld/sld_filter_parse.php	2007-12-18 14:35:47 UTC (rev 1930)
+++ branches/mapbender_sld/http/sld/sld_filter_parse.php	2007-12-18 15:17:01 UTC (rev 1931)
@@ -36,7 +36,7 @@
 function parseFilter($data)
-	$xml_parser = xml_parser_create();
+	$xml_parser = xml_parser_create_ns();
 	xml_parser_set_option($xml_parser, XML_OPTION_CASE_FOLDING, 0);
 	xml_parse_into_struct($xml_parser, $data, $vals, $index);
 	xml_parser_free($xml_parser);
@@ -54,7 +54,7 @@
 		$tagname=strtoupper($tag);
 		switch($tagname)
-			case "OGC:FILTER":
+			case "FILTER":
 				if ($element["type"] == "open" || $element["type"] == "complete")
 					$parent[] = false;
@@ -141,11 +141,11 @@
 					$parentactual = $parent[$parentactual];
 				break;
 					$parent[] = $parentactual;
-					$objects[count($parent)-1] = new BinaryComparisonOp("ogc:PropertyIsEqualTo");
+					$objects[count($parent)-1] = new BinaryComparisonOp("PropertyIsEqualTo");
 					$objects[count($parent)-1]->id = count($parent)-1;
 					$objects[count($parent)-1]->parent = $parentactual;
 					$objects[$parentactual]->operations[] = &$objects[count($parent)-1];
@@ -160,11 +160,11 @@
 				break;
-					$objects[count($parent)-1] = new BinaryComparisonOp("ogc:PropertyIsNotEqualTo");
+					$objects[count($parent)-1] = new BinaryComparisonOp("PropertyIsNotEqualTo");
@@ -179,11 +179,11 @@
 				break;
-					$objects[count($parent)-1] = new BinaryComparisonOp("ogc:PropertyIsGreaterThan");
+					$objects[count($parent)-1] = new BinaryComparisonOp("PropertyIsGreaterThan");
@@ -198,11 +198,11 @@
 				break;
-					$objects[count($parent)-1] = new BinaryComparisonOp("ogc:PropertyIsGreaterThanOrEqualTo");
+					$objects[count($parent)-1] = new BinaryComparisonOp("PropertyIsGreaterThanOrEqualTo");
@@ -217,11 +217,11 @@
 				break;
-					$objects[count($parent)-1] = new BinaryComparisonOp("ogc:PropertyIsLessThan");
+					$objects[count($parent)-1] = new BinaryComparisonOp("PropertyIsLessThan");
@@ -236,11 +236,11 @@
 				break;
-					$objects[count($parent)-1] = new BinaryComparisonOp("ogc:PropertyIsLessThanOrEqualTo");
+					$objects[count($parent)-1] = new BinaryComparisonOp("PropertyIsLessThanOrEqualTo");
@@ -255,7 +255,7 @@
 				break;
@@ -277,7 +277,7 @@
 				break;
@@ -296,7 +296,7 @@
 				break;
@@ -316,7 +316,7 @@
 				break;
-			case "OGC:LITERAL":
+			case "LITERAL":
 				if ($element["type"] == "complete")
 					if ($boundary == "upper")
@@ -333,13 +333,13 @@
 				break;
-			case "OGC:PROPERTYNAME":
+			case "PROPERTYNAME":
 					$objects[$parentactual]->ogcPropertyName = $element["value"];
 				break;
-			case "OGC:LOWERBOUNDARY":
+			case "LOWERBOUNDARY":
 				if ($element["type"] == "open")
 					$boundary = "lower";
@@ -349,7 +349,7 @@
 					$boundary = "";
 				break;
-			case "OGC:UPPERBOUNDARY":
+			case "UPPERBOUNDARY":
 					$boundary = "upper";
Modified: branches/mapbender_sld/http/sld/sld_function_handler.php
--- branches/mapbender_sld/http/sld/sld_function_handler.php	2007-12-18 14:35:47 UTC (rev 1930)
+++ branches/mapbender_sld/http/sld/sld_function_handler.php	2007-12-18 15:17:01 UTC (rev 1931)
@@ -96,7 +96,7 @@
 			db_select_db($DB,$con);
 			/*$sld_xml = "<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n<StyledLayerDescriptor version=\"1.0.0\">\n";*/
-			$sld_xml = "<StyledLayerDescriptor version=\"1.0.0\">\n";
+			$sld_xml = "<StyledLayerDescriptor version=\"1.0.0\" xmlns=\"http://www.opengis.net/sld\" xmlns:ogc=\"http://www.opengis.net/ogc\">\n";
 			foreach ($layer_names as $layer_name)
@@ -131,8 +131,9 @@
 			$sql = "SELECT fkey_layer_id FROM gui_layer WHERE fkey_gui_id='".$_REQUEST["gui_id"]."' AND gui_layer_wms_id=".$_REQUEST["wms_id"].";";
 			$res = db_query($sql);
-			$sld_xml = "<StyledLayerDescriptor version=\"1.0.0\" xmlns=\"http://www.opengis.net/sld\" xmlns:ogc=\"http://www.opengis.net/ogc\">\n";
+			$sld_xml = "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n";
+			$sld_xml .= "<StyledLayerDescriptor version=\"1.0.0\" xmlns=\"http://www.opengis.net/sld\" xmlns:ogc=\"http://www.opengis.net/ogc\">\n";
 			while ($row = db_fetch_row($res))
 				$layer_id = $row[0];
More information about the Mapbender_commits mailing list
