[Mapbender-commits] r1730 - branches/mapbender_sld/http/sld
    svn_mapbender at osgeo.org
    Mon Oct 15 10:30:05 EDT 2007
Author: mschulz
Date: 2007-10-15 10:30:05 -0400 (Mon, 15 Oct 2007)
New Revision: 1730
   branches/mapbender_sld/http/sld/sld_function_handler.php
added new function to construct sld document, column name changes
Modified: branches/mapbender_sld/http/sld/sld_function_handler.php
--- branches/mapbender_sld/http/sld/sld_function_handler.php	2007-10-15 14:28:15 UTC (rev 1729)
+++ branches/mapbender_sld/http/sld/sld_function_handler.php	2007-10-15 14:30:05 UTC (rev 1730)
@@ -27,7 +27,7 @@
 	$con = db_connect($DBSERVER,$OWNER,$PW);
 	db_select_db($DB,$con);
-	$sql = "UPDATE sld_user_layer SET sld_xml='".$data."' WHERE layer_id=".$_SESSION["sld_layer_id"]." AND mb_user_id=".$_SESSION["mb_user_id"].";";
+	$sql = "UPDATE sld_user_layer SET sld_xml='".$data."' WHERE fkey_gui_id='".$_SESSION["sld_gui_id"]."' AND fkey_layer_id=".$_SESSION["sld_layer_id"]." AND fkey_mb_user_id=".$_SESSION["mb_user_id"].";";
 	$res = db_query($sql);
@@ -55,11 +55,11 @@
 	// the function "getusersld" is called by the mapserver to get the user's sld
 	else if ($_REQUEST["function"] == "getusersld")
-		if ( isset($_REQUEST["layer_id"]) && isset($_REQUEST["user_id"]) )
+		if ( isset($_REQUEST["layer_id"]) && isset($_REQUEST["gui_id"]) && isset($_REQUEST["user_id"]) )
 		{ //Used for the preview
-			$sql = "SELECT * FROM sld_user_layer WHERE layer_id=".$_REQUEST["layer_id"]." AND mb_user_id=".$_REQUEST["user_id"].";";
+			$sql = "SELECT * FROM sld_user_layer WHERE fkey_gui_id='".$_REQUEST["gui_id"]."' AND fkey_layer_id=".$_REQUEST["layer_id"]." AND fkey_mb_user_id=".$_REQUEST["user_id"].";";
 			if ( db_fetch_row($res, 0) )
@@ -69,15 +69,16 @@
 					echo db_result($res, 0, "sld_xml");
-		} //Used for mapbender integration
-		else if ( isset($_REQUEST["layer_names"]) && isset($_REQUEST["user_id"]) )
+		} //Used for mapbender integration - old deprecated
+			else if ( isset($_REQUEST["layer_names"]) && isset($_REQUEST["user_id"]) )
 			$layer_names = split(",", urldecode($_REQUEST["layer_names"]));
-			$sld_xml = "<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n<StyledLayerDescriptor version=\"1.0.0\">\n";
+			/*$sld_xml = "<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n<StyledLayerDescriptor version=\"1.0.0\">\n";*/
+			$sld_xml = "<StyledLayerDescriptor version=\"1.0.0\">\n";
 			foreach ($layer_names as $layer_name)
@@ -87,8 +88,8 @@
 				$layer_id = "";
-					$layer_id = db_result($res, 0, "layer_id");
-					$sql = "SELECT * FROM sld_user_layer WHERE layer_id=".$layer_id." AND mb_user_id=".$_REQUEST["user_id"].";";
+					$layer_id = db_result($res, 0, "fkey_layer_id");
+					$sql = "SELECT * FROM sld_user_layer WHERE fkey_layer_id=".$layer_id." AND fkey_mb_user_id=".$_REQUEST["user_id"].";";
@@ -103,6 +104,34 @@
 			$sld_xml .= "</StyledLayerDescriptor>";
 			echo $sld_xml;
+			else if ( isset($_REQUEST["wms_id"]) && isset($_REQUEST["gui_id"]) )
+			$con = db_connect($DBSERVER,$OWNER,$PW);
+			db_select_db($DB,$con);
+			$sql = "SELECT fkey_layer_id FROM gui_layer WHERE fkey_gui_id='".$_REQUEST["gui_id"]."' AND gui_layer_wms_id=".$_REQUEST["wms_id"].";";
+			$res = db_query($sql);
+			while ($row = db_fetch_row($res))
+				$layer_id = $row[0];
+				$sql = "SELECT * FROM sld_user_layer WHERE fkey_layer_id=".$layer_id." AND fkey_gui_id='".$_REQUEST["gui_id"]."';";
+				$res2 = db_query($sql);
+				if ( db_fetch_row($res2, 0) )
+					if ( db_result($res2, 0, "use_sld") == "1" )
+						$data = db_result($res2, 0, "sld_xml");
+						$styledlayerdescriptor = parseSld($data);
+						$sld_xml .= $styledlayerdescriptor->layers[0]->generateXml(" ");
+			$sld_xml .= "</StyledLayerDescriptor>";
+			echo $sld_xml;
 	// sets whether the user wishes to use a sld for this layer
@@ -112,8 +141,16 @@
-			$sql = "UPDATE sld_user_layer SET use_sld=".$_REQUEST["use_sld"]." WHERE layer_id='".$_SESSION["sld_layer_id"]."' AND mb_user_id='".$_SESSION["mb_user_id"]."';";
+			$sql = "UPDATE sld_user_layer SET use_sld=".$_REQUEST["use_sld"]." WHERE fkey_layer_id='".$_SESSION["sld_layer_id"]."' AND fkey_mb_user_id='".$_SESSION["mb_user_id"]."';";
+			# update gui_wms_sldurl
+			if ($_REQUEST["use_sld"]=="1")
+				$sld_url = $_REQUEST["mb_sld_url"];
+			else
+				$sld_url = "";
+			$sql = "UPDATE gui_wms SET gui_wms_sldurl='".$sld_url."' WHERE fkey_gui_id='".$_SESSION["sld_gui_id"]."' AND fkey_wms_id=".$_SESSION["sld_wms_id"];
More information about the Mapbender_commits
